Results 1 to 30 of 30
    Senior Member Two Rings jdogg's Avatar
    May 19 2009
    Is the plastic shield under engine necessary?
    I am a newbie and was wondering if anybody has taken of the black plastic shield underneath of the engine. It is blocking me from doing any work, and i do not want to put it back on if i don't really need it. I know it serves a purpose, but it is an annoyance to me since i cant see where i have fluid leaking from.
    Thank you in advance for any feedback.
    I have what i think might be run off from the oil filter, and wasnt cleaned off after oil change. It looks like dirty oil dripping from the right front axle bolts, they are the 2 bolts holding the axle i think?
    Senior Member Three Rings akarol's Avatar
    May 09 2008
    2003 Audi A4 3.0 Cabriolet
    Orlando, FL
    Re: Is the plastic shield under engine necessary?
    Not needed but a precaution. I would feel uneasy knowing that at any moment, something from the road can jump up and really damage the engine.
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    I love a clean engine bay and the shield does exactly that. It takes about 3 minutes to take it off and another 3 to put back on, don't be so lazy.
    I have an opening where the block and tranny meet where I can see the flywheel, is that normal?
    Buncha motorcycles
    Memphis, TN
    its also my understanding it helps force the air through the engine better. if the air can escape out the bottom then it doesnt flow through the radiator and engine bay as well, increasing engine, exhaust and IATs especially for those of us with FMICs.
    With that being said, i ran all winter without mine, but i may run some logs this weekend before and after i put it back on... im curious if there is a measureable difference.
    dont forget it has some air scoops/vents on the pan to pull hot air out of the bay as well...
    Quote Originally Posted by fitch303 View Post
    yep
    APR Stage 2/AWE Intake
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    I see no reason why I would take it off. Road debris alone is enough for me.
    May 19 2009
    Thank you for your feedback. I just do not think that on my car the shield is sitting correct. There is a couple of plastic clips that are not in place and there is little bit of sagging on the rear end. And also it is in my way of getting at everything i want to see. I only have a smaller jack and cant really get to far underneath.
    I am trying to find where the oil is dripping from.
    Feb 12 2004
    Everywhere
    Did someone change your oil for you recently? If so they could have spilled a bunch from the oil filter onto your subframe and it's slowly dripping off.
    Also check the turbo oil return gaskets, oil pan drain plug, valve cover gasket, crank seals, etc...
    You probably knocked off some 1/2 turn screws and/or the clips those screws turn into. There are three in the rear of the belly pan that hold it in place.
    May 19 2009
    I just bought and picked up car last week. I had been told that the oil was changed, so that is what i was assuming happened, but i cant see beyond the shield. Until i get it off i am going crazy because i do not like drips on my drive way. I own a 93 civic as well with 400k and never had dripping!
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    Quote Originally Posted by jdogg View Post
    was that 400k a typo?
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Anybody interested in buying these, I thought about contacting a supplier to reproduce these at a lower cost, since, they always come up missing on our cars(Jiffy Lube)
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    Quote Originally Posted by gtsingh91 View Post
    honda lol..
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Veteran Member Four Rings Pufftrees's Avatar
    Mar 10 2009
    B9 RS5, B9 SQ5, B5 S4
    New Jersey
    Quote Originally Posted by akarol View Post
    I do feel uneasy lol, I havent had mine since i bought the car. Some mechanic at a jiffy lube prob forgot to put it back on and I never felt like paying for a new one
    Cheap and fast wont be reliable.
    Reliable and cheap wont be fast.
    Reliable and fast wont be cheap.
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    Mine is sitting in my garage right now. I still haven't put it on...
    FWIW that piece of plastic will do you no good if you hit something in the road. It's really only good as a wind deflector, and I'm wondering how good of a job it does at that.
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Alot of people have them, alot of people dont, me personally haven't had one for 2+ years.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jan 03 2008
    Columbus, Ohio
    The shield also helps you locate where the leaks are.
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    I don't have one either. My car didn't have it when i bought it. I'm contemplating getting a new one to put on just cause i don't like the idea of mud and rocks and whatever else is on the road flying up into the engine bay. And like someone else said, it'll help keep the engine bay cleaner, which is a plus to me. Although i might not end up getting a new one. It might just be a bigger PITA than it's worth.
    - Justin -
    Veteran Member Three Rings szinkuti's Avatar
    Oct 06 2008
    Allroad Truck aka Uber UTE
    Grand Prairie, Texas
    its not really a shield...its a "noise insulation pan" according to Audi....it does not protect against road debris....i have seen lots and lots of cars that come in with the belly pans on and oil pans with holes in them....
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Took mine off when I started doing my own oil changes 4 years ago... after the warranty expired and I got tired of paying $60 for synthetic oil changes. My how time flies.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Feb 12 2004
    Everywhere
    Tell me how it doesn't protect against road debris? It's common sense no matter what audi uses it for. A rock 1/2" in size will probably not break the belly pan. But it will prevent it from flying up into the engine bay. That's protecting against road debris IMO... I have worked on many cars and it seems all the cars running without a belly pan have a more dirty engine bay.
    Senior Member Three Rings Johnnada's Avatar
    Aug 02 2008
    04 Audi A4 3.0, 09 BMW 328 X-Drive
    MA
    Quote Originally Posted by manhertm View Post
    I am interested, but the shipping cost is the problem.
    Veteran Member Four Rings maclem8223's Avatar
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    Quote Originally Posted by CO AVANT View Post
    Road debris I agree with; clean engine bay depends on where u live. If I wasn't in socal I wouldve bought a new one just for the keeping it clean factor. Had a b5 and b6 no problems this far without it...
    ~Matt~
    BetaAlphaTauMemeber #45
    USPMemeber #1001
    04' 1.8T Q6M 2871R Revo Tuned
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    After the horror stories I've heard, (rocks hitting the oil pan, water from a puddle causing the power steering to fail, etc.) I'm wary about not running with it. I think Winston (podi) was thinking of making a metal one.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Oct 09 2008
    I agree.
    Wouldnt a metal one be more heavy?
    EDIT: But I guess it would be more protective, so about how much more would a metal one weight vs. the plastic one?
    The Awesome™
    Registered Member Two Rings
    Apr 11 2009
    MN
    Not really necessary. I've been driving without one for a while now just because it is such a pain in the ass to work on the car.
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    This is the last belly pan thread I'll state this in; hopefully someone will refer back to it on the millions of times it gets posted in the future...
    I logged before and after.
    All temps went down noticably with pan ON.
    There is a reason race cars run them. Air turbulance hurts in many ways. Temps just being one that we'd worry about, since none of us are fast enough on a road track yet to worry about the other effects, lol.
    Run without it for all I care. I was going to since my car doesn't get driven in bad stuff. But after logging, no way. It stays on. And it isn't a big deal to take off; I don't see what all the fuss is about for an extra minute or two TOPS. But hey, it ain't my car, so have at it.
    My 2004.5 APR Stage 3+ is SOLD
    Veteran Member Four Rings itsdarrow's Avatar
    Jan 27 2006
    Nyc
    havent had mine on for 3yeard and everything is great
    black B6 a4, 18x8.5 anthracite bbs ch, Full frame gt28rs kit, Unitronic 440 file, high on meth.
    Account Terminated Two Rings
    May 08 2009
    Ontario
    I've heard it also helps direct air flow underneath the engine.
    I'll keep mine on anyways.
    Sep 29 2008
    too lazy and a pain to put on and take off...so its been off
    the only upside I see in having it off is that I can find any leaks in the engine right away, I noticed valve cover gasket and front cam seal right when it happened. I don't think I would have noticed the small cam seal leak until I did my next oil change...
    Established Member Two Rings mullardel34's Avatar
    Nov 26 2008
    `03 A4 3.0L Quattro (manual)
    Midwest US
    The A4's skid-plate serves a number of purposes beyond its sound-dampening task; the skid-plate improves aerodynamic air-flow as well as providing additional protection for the engine's oil-pan.
    At highway speeds (55+mph), a number of forum members have observed a loss of several miles-per-hour when operating without an engine skid-plate. The plastic OEM skid-plate can fracture, with chunks of the skid-plate being released by encounters with road debris. As long as 75% or more of the skid-plate remains intact and properly attached to the car, most of the highway mileage benefits are retained.
    The B6 A4's oil-pan is amazingly thin-walled and fragile; the skid-plate provides an important additional degree of protection. For those with a B5 A4 (1996-2001), there's the "Panzer Plate" heavy-duty replacement skid-plate fabricated by DieselGeek (http://www.dieselgeek.com/servlet/Detail?no=375). The "Panzer Plate" skid-plate is only a few bucks more than the plastic OEM part and offers a durable aluminum skid-plate that only adds a few pounds of weight (I wish these guys offered a "Panzer Plate" for my B6 A4; I'd buy it in a heartbeat... ;-)
    Mullard EL34
    * 2003 A4 3.0L Quattro (6-speed manual)
    * sport package
    * 18"x8" Moda MD5
    * Sumitomo HTR+ (235/40ZR18))
    Deactivated Three Rings
    Jun 10 2007
    Toronto, Ontario, Canada
    I, too, debated removing the plastic shield permanently to faciliate work under the car but after thinking about it carefully for 30 seconds, I decided that it was not a big ordeal to either put it on or take it off.
