Originally Posted by
Big Boost
Do you offer your stand alone ecu that is ready to go and will control the existing dash info? More specifically, is it a plug and play where you could have the software already set to the needed parameters to operate the S4 info systems? If so, how much? Thanks.
We can make a plug and play system to use the 034 Stage IIc,that would not be an issue.The issue would lie in being able to pass inspections in your state.If that can be solved then you are golden.
awtst3.a6
Are you making a kit for this swap or offering tuning/instal? This would be one worth a trip to get worked on. As far as the a6.. I guess the question would be is the room about the same? I have heard these motors don't last that long. How long have you been testing this motor?
We allready have a 12V kit that is pretty much bolt in for any B5 chassis.
The 24V kit I am working on still.This is my own personal project:
You can see the use of OEM motor mount brackets
RusS4
seems a litte more complicated than that. i mean even chris green said that it wasnt ditect bolt in.
I went down to Florida to help out Chris with the project.
The reason I created this thread is that there is too much misinformation floating around so if I or anyone from 034 did not post it then take it with a grain of salt.No engine swap is direct plug and play but like ALL engine swaps the more people that do them,the more information gets transferred around making the swap easier and easier to do.
wdbdy2000s4
idk about the mounts...maybe they work for the 24valve...but:
See post below
revhards4
I believe the 24v vr6 is a direct swap with the adapter plate only. The 12v vr6 is not. The most desirable reason to go VR6 is not that it's a better motor than the 2.7t it's just that there is more room to run a very large turbo. More difficult with the space provided with the v6.
The 12V VR6 is the same as the 24V.
The issue with the 12V VR6 motor is that it came in 5 chassis's at most and NONE of them were longitudinally mounted.This meant that the block did not have alot of provision for mounting bosses of an engine mount bracket.The only mounting boses you will find on a 12V VR6 motor @ the rear for the MKIII VR6 rear engine mount bracket (4 boses) and on the front of the motor for the accessory bracket.The reason why we say you cant run AC if you want a sturdy bracket is because you build a bracket that goes where the AC compressor once went.
The 24V VR6 motor came in NUMOUROUS chassis:
* Porsche Cayenne
* Audi Q7
* VW Phaeton
* VW Touareg
* Audi A3
* Audi TT
* VW Golf
* VW Jetta
* VW R32
* VW Eurovan
* VW Sharan
* Seat Leon
etc etc...
Whenever VAG uses an engine in numourous chassis's you can almost guarantee that it will stuff as many mounting boses on the block as it possibly can.Any 1.8T users in here ever looked at there block close up? You would see 4 different configurations for mounting a 1.8T motor.The 24V VR6 motor was no different.
Here is a list I put together yesterday on Motorgeek:
Wizard-of-OD
2.8 24V VR6 Engine - 1500 USD (high) to 1000 USD (low).
Manifold - can use a y-pipe EIP style - 250 USD or full log - 600
Downpipe - 495
GT3582R - 1295
Clutch Set up - 790
Flywheel - 430
Adapter Plate - 210
Starter Motor - 425
Engine Management - 1700 USD for the Stage II + 595 for the harness = 2295 or if you have the skill....put a 24V harness in the B chassis.
OEM Motor mount brackets - 600
Fueling - (6) 630cc injectors and an adjustable FPR - 540
Oil pan - 500
Misc - 2000
And I am being over generous
Total = 11680
And you will have a set up that will blow the doors off any S4 out there.
On my own personal project the plan was to graft the ME-7 harness into a BX chassis but anyone here who has done wiring knows that this is a task that will drive you insane.The only other possible solution was to get the S4 harness and modify it to work on either engines.Great for a 24V but sucky for a 12V.
