Results 1 to 24 of 24
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Tyre pressure on 225\40\18
    Anyone with some insight on what pressure I should run on my 225\4018 tyres? Avant.
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Veteran Member Four Rings CBRmatt600's Avatar
    Mar 15 2009
    2011 S4 / 2008 BMW X3
    Atlanta
    Re: Tyre pressure on 225\40\18
    What is a tyre?
    Past: 2008 S-Line A4 6MT, Brilliant Red APR Stage II
    Present: 2011 S4 6MT,Phantom Black: GIAC Tune/APR Exhaust/Strat Intake/Stasis Touring Suspension/Alu Kreuz/E-Codes/Passport Hardwire
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    The max PSI should be right on the side of the tire
    Justin
    DTM S4 Sprint Blue
    Mar 15 2009
    Atlanta
    And the manufacturer recommended pressure is always on the inside of the drivers door.
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Quote Originally Posted by CBRmatt600 View Post
    What is a tyre?
    That's what some people call it who aren't from YOUR country... Like how Canadians say colour instead of color.
    To answer the OP's question, the inflation numbers should be on the inside of the driver's door. Those numbers are the recommendation for all tire sizes as that pressure is ideal for the weight of the car to ensure the best contact patch between the tire and the road. Off the top of my head, I can't remember the numbers, but I think it's 35psi up front and 33psi in the rear.
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Nov 24 2007
    Tromsoe, Norway
    What is a tyre?
    UK = Tyre, USA = Tire
    Nov 24 2007
    Tromsoe, Norway
    Thanks for the informativ info guys.
    I know about the info on the inside of the door, but talked to the tyre dealer and he recommended me to drive with higher pressure than that. Closer to 40PSI.....Think it sounds high.
    Mar 07 2008
    Audi A4 B7
    VA
    The only time I've heard of people running 40psi is when they're at the drag strip with a lower horsepower car trying to get the tires to spin a little off the line... I would stick with the recommended pressure since like I said, it's the "best" pressure to have the "best" contact patch with the road based on the weight of the car. If you're into tweaking things and have a good feel for your car and it's handling/braking, you can try different psi's to see if you can feel the car handling differently. Just remember if your pressures are too drastically different from the recommended pressure, you chance killing gas mileage and premature wear of your tires (tyres).
    Mar 15 2009
    Atlanta
    Quote Originally Posted by redlabel81 View Post
    I seriously did not know that.
    And yeah, 40 is way high.
    Mar 07 2008
    Audi A4 B7
    VA
    You learn something new everyday! Disregard my semi dick comment in my first post...
    Mar 15 2009
    Atlanta
    Ha I already assumed you didn't realize I was being serious. I obviously knew what he was talking about but didn't know that people actually spelled it that way.
    Veteran Member Four Rings quattshot's Avatar
    Oct 27 2006
    East Ft. Lauderdale, Florida
    Anybody with any Autocross or track experience can tell yah that knowing what tire pressure is good for your conditions is an art in itself. Since tire pressure can induce under and oversteer by adding (+-) PSI in the front and back, you can actually play with your PSI from front to back. For everyday driving I would use the recommended tire pressures on the inside of your door jam as a REFERENCE. Play with it from there. REMEMBER, if you lowered your car, your camber will be thrown off a bit and the inside of your tires will wear faster. Therefore, try and keep a bit more air (PSI) in your tires to TRY and keep most of the rubber in the center of the tire in more contact to the tarmac. If you keep less air, then the inside of your tires will scrub more and wear even faster with a lowered car.
    Always remember from a cold start, once your tires come up to temperature (which could take 5+ minutes depending on what type of driving your doing), your air pressure will INCREASE by at least 3 PSI!! So, keep that in mind when filling your "COLD" tires to a MAX of 40!! You dont want your tires to SKIP over bumps, potholes, etc. You want the tires to absorb these obstacles keeping the rubber DOWN on the ground.
    Me personally, I like 32-35 psi for 18's.
    Currently in the market for an Avant or Allroad.
    2007 A4 2.0 Quattro Silver/Blk "Quattshot Edition" Too many upgrades to list.
    2000 S4 Race Spec Champion Motorsport Edition. Too many upgrades to list.
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    With all the above in mind, I have mine at 38-40 too. 40 can be a bit much, but I drive alot on the hwy and over NJ roads which suck...so sometimes 40 is more for safety then performance. Bending wheels sucks !
    Nov 24 2007
    Tromsoe, Norway
    Quote Originally Posted by quattshot View Post
    Great post. Thanks. I'm thinking I will stick with the recommended value for now and maybe add some when lowering her.
    So the recommende tyrepressure as stated inside the door is that when the tyre is warm or cold?
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Based upon a cold tyre (usually less than 1 mile / 1.6km of driving). If you can't get to a pump within approx that distance, measure the pressure before starting the car. Once at the air pump, measure pressure again and allow for the increased pressure from a warm tyre. Check the next morning that you got it right; repeat as necessary
    Nov 25 2007
    only car I have ever known was a Mk4 R32 asking to Run 40+ psi in the rear tires from the Factory!
    Deactivated Three Rings
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    What is a tyre?
    European tires are tyres. They offer better performance on European cars like Audis. That should be the first upgrade we do to our cars -- ditch the crappy tires and get tyres. Next, do the sway bar and then drop the car, etc ...
    (Just playing with ya ...)
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    I like 35 psi ... just a tad above the recommended pressures on the door jamb. BTW, the sticker pressures are the pressures that are used in the design calibrations of the car's suspension (the tire is just another spring) so you'd probably find that staying close to the spec pressure is best. Over a tad for nicer feel and better fuel economy.
    Senior Member Two Rings cecaa's Avatar
    Feb 13 2008
    2007 A4 2.oT MT S-line Ti
    Vancouver BC
    I would do 38 for 18". My 19" is on 40 psi all around.
    the sticker on the door panel actually states different psi for different tires, therefore I think the ideal psi for maximum road contact should be different depending on the diameter/width/sidewall and maybe even the brand of tires (different materials /sidewall support).
    The camber also makes difference when deciding the pressure, not big difference tho.
    Sponsored by VMR
    2007 Imola Yellow A4 2.0T S-Line Ti 6sp.
    235/35/R19 RS4 Replica. Bilstein Shocks. GIAC 93X. Rear Windows Tint. Lamin-X Smoked Tail light/Fog light. Metallic Black Rear Rings. Debadged.
    2004 Imola Yellow TT 1.8T Tip. Gone but not forgotten.
    ________________________________________
    Everyday is a gift, that's why we call it present.
    Dec 21 2008
    British Columbia
    The decal on the doorsill of my 2006 2.0t sline says 41 psi for the 235/45/18s.
    Oct 27 2006
    Definitely cold. You will be happy with 38lbs all around. Maybe 40 in the rear to try and dial out that little extra oversteer that we need to compensate for tons of Audi Understeer.
    Nov 24 2007
    Tromsoe, Norway
    ^^ Thanks mate.
    Feb 12 2004
    PA-NJ
    Quote Originally Posted by cecaa View Post
    Exactly!! I'm running 225/35/19 and 255/30/19 so the extra psi is safer...when they loose pressure and go down to 34-36 they feel too low and get squishy.
    Senior Member Two Rings DFDUB.S-Line's Avatar
    Mar 20 2009
    Texas
    35-40psi
