Results 1 to 40 of 54
    Senior Member Two Rings jms-4's Avatar
    May 14 2009
    2000 Audi S4, 68 Mustang
    Renton, WA
    Replaced my driveshaft center support bearing this weekend. Anyone interested in a
    write up?
    If enough folks want one, I'll bang one out.
    No pictures, though. Job is way to greasy to handle a camera.
    Jeff
    2000 S4
    Revo w/SPS3
    AMS TBB, Stern snub mount, Apikol Rear Diff Mount
    3" custom exhaust, Minor lemmi tweaks
    ST Coilovers
    710N, EBC Slotted + Dimpled
    Incognito Piggie Pipes, 034 Density Trans Mounts
    Voodoo MBC Ceramic in MBC only mode
    other stuff
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    Re: Replaced my driveshaft center support bearing this weekend. Anyone interested in
    +1 to doing a write up. Would be good to know how.
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    +2 for write up. We never know.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ă C, CĂ*
    +3, was goin got change mine out, but it seemed cheaper to buy a whole shaft for $400 shipped rather than buying the bearing, and having it pressed out. What center support did you go with?
    May 14 2009
    Renton, WA
    Quote Originally Posted by infinkc View Post
    The one from 034.
    It's not pressed on. It came of with 2 hits on the sides with a hammer and screwdriver.
    The hard part was getting the drive-shaft separated.
    In fact, that was the only thing that gave my friend and I any grief.
    Jeff
    2000 S4
    Revo w/SPS3
    ST Coilovers
    other stuff
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Midwest
    +4. Please
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    May 14 2009
    Renton, WA
    Driveshaft support bearing write up.
    Driveshaft support bearing using 034 Motorsports part.
    I am providing this write up for informational purposes only. PLEASE NOTE: AUDI SAYS THAT THIS IS A NON-SERVICEABLE PART. By undertaking any projects on your own, you assume the risk of bodily injury and/or damage to your car.
    I don’t think this can be done with just 1 person. In fact, I wouldn’t even try it. You can easily get the driveshaft out with one person, but I fail to see how you would ever get it back in.
    By far, the most difficult step is separating the driveshaft. If you don’t have a way to do that, do not even bother reading the rest. I will let you know what we did to separate it, but it was an ad hoc procedure.
    1. Jack up all 4 corners and put car on jack stands. Be sure to have it high since there will be two of you under there at times.
    2. Remove exhaust. If you need a how-to on this, stop right now and go to a shop. Basically, there are just a few hangers and some clamps that hold it to the DPs.
    3. Remove heat shield. I believe there are 4 10mm nuts holding it on. This is the heat shield that covers the driveshaft.
    4. Now, you’re looking at the driveshaft and the bearing bracket. Take your time here getting a sense for how the bracket is aligned on the car. It may make sense to mark how the bearing is situated. I didn’t since it was covered in grease and goop. Where the shims were placed between the bracket and the car was the only clean spot, so it was clearly marked anyway. As it turns out, my new bearing didn’t have holes, it had slots, so I didn’t really use the marks anyway.
    5. Get your allen set out and begin removing the 8 allen bolts that attach the drive shaft at each end. I recommend using power tools to speed things up a bit here. For one, you will want the ebrake on when loosening the bolts. On the rear, I think you can get two or 3 at a time. At the front it’s one at a time. So, loosen bolt, ask friend to release e brake, rotate driveshaft, ask friend to engage e brake, loosen bolt, repeat until all 8 are done. The thing are not too long, but getting enough room to turn the socket around the downpipes was difficult, thus my recommendation for considering power tools.
    6. Now that your hands are greasy (and they will be since there is a ton of grease in the driveshaft ends, remove the 2 bolts that hold the support bearing. Caution: the driveshaft is a bit heavy and will hurt if you let it fall on your head.
    7. Get driveshaft out from under car and IMMEDIATELY put some kind of protecting cover on each end. I used big ziplock bags and some tape. You may notice a gasket has fallen out or not (mine did). No biggie. It’s easy to put back in when you’re getting the thing back on your car.
    8. Now, you will notice there is a bolt (18mm I believe) in the middle of driveshaft under the u joint. That will be coming out.
    Here is a pic:
    Before you do that, though, take a breath and gather your wits.
    9. with your wits gathered, remove the bolt. A big washer will come out with it. Now you are looking at the driveshaft connection. This is where you will have the most difficulty. I took one look at mine and said “no freaking way.” The driveshaft appears to be pressed together, and you can’t press it apart with the ujoint in the way. But, the ujoint is machined together (this is how Audi made this part “unserviceable”).
    So, how are you going to separate these two things? Spray PBlaster on the teeth right now. Let it sit for 5 minutes. Then, spray some more. Do not get any in or on the ujoint. There is grease in there and Pblaster would likely ruin the grease.
    What we ended up doing is this: tapping it with a sledge hammer. Nope. Inserting an iron rod between the ujoint and the shaft connection and pounding that. Nope. Pulling on each end. Yeah, right. Finally, my friend says “I have an idea.” He walks around his garage, and comes back with a simple piece of steel in the shape of a right triangle. We’re going to use the thing as a wedge. We put the bolt back in the hole of the driveshaft about halfway. We then put the flat side of our wedge against the ujoint and began hitting it with a hammer. After a few whacks, we looked and saw we were making progress. When we estimated we were halfway there, we decided this was the time to mark the teeth so when we go to put the 2 pieces back together it would be lined up properly.
    NOTE: THE DRIVESHAFT IS BALANCED SO MISALIGNING THE TEETH WHEN YOU PUT IT BACK TOGETHER WILL MAKE VIBRATIONS WORSE. TAKE YOUR TIME HERE TO GET A GOOD MARK ON 1 TOOTH AND GROOVE, PREFERABLY 2. We used a Sharpie and only marked one groove and one tooth.
    A few more whacks, then we removed the 18mm bolt, and some light taps, and BINGO, driveshaft was separated.
    Now, to get the bearing off. I used a large screwdriver and whacked it 3 or 4 times, and it popped off. Be sure to hit the correct spot on the bearing. There seems to be a piece of steel that is coated in rubber. That’s where I hit. Be sure you’re not hitting the driveshaft.
    Make note of the orientation of the bearing. Note that it does go on a specific way. Now, tap it on. You could probably use a piece of wood to cushion the blows. It does not take that much force.
    To get the driveshaft back into one piece, grab the other end, find your marks on the teeth and grooves, line them up, and push the two sides together a bit. Now, insert the washer and 18mm bolt and begin tightening. By doing this, the bolt and washer will press them back together.
    Reinstall is basically steps in reverse. I had my friend hold the driveshaft while I put back the 2 bolts that hold the bearing to the car. I did this to hold the driveshaft, but I did not tighten them yet.
    Now, begin putting the driveshaft bolts back in I’d recommend power tools here once again, but don’t go too crazy with them, you don’t want to strip out a bolt at this point.
    Once those are in and tightened, line up the bearing bracket as best you can, and tighten the bolts down.
    Put on heat shield, put on exhaust (again difficult with just one person) and crack a beer. You just spent about $100 and 3-4 hours (max) on a repair that Audi wants you to spend $400 on parts and another $100+ per hour of labor.
    So, once we got everything buttoned back up, the car was still off the ground, so I had my friend get in a start the car (I was seriously coated in brease and muck), put it in gear, and shift a bit. He took it up to 30 mph and we noticed no problems.
    “You won’t notice anything until the driveshaft is under load” he tells me. OK.
    Driving home, let’s just say I put the thing under load a few times, and not a singe vibration was felt.
    I’d have to conclude that my “unserviceable part” had in fact been serviced by me.
    The driveshaft is now my bitch, and I feel about $700 richer.
    Questions?
    Jeff
    2000 S4
    Revo w/SPS3
    ST Coilovers
    other stuff
    Registered Member Two Rings
    May 17 2009
    Virginia Beach, VA
    Re: Driveshaft support bearing write up.
    Awesome write-up dude. Very detailed and informative.
    Oct 14 2007
    Val-Belair
    Thank,s Jeff.
    Maybe just a litle pic of that bolt between the shafts. But it's fine.
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    Why not just buy a new rebuilt driveshaft that includes brand new center support bearing among other things??
    Than all you have to do is drop the old driveshaft and install the new one...
    Yea, I went through this bullshit too, and to me, this was easier than a new bearing
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    May 14 2009
    Renton, WA
    Quote Originally Posted by Reich View Post
    Thank,s Jeff.
    Can't miss it.
    Jeff
    2000 S4
    Revo w/SPS3
    ST Coilovers
    other stuff
    May 14 2009
    Renton, WA
    Quote Originally Posted by WMi_S4 View Post
    The only thing that was really a bitch was separating the shaft. And, once we figured out to use a wedge it was done in less than 5 minutes.
    I thought the bs part was having to set the parking break when tightening and loosening the driveshaft bolts. That was a pia in my opinion.
    Why spend an extra $350+ on a new driveshaft, if all you need is a $100 bearing?
    I'm a cheap bastard when it comes to such things.
    Jeff
    2000 S4
    Revo w/SPS3
    ST Coilovers
    other stuff
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 24 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    What kind of symptoms or noises did you have?
    May 16 2008
    South Texas
    You could always replace the shaft it all together with a stronger unit and save a few pounds with this..
    http://www.advancedautomotion.com/pr...products_id=43
    Feb 13 2004
    S Ă C, CĂ*
    Quote Originally Posted by scottmandu View Post
    Anyone try one of these? how safe is it to run this, i can only picture in my head the shaft droping out. Are there any joints on the ends?
    May 14 2009
    Renton, WA
    It's a solid driveshaft?
    Not sure how that works with an AWD car.
    Most folks buy rebuilt ones for $400-500 if they are doing the entire shaft.
    Jeff
    2000 S4
    Revo w/SPS3
    ST Coilovers
    other stuff
    May 16 2008
    South Texas
    Yup we have dozens in the field. The shaft is less CV joints, which can easily be transferred over from your old shaft.
    May 16 2008
    South Texas
    Quote Originally Posted by jms-4 View Post
    It's not solid but rather hollow steel high strength tube.
    Veteran Member Three Rings rarak69's Avatar
    Jul 15 2007
    Snap-On
    Pittsburgh, PA
    absolutely no reason to by a new shaft if the center support bearing goes. why pay all that when it can be fixed for $50 in parts?
    did my a4 like 4 years ago, its a bitch. but air hammer helps a lot. took 2 hours to do.
    May 16 2008
    South Texas
    I'd agree however the replacement parts are typically not the quality of the stock stuff, and with the center ujoint installed under high torque situations, the shaft will move to the point of hitting the transmission tunnel.
    Account Terminated Four Rings
    Sep 18 2009
    Andrews
    What people do not use a solid drive shaft boggles my mind..... People that say you get added vibration must be retarded seeing as these are precision balanced to 8k and about every other car has a solid drive shaft that is actually longer than ours. The reason Audi implemented a 2-piece drive shaft was due to the crash testing that found it destroyed less things. You lose so much power to the wheels with this crappy OEM setup.
    Veteran Member Three Rings Matt Danger's Avatar
    Jun 04 2007
    B5 S4
    ROC NY
    I bought a rebuilt DS for $450 + core, then saw there was a solid DS alternative. D'oh.
    770r B5S4 home built & tuned
    May 14 2009
    Renton, WA
    I've received a few questions on how to use the wedge thing.
    Here is a sketch of how I used it.
    [IMG][/IMG]
    Jeff
    2000 S4
    Revo w/SPS3
    ST Coilovers
    other stuff
    Veteran Member Three Rings Congratulati0ns's Avatar
    Nov 09 2009
    tri-state
    sweet write up man! i did mine a few months back and i used a round piece of steel and left the bolt in there and hit it...worked very well=]
    6 Speed Single Turbo S4
    Q7 TDI S-Line
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    http://www.audizine.com/forum/showth...=1#post5767341
    Feb 14 2011
    Denver
    Just want to say thanks!
    To the OP, this diy helped so much when diagnosing a bad vibration in my car during the low RPM's. For anyone who might have an issue with a vibration at low speeds, I will describe my symptoms:
    In first and second gear from 1400 RPM to 2200 RPM on either accelerating and decelerating, the car would vibrate down the center of the car as well as in the rear. Any gears above this would not replicate the vibration. After taking off the exhaust, I examined the drive shaft and it had some play in the center bearing. After taking it the drive shaft out, I found that one of the U parts connecting the two shafts, had locked out. Instead of being able to move side to side and up and down, it was only able to move side to side. This caused excessive wear on the center bearing. After replacing the shaft, all the vibrations have gone away.
    Thanks again for the tips!
    Veteran Member Four Rings amd is the best's Avatar
    Oct 05 2007
    '91 200 20v, 01 A4 2.8 PES
    Manteca, CA
    I am thinking that my driveshaft needs to be replaced/rebuilt. The car has no problems at speeds of 55 or less but go anything above 55 and the car is literally giving me a back massage. Could this be caused by anything else or do you guys think the shaft it bad?
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    8V Audi S3/RS3 Facebook Group
    Feb 14 2011
    Denver
    Do you feel it in the center of the car? Or just everywhere? When doing the research for this problem it seems that if the vibration comes on at high speeds, then it was related to wheel bearings, wheel balancing, not true or straight wheels, or a poly mount somewhere. Although it very well could be the driveshaft. If the exhaust isn't too hard to remove then just yank it and pull the heat shield and check out the shaft and bearing.
    Senior Member Three Rings ezfour's Avatar
    Apr 17 2010
    Nevada
    I also think my drive shaft bearing might be toast, 60 mph and over I get some vibration as well as definite bearing type noise when turning right at any speed.
    Senior Member Two Rings tambat's Avatar
    Sep 04 2007
    Chicago, IL
    i don't think vibrations at high speed should be blamed on a your drive shaft right away. there are other much more likely possibilities. usually high speed vibrations mean wheel is off balance (easiest fix), bad wheel bearings, bent wheel or wheels that are no longer true. i would check out all those options before jumping to replace your drive shaft.
    B5 S4 K04'd + (sold)
    can't seem to leave
    Veteran Member Four Rings Gujuhammer's Avatar
    Oct 07 2010
    02' Avant
    Florida
    Quote Originally Posted by tambat View Post
    x2
    Oct 05 2007
    Manteca, CA
    What I'm feeling is defiantly not a bad wheel bearing or out of round wheel. The vibration is way too fast to be a wheel/wheel bearing and the driveshaft does spin 4.11 times faster then the wheels. It seems as though its vibrating right in the center of the car.
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    Sep 18 2009
    Montreal
    Sorry to revive that old thread but what tool did you use to remove that 18 mm bolt ? I can't stick any wrenches in there...
    Audi A4 2001 1.8 TQM
    Custom Flash 22 psi, forge splitter valve, n75 race, Ra4 clutch kit + lightweight flywheel, H-sport sway bars f+r , Billstein + h&r.
    Custom Catback with magnaflow muffler.
    Mar 29 2011
    home
    does anyone ever use a tool to realign the shaft by holding it in a straight plane and shimming the center bearing clamp. i know audi have a proper tool for this and say its essential to get it straight in both orientations,
    Oct 05 2007
    Manteca, CA
    Quote Originally Posted by jimbo1234567 View Post
    I do. I built my own out of some angle-iron and exhaust clamps. I'll try and dig up a picture.
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    Sep 18 2009
    Montreal
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Great DIY and info OP. Thinking of replacing my center drive shaft bearing. Since I'm starting to get a little knocking sound under my armrest during acceleration or deceleration. It only happens once in a while. Anyone done the repair without using an alignment fixture for aligning the drive shaft back on? Audi recommends using an alignment fixture to put the driveshaft in place. Is it really necessary or can you bolt it back on without using the alignment fixture?
    Senior Member Three Rings Shenanigans's Avatar
    Jul 14 2009
    Saint Petersburg,FL
    i get noises and vibrations from the center/rear of the car when driving in the rain, its not wheel bearings, i assume it would be my center drive shaft support?
    Stage 2.5+
    GIAC X/ko3/ko4 hybrids/ AWE downpipes/ JHM FMIC/ Forge DV's/ greddy catback/ RS4 clutch/ Fidanza Flyhweel/ ARP / EBC red pads/ neuspeed sway bars / ST's/ Vast Meth
    07 SWB Toyota Tacoma Off Road 4x4
    Nov 09 2009
    tri-state
    Quote Originally Posted by Shenanigans View Post
    Sounds like it to me, mine made more noise in the rain for some reason as well... If it isn't your wheel bearings, more than likely it's that center bearing, especially if it has never been replaced.
    Sent from Antarctica using Quattro
    Q7 TDI S-Line
    Jul 14 2009
    Saint Petersburg,FL
    Quote Originally Posted by Congratulati0ns View Post
    I need to get this done soon, althought my S4 isnt my DD anymore, it still makes driving in the rain annoying as hell
    Stage 2.5+
