Page 1 of 21 12311 ... LastLast
Results 1 to 40 of 839
    Veteran Member Three Rings speeding-g60's Avatar
    May 19 2009
    PNW
    My BAMFT AEB 366XL solid head drag chassis buildup
    so i am new here.... been pointed this way by a few regulars. i carry the name almost everywhere, its easier to spot me that way. my new drag chassis i am working on right now is going to be a monster.... it is being built to cert in the 8.50 class. the goal is 9 sec 1/4 mile. bottom end built by Issam. top end built by Joey @ DJM in Portland in case you dont know of him. SM4 tuned by Kevin "Lugnuts" Black. most other stuff internet sourced. all 034 parts supplied by Issam. exhaust manifold and downpipe, if you can call it that, was built by Jim and Brian of HorsepowerConnection in Lacey WA.
    Jake told me to post it here, and make it good if i wanted half a chance to have it stay.
    the car is now being assembled. and it is getting painted this fantastic looking deep burgundy-ish color. we may paint the rest of the car this weekend if its nice.
    i read the rules, and i know it said B5, but nobody is going to see it in the Coupe Quattro section, and it is based upon the B5 motor (please let it stay).
    anyways, if ya move it ya move it. how many people ditch the 20v I-5 for a 20V H(uge)T 4cyl?
    some quick stuff to layout, then i will post a few pix. if you dig it i will put up more... if not, cool. i shared something...
    AZG (VW 2.0L) block, 06A. ditched the 92.8mm crank.
    86.4mm Forged crank.
    83.5mm JE pistons, coated and also with custom 21mm pins.
    custom length Scat rods.
    Billet main caps.
    Block Girdle.
    034 coated bearings throughout.
    ARP head studs.
    basically destroking the motor to survive in the 10k rpm range.
    AEB head, non ported.
    CAT Billet solid lifter cams, 1003756.
    Supertech springs & retainers.
    Supertech valves, +1mm SS Nitrided intakes and stock sized Inconel exhaust, single groove option on both.
    CAT solid lifters.
    CAT cam degree pulley.
    Supertech shim set.
    basically getting prepped to rev to the moon, Alice.
    Fueling is custom fuel cell.
    two Bosch Motorsport 044 pumps.
    all SS braided lines.
    Race-Craft Fabrication Fuel rail.
    Bosch 1600cc injectors.
    E85 fuel.
    BBK/Roush Racing 75mm TB.
    Engine management is Autronic SM4, going to hopefully fly Kevin out to tune it if we dont do the remote link.
    monitoring is all Stuart Warner gauges.
    NGK WB02.
    2-step and gear based boost controlled by SM4.
    Turbo is Bullseye S366XL. T4, divided inlet. 1.00 A/R. 5" inlet. 4" v-band exhaust, straight off turbo out thru fender by door. 3.5" Vband compressor outlet to AWIC.
    twin Tial MSv 38mm Vband wastegates, open dump.
    one single pipe for boost line. AWIC connects direct to TB.
    custom intake manifold. INA backplate with our design plenum.
    HKS SSQV BOV on the output side of AWIC.
    all the engine bits are custom. intake, catch can, VC breather setup, fuel cell, radiator cell, all of it we make.
    chassis is a 1990 Coupe Quattro. gutted, caged, suspensioned, all work done in that area by me. B4 CF hood. S2 rear bumper. Euro Cabby front bumper. half-tubed front end.
    suspension/drivetrain include 01E trans from UrS4.
    all axles custom made by A1CVTech in Canada.
    a full custom coilover setup built by yours truly.
    all solid 034 subframe mounts.
    ClutchMasters FX 700 Twin Disc clutch setup.
    motor and trans are solid mounts as well.
    rear diff is hockey puck mounted, with Delrin rear mount.
    control arms all delrin from 034.
    all tie rods are swedged tube, heims end, made by me.
    Wheels are Centerline Convo-Pro 15 x 7.5 front and 15 x 8.5 rear.
    tires are M&H Racemaster 24.5 x 8.5 slicks.
    full 10 point roll cage is based from my own design and bent by S&W Racecars.
    Maunal brake conversion.
    Girling G60 dual piston front brakes with D/S rotors.
    Wilwood prop valve.
    custom SS lines.
    i hope you actually read all that, and didnt skim to the pictures. but if you did, there is some stuff to see that will make you back up and read stuff.
    on to a few pictures.... you gotta watch though, cuz i sometimes get carried away with pictures :)
    manual steering rack from a Fox.
    deleted the hydro brake booster, fully manual brakes.
    Wilwood prop valve, stainless lines.
    slotted/drilled front rotors on Girling G60 two piston caliper front setup.
    i run a 20V with a 35R in the drag rabbit. here is a few pix of the size difference between this turbo and a GT35R, if anyone really wondered how much bigger this turbo is. these are sitting on a set of 2x12's, BTW.
    May 19 2009
    PNW
    Re: My AEB 366XL solid head build
    May 19 2009
    PNW
    welded the center diff for full time no-split AWD.
    May 19 2009
    PNW
    its a nice view, i wonder what the combined power output will be :)
    and man, the front shot just looks mean as hell....
    and some line work accomplished. also, cut up the turbo compressor housing a bit, fitting for the boost pipe.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Yay, Aaron has arrived !
    May 19 2009
    PNW
    if you guys dont want this here i understand. just delete it if thats what you want to do.... its cool by me. just thinkin to show you guys some stuff that is related to your builds, that are being done out in the world. there are some of you that know me from Poortex.... and MG, and VWSport, and other places....
    just another car nut in the great scheme of things is all. i like to see others work, and show mine.
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    wow
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Feb 27 2005
    North Wales, PA
    i think i saw this on motorgeek.Maybe not. Awesome build. The motor heads here just popped boners.
    May 19 2009
    PNW
    yeah you would have seen it on MG.... the full play by play is there.... this is the bulk of the cool pix....
    you guys dont want to see stuff like gutting interiors, engine bays, etc.
    so far, seems you like it.
    this car is in a class of its own. and since this whole build pretty much revolves around the motor anyways, may as well share. it all pertains to you B5 A4 20v guys anyhow... its all the same stuff.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    JESUS H CHRIST!
    this will decimate all!!!!!
    can't wait to see more progress! im giving you rep just because
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Oct 29 2005
    10speed
    San Francisco, CA
    So, I guess a passenger headlight isnt going to happen eh? I feel like the compressor is going to suck the world in
    btw Im sorry that your friends with Jake, that sucks
    - Clint
    May 19 2009
    PNW
    another shot or two of the size of this turbo.... it is kinda largish. 38 pounds it weighs.
    Active Member Three Rings 4inchMAF's Avatar
    Sep 04 2008
    Columbus O-high-O
    sup man!!! this is Biggee Talls from that one big, gay-ass VW forum. what you have here is just beyond words..... i will follow this closely. glad you could make it....
    Oct 29 2005
    10speed
    San Francisco, CA
    you know your a baller when you have v-band housings on your turbo...
    Anyway, 50trim S will love that your destroking and making high revs
    - Clint
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Good lord man! Can't wait to see the results.
    Oct 27 2007
    In the lab
    I'll chop your nuts off and make you eat them you dirty whore...
    Oct 27 2007
    In the lab
    Aaron, any ETA on the shortblock?
    May 19 2009
    PNW
    Quote Originally Posted by 4inchMAF View Post
    and you now see why this would not be put up there....
    the 50Trim's and those damned retarded MK4 drivers that havent a clue....
    dont say that name... what if he googles his name and finds this place? he wont know about it if i can help it.
    May 19 2009
    PNW
    Quote Originally Posted by 317ssayzarc View Post
    spoke with Issam today. block is ready. i sent FW to him to have the whole deal balanced complete.
    i am having the axles (stock and custom) and all my hubs/spindles that are @ A1CVTech crated up in the same pallet box. so i can SORTA save on shipping. still gonna be spendy i think.
    will call Marco tomorrow and see what he says, when he will be ready. its going to be busy here when all that stuff hits, though. i will have to put the rabbit back in the storage with the Vortech SC'd MK3 VR6. they like each other, all alone in the dark there... freaky VW's anyhow.
    whole garage dedicated to the one car again.
    Established Member Two Rings STS9king's Avatar
    Apr 27 2009
    Denver
    hey man, glad to see you made it over here and left joketex. that drag car of urs is going to be pretty slow ;)
    1999 A4 Avant: PT 5558 DBB, Tapp 630cc software (91 octane), spa exhaust mani, CM stage 4 clutch, 034 track density motor/tranny mounts, wahlbro 255, porsche brakes, h&r sports w/ bilstiens, BBS wheels, turbo timer, JHM solid linkage and bushings, fully built motor top to bottom, 8,500rpm redline. 420awhp
    (daily driver) 2008 bmw 335xi - cobb tune- the rest stock - 13.0@106mph (6000' altitude)
    (retired) 01 1.8t jetta: t3/t4 12.7@107mph (6000' altitude)
    Veteran Member Three Rings michael66899's Avatar
    Oct 26 2006
    A lot of B5 S4's
    WA
    Damn, love it man this thing is going to be an absolute beast. Where about in the PNW do you live? And you have to let me know when this thing sees its first TnT, I wana be front row.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    sick.
    Jim
    I Do Werk.
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    braaapap braaappapa braaaapapapaappa
    Going to enjoy hearing the first crank from this.
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    Good stuff I cant wait to see a vid of this.
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Feb 15 2007
    marimont
    You plan on brushing your teeth in front of the engine in the morning?
    So how long have you been building this car for?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I'm seriously impressed. Not only are you going big, you're kicking it old school too.
    I recognized the name from the whoreTex, your name is a sign of quality in my mind.
    Good luck with the build, just make sure you keep us in the loop for the progress.
    I've been waiting to see what a divided T4 can do on a VW 4cyl.
    May 19 2009
    PNW
    Quote Originally Posted by solowb5 View Post
    well, i got the car in maybe July last year. it was delivered to my house with me never even having seen this body style at that time. i was working out of state until Feb this year. i would work on it like part of a day on every other weekend, or bring parts to the jobsite to build. like the coilovers, i built those after work at the jobsite. welded up the subframes, that kind of stuff. been working on parts and procuring parts since then....
    it WILL be running this year. i do have two drag cars, the rabbit is up and running, just waiting to get it back out there. but since it has no traction, i built this one. the rabbit spins across the line in 4th gear, GT35R @ 36psi, 130 MPH burnout. thats cool to say once or twice, but every time its annoying LOL.
    Quote Originally Posted by djwimbo View Post
    thats for the kind words. i try. it makes no sense to shortcut, i find everytime i have ever tried it bites me in the ass. like the OEM headstuds on the rabbit, with the 35R. lifted head @ 36psi on my first run this year. now Raceware headstuds.
    we will keep this updated.... and thanks for the good words from all you'ns over here.... its good to be away from all the critics and E-racers/tooners that have never done anything but pick apart someone elses work. what i do, i do for fun, and to satisfy me. i am not a serious racer, my job is demanding at times and i dont get to go race alot. but i like to wrench on my cars, and i like to drive fast. last year i got 13 passes total in the rabbit, thats why i built this chassis. no changes to make to the rabbit so i figured WTF, build something that will hook up.
    Quote Originally Posted by michael66899 View Post
    i live down in Oregon, and i plan to bring this to Pacific Waterlands show on Aug 30th @ Woodburn Dragstrip. but hoping to T-n-T it before then.
    Aug 05 2008
    Highland
    this thing is going to be an absolute monster. and i look forward to 9 second times slips.
    edit: i skimmed through the wording above, but did you happen to mention what the approx weight of this thing is going to be over here? cause i think peoples jaws will drop even a bit more.
    Oct 30 2006
    B8 A4 Avant 6spd
    You sure that turbo isn't going to create a problem?
    With space time continuum that is?
    Incredible build, very impressive stuff, good luck, I hope you put down some nutty numbers with this thing. /Wishes this was a B5.
    -18 718 GTS
    May 19 2009
    PNW
    these come in stock around 3175 curb weight.
    this one right now, as it sits, next to that 1800 pound rabbit, weighs only 1760 pounds. i do have some stuff to put back in, like axles, brakes, minimal stuff. i really cannot see 500 pounds going back in. hell, i can pick the front of the car up off the ground by myself, with the motor/trans in it!
    not sayin i am a "huge friggin guy" (said in Boston-ese from the movie Boondock Saints) but i am not scrawny....
    so i look to have this thing around 2300 pounds or so all said and done. maybe a touch more.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Looking good Aaron, plenty pics I haven't seen yet. Thanks for that transmission. :)
    May 19 2009
    PNW
    no worries.... and i got lots more pictures than this. these are just some of the better ones. if i had known you wanted more in emails, i woulda shot you some more :D
    Veteran Member Three Rings kevin12's Avatar
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    Incredible build. Can't wait to see more! Love that its in a quattro coupe too
    Current:
    17 Ibis White A3 2.0TQ S-Line
    01.5 Santorin Blue A4 1.8TQ 5-Speed
    Uni 1+, XS Power Exhaust, ST Coilovers, Forge DV
    99.5 Laser Red A4 2.8Q Tip Totaled RIP
    01.5 Casa White A4 1.8TQ Tip Current Parts Car
    08 Ibis White A4 2.0TQ Tip S-Line
    Jul 07 2004
    socal
    Quote Originally Posted by speeding-g60 View Post
    If I am able to get a enclosed trailer before this summer I will try to make it up to the Waterlands event.
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    you should name the car the serial crusher
    Sep 04 2008
    Columbus O-high-O
    LOL!!!!! he said this was his idea in one of his posts, and that it was "biggest" contribution to the 1.8T "community".
    im so glad he doesnt drive an audi...
    anyways, are those billet cams solid? or hollow?
    May 19 2009
    PNW
    they are solid billets. and they are for solid lifters. so double solid?
    and Mike, that would be sweet ass if you could come up here, but horrible if you beat me hahaha. but it is a good track... August is hot though.
    but i tell you, it would be an EPIC event if you did come. we could make it happen that we run it heads up :) that would be one hell of a video, and i have a great camera guy going to be there to film it. and Kris and Ken are coming from down that way, they do GREAT film work.
    Serial Crusher, huh? i made a lil vid or two, i got kinda off-track and slipped into VORTEX mode. defending myself, with some "pix or it didnt happen" type challenge. i took the bait, of course.... thats where the "huge friggin guy" came from LOL.
    Oct 06 2004
    Minnesota
    Wow. That is all. Just WOW
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I love the commentary on the vids.
    Good choice on the quattro for this build. Quattro > FWD
    May 19 2009
    PNW
    yeah, some of you know my frustration with vortex and the 1.8T forum.... and it was not even there that it started. but it just hit me as the regular vortex attitude.... and i hit right back with "OH YEAH?".
    it really helps that the tube-framed front end happens to have the cross bar at such a level and height that it is an easy(ish) pull. but still.... i will admit i flared a little.... there are alot of people that try and make themselves off as more than they really are. say they do things that they could not even dream of doing in reality.
