Results 1 to 40 of 42
    Apr 17 2009
    Ann Arbor Mi
    $1120 for Cam Adjuster Seal Repair?
    Apparently I have an oil leak on both sides of my engine. Howard Cooper Audi (in Ann Arbor Michigan) is asking for $1120 to repair the cam adjuster seals/Valve cover gaskets where the oil is coming from. Is that too price too high? What do you guys think?
    Also they're charging $450 to replace an O2 sensor that's giving me a CEL.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Re: $1120 for Cam Adjuster Seal Repair?
    run! run far away. took me 3-4 hrs to do my gaskets for the first time, and about $100 in parts for all the gaskets.
    100 + 4hr*$80hr + $25 tool = $445. I would only pay around this much.
    For the 02 sensor ripoff also.
    Thats what you get for a stealership.
    Learn to DIY, its not that difficult.
    Veteran Member Three Rings VR4-S4's Avatar
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    That's ridiculous
    B5 S4 - PJK04's Vast E85 Tuned
    452AWHP, 475AWTQ
    C7 S6 - RS7 Turbos Vast Tuned
    B8.5 A5 - GIAC Stage 1
    B8 A4 - Stock
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    if you ar enot far from needing a timming belt service do that as well, i would look for a good indi or call Vast in MI, they are worth the drive
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Jan 29 2007
    08 S4 00 S4
    MD
    Don't go to the dealer. Post in your regional forum, someone can probably help you out for far less. Those are basic DIY's.
    08 S4- Stock SOLD
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Do it yourself. That is easy work.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Registered Member Two Rings auditech79's Avatar
    Jul 18 2007
    00 A4 1.8T
    Elk Grove, CA
    The dealer will charge you a lot because the book says to remove the timing belt and cams, this of course doesn't have to be done. You only need to compress the tensioner using this tool:
    Once the tensioner is compressed you can fish out the seals using a small 90* angle pic. Takes about the same amount of labor as doing both valve cover gaskets. The tech knows this and he will most likely be done in about 45 minutes, that won't stop them from charging you 8+ hours though.
    Account Terminated Two Rings
    May 25 2007
    Stage 3 EPL 2001.5 B5S4
    Madison, WI
    Wow I just did that job on my car last week and cost me $80 in parts! I would only do $400 for that job. It is not difficult and takes around 3-4 hours and I just took my time. The biggest thing is you need to know how to roll the car so that you get the lobes on the cams to align and give you the most room to work with. It was not hard.
    If you need a tensioner compresson tool I have one I can sell you!!
    Active Member One Ring ATKS4's Avatar
    Mar 20 2007
    Detroit, MI
    Go to VAST. They're a 45 minute drive for you. Well worth it. Howard Cooper is asking way too much, even for a dealer.
    Jun 15 2009
    2007 Audi A4
    IL
    You guys make it sound so simple to do all the work your self, I just bought a Audi a4 with 16k miles, and im having some problems with my turbo keeps on cutting out on me, It might be hpfp, or cams, I have no clue what i got my self in to, I dont think i will buy another Audi again even though i love that car.
    Sep 16 2005
    Asheville, NC
    Quote Originally Posted by quickaudi07 View Post
    Shouldn't that be a warranty issue? Turbos are easy as heck to replace on an A4.
    2000 S4 - SSP tuned Stage 3
    CrtchRktRcr: You could turn it into a unicorn with a gigantic pink dildo and i'd still love a b5s4.
    Veteran Member Four Rings Yesmar's Avatar
    May 15 2009
    couple 2.7t's, and a tacoma
    Harrisburg, PA
    i just hit 60,000 im about to do this project myself all the stuff will be here tomorrow and sat. im also doing the whole timingbelt ect. at the same time. diy it will save you atleast $,$$$ take your time , its not as hard as it sounds , ive done it on a v6 passat
    Veteran Member Three Rings s4killer's Avatar
    Jul 27 2009
    audi s4 b5(sold( corolla 95 stick, jetta se, honda civic ex
    wisconsin
    hello friends I have a big problem I went to my garage and they told me I need a cam seal cost is $ 450 haora someone that I can explain it please the cam seal parts or you have not anything to seal has about this can help me understand this with photos and detailed information through
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
    Veteran Member Three Rings car's Avatar
    Feb 03 2009
    16 S6 93 SLC 91 GTI
    Harrisburg, PA
    You don't need no stinking tool! Just unbolt the tensoiner and turn to engine over till the adjuster pops up enough to slide the old gasket out and the new one in. Make sure to clean the old gasket material / sealant up and bam. Bank 2 is a little tight but just get it done.
    Make sure to replace the valve cover gaskets as well as the end caps. My main leak was my end caps, dripping right onto the manifold.
    Search for the DIY, you need to put some sealant at the corners of the cam hold downs as well.
    Here is the kit from ECS. You can get it from many places, I just choose ECS because they had everything I needed at the time.
    ECS Valve Cover and Tensioner Gasket Set
    16 S6 Prestige - Daytona Gray Pearl - Sport Package - Drivers Assistance - B&O - Black Optic - Comfort Seats - Cold Weather Package - Alcantara Headliner - Cargo Net
    Veteran Member Four Rings orttauq's Avatar
    Mar 11 2007
    8V S3
    tri state
    Quote Originally Posted by danche200 View Post
    Like it's been said here. I used to work at a dealership and we'd charge 8 hours flat rate for VC gasket/cam tensioner seal replacements on v6 VW/Audi's. Vesis/Aesis says you need to remove the cam tensioner, which of course is not true. That's where all the labor time comes from. A VW/Audi tech will have that job done in an hour.
    Now, if you can't find someone to do the job for you, you could always use this as a bargaining tool at the dealership. We've had customers do it before, and to not lose the job we cut the labor time in half.
    Senior Member Two Rings YnotS4's Avatar
    Jun 22 2008
    S4
    Chicago
    Quote Originally Posted by s4killer View Post
    GOCPT.com
    Stage 3 VAST TUNED / EV 14 injectors/ ported intake/ ARD bi pipes/ VAST meth/ h20 / AWE ICs / APR DP / AWE Twin 2 / VAST EFK /
    034 SLFW / 17Z w 300mm rear/ 2.0 CP ICM delete/ plus other stuff
    11.92 @ 122.07 with 1.6119 60ft .
    Active Member Two Rings new audi guy's Avatar
    Jan 19 2009
    Columbus, Ohio
    Jesus. I just had my dealership do a recall notice on something and they came back with this Cam Seal nonsense. They want $1500 for it! saying its a 12 hr job. ridiculous.
    Jul 28 2007
    RS5
    gta, ontario
    Quote Originally Posted by ATKS4 View Post
    YES do this save a metric shit ton of cash.
    Get to the know the guys at VAST, living that close and owning a B5 S4 you owe as much to your wallet and your S4... do it now!!
    Last edited by spa; 03-03-2010 at 02:19 PM. Reason: monkey shitting on my keyboards while typing original message
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    simple simple stuff. order a valve cover gasket kit, cam, caps, tensioner seals, and might as well do spark plugs all at once while you are in there.
    Veteran Member Three Rings DaveS4's Avatar
    Apr 12 2009
    Nova Scotia, Canada
    Where's the easy guide to do all this? The guide I or says to take the cams and tensioner
    out, but I'd rather not... I need to do all the end caps too...
    2001.5 VAST Stage3 **** Silver * 6 Speed
    2001.5 Completely Stock * Imola * Automagical
    Jun 01 2008
    Apopka, FL
    ditto, techs make $$$ based on quoted labor hours, not actual work. so if he does it in 45min and it's a 8hour quoted job, he gets the 8hours of work pay for 45minuites of acutal labor, and can then start on the next job. It's fairly easy to walk out everyday with 12-15hours worth of labor for doing 8hours of work at a dealership.
    Established Member Two Rings S/4biturbo's Avatar
    Sep 07 2009
    Albany
    I am having the same exact issue. The Shop says to just do it with the timing belt. They are charging me $1200 for full timing belt kit, valve cover gaskets, snub mount and cam adjuster seal replacement, all installed. reasonable price? Also does anyone have a DIY on the cam adjuster seal
    2005 B6 Nogaro S4, 6spd, RNSE, Custom Exhaust, More to come...*DD*
    2005 B6 S4 6Spd...APR Tune, Stratmosphere intake, Koni/H&R Springs, Magnaflow*Sold*
    2001.5 S4...MTM Stage 2 *Sold*
    1999.5 V6 MT with intake, just a daily winter beater. *Sold*
    2004 A4 1.8T usp 6MT 2.0 Stroker kit, GT2871r Elim, 550cc, Maestro 7, *Sold*
    Sep 11 2009
    NE
    Quote Originally Posted by blmlozz View Post
    Tech gets nothing extra for making the job quicker. It is the dealership being thieves. There is a reason why it is called Stealership not Stealerchanic. Pure robbery.
    Sep 11 2009
    NE
    Quote Originally Posted by S/4biturbo View Post
    That's not the same issue. You're paying $1200 for everything including $400 in parts while the OP pays the same for about 10% of what your job will take. Replacement of imebelt is very involved and includes taking off bumper, putting the whole front into service position and using specialized tools. Hardly the same as 2h (if you take your time) cover seals job.
    Veteran Member Four Rings P0234's Avatar
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    Quote Originally Posted by julex View Post
    Not sure what dealership you've worked for but the one I worked at as well as all the ones my friends worked for, everyone gets paid in "book time." The books says 8 hours, you do it in 1, you get paid for 8. Most techs were booking over 80 hours a week working 40 or less. If you didn't book 60 or more, you were either lazy or new.
    Sep 07 2009
    Albany
    No I realize that I am not getting the same thing done however, they said that I would be better off just doing the timing belt at the same time because it involved the cams being pulled (timing belt comes off) I was quoted about the same for only the cam adjuster seal Like 1k to do those seals only. I was wondering if there was a DIY somewhere on how to do the adjuster seals without pulling the cams.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Quote Originally Posted by auditech79 View Post
    And you know what the funny part is! You're going to pay them for the time to do it by the book, but they do it like we do... lift and tuck... 2hrs and they're done the car but get paid by the book.. nice huh!
    Dec 06 2007
    Calgary, AB, Canada
    S /4biturbo,
    Do you have the Bentley manual? The cams definitely don't need to come off to replace the seals. If your going to need a TB change soon, then it's not a bad deal, but if your TB still has lots of life left on it, I would just swap the seals.
    Sep 07 2009
    Albany
    Quote Originally Posted by The_Jerbel View Post
    S /4biturbo,
    Unfortunately I have yet to get the bently manual, Yes I know I am a noob when it comes to that. I was only going by what the shop was trying to tell me. It didn't sound quite right either. But yes Im at 71k so I am about due for a timing belt anyways as it is
    Sep 11 2009
    NE
    Then do the TB as well. With TB it is an "OK" price I guess.
    Here is the DIY for cam seals/plugs/cover which doesn't require screwing around with any cams:
    http://www.audiworld.com/tech/eng107.shtml
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    71k miles is a bit early for a timing belt. service interval is even 80k miles i believe
    Dec 06 2007
    Calgary, AB, Canada
    I disagree. I like to do the TB every 60k, even though the specified interval is ~74k. I've seen some belts with quite a bit of wear with much less than 74k on them. Better safe than sorry, when it comes to the TB. 71k isn't too early at all, IMO.
    Sep 11 2009
    NE
    Plus the things that fail earlier than TBs are usually water pumps and idlers... many stories of these breaking down around 60k mark out there.
    Nov 19 2012
    Philadelphia/ PA
    Hell yeah thats waaay too much! I fixed mine in private repair shop, and to change the valve cover gasket, oil change, oil filter change, and for the full synthetic oil cost me $210.
    Feb 22 2012
    cincinnati ohio
    Quote Originally Posted by S4_NE View Post
    thought vast was closed.
    Feb 22 2012
    cincinnati ohio
    each cam adjuster seal repair labor time is 2.0hrs at a dealership.the cam adjuster gasket doesnt cost more then $20each.they shouldnt be chargeing you aymore labor time for the valve gaskets since they have to remove them any ways.the valve gasket kit $45 each.so you do the math.
    Veteran Member Four Rings ratherb1's Avatar
    Jun 07 2010
    Rhode Island
    Quote Originally Posted by Audi User View Post
    Dude I think he knew this 2 years ago
    -----Romie------
    CURRENT B8.5 S4 IE TUNED
    OLD MKV GTI STAGE 2
    OLD C5-A6-2.7T-STAGE 2-SELFTUNED-ST-TSW
    Jun 07 2010
    Rhode Island
    Quote Originally Posted by greatestever1 View Post
    It is ...... Necrobump
    -----Romie------
    OLD MKV GTI STAGE 2
    Veteran Member Three Rings nJoy's Avatar
    Dec 18 2010
    C7.5 S6, B6 A4, ex 01.5 B5 S4
    Illinois (South Suburbs)
    Pfft, that's cheap!
    Audi of Orland Park, Illinois wanted over 1400 w/ parts and labor. X D
    I called them because they sent me a coupon of 15% off w/e for an Audi under 2005. Gonna do it myself lol
    MTM
    Veteran Member Three Rings MLJS4's Avatar
    Jan 06 2010
    Michigan
    Send me a pm ill hook you up with a good price
    2001.5 Stage III
