Results 1 to 4 of 4
Thread: VAG-COM
    Dec 28 2008
    south africa
    Question VAG-COM
    hey,
    can anyone help me with these codes '09236' and '05634'...i used a VAG OBDII reader.
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Re: VAG-COM
    Quote Originally Posted by simi362 View Post
    hey,
    09236 - I have nothing on this one can't find it in any of the listings
    18010/P1602/005634 - Power Supply B+ Terminal 30: Voltage too Low
    Possible Causes
    * Cables on the Battery were removed
    * Battery weak (voltage)
    * Generator Disfunction
    Possible Solutions
    * Check Battery Cables
    * Check/Replace Battery
    * Check/Replace Generator
    Special Notes
    * If multiple Control Module have Power Supply Faults stored, it's most likely to be one common Problem like the ones shown above. Otherwise when only one or two Control Modules have such Codes stored you better start searching at the individual Power Supply of these Modules.
    -Kris
    Dec 28 2008
    south africa
    Re: VAG-COM
    Quote Originally Posted by IceMole View Post
    Possible Causes
    Possible Solutions
    Special Notes
    ok thanks for the info!!
    Jun 11 2014
    IN/BJ
    I have the same code on my 07 C6S6, thank you for the information!!
