Results 1 to 40 of 72
    Sep 17 2005
    Fremont, California
    034Motorsport - 1.8T High-Flow Catalytic Converter Testing
    After seeing quite a few posts and remarks saying that there is no benefit to a high-flow cat over the stock one, we decided to do some back-to-back testing on a car that we were tuning in-house.
    We verified the functionality of the stock catalytic converter, to ensure that it wasn't clogged, rattling, or had its flow obstructed in any way.
    Here are the results of the stock catalytic converter vs. our 034Motorsport High-Flow Catalytic Converter (HFC):
    The tuning was left unchanged between the two runs.
    This vehicle passes smog with the 034Motorsport HFC, and there is no nasty hydrocarbon buildup on the back of the car from the exhaust.
    The results speak for themselves, and prove that a 034Motorsport HFC is a great alternative to a test pipe for those who want to pass smog, save the planet, seduce hippie/environmentalist chicks, etc.
    034Motorsport B5/B6 1.8T HFC Results:
    - 400 RPM quicker spool
    - 14.5 HP / 35 ft-lb Gain @ Peak
    - Peak Horsepower Gain of 31.99 HP
    - Peak Torque Gain of 35.29 lb-ft
    Veteran Member Three Rings Drew-B6's Avatar
    May 15 2008
    Syracuse, UT
    Re: 034Motorsport - 1.8T High-Flow Catalytic Converter Testing
    How much?
    Drew-
    2013 Audi S4
    Sep 07 2007
    San Francisco, CA
    Will it throw a CEL?
    Sep 17 2005
    Fremont, California
    Test Vehicle Info:
    - 2000 Audi A4 1.8T Quattro
    - GTRS Eliminator
    - ATP High-Flow Stock-Fit Manifold
    - 415cc Genesis Injectors
    - TT225 MAF
    - 034Motorsport Motronic Tuning
    - 91 Octane
    - 2.75" Milltek Exhaust
    - EVOMS FMIC
    - Stock Airbox
    - 034Motorsport Turbo Inlet Hose for Eliminator Turbo & TT225 MAF
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    will this bolt on with stock exhaust?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Drew-B6 View Post
    How much?
    $295 retail, and we have gasket kits available here: http://www.034motorsport.com/product...ducts_id=18175
    But, we will have a group buy going soon for these guys!
    Quote Originally Posted by grimlock View Post
    On the cars we've had here, it did not, but the 250-cell cat is right on the verge of keeping the ECU happy. It shouldn't, but if it does, a simple spacer for the rear O2 sensor will do the trick.
    We have O2 sensor spacers available here: http://www.034motorsport.com/product...ducts_id=18938
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by mrbacardi35 View Post
    Yes!
    Sep 07 2007
    San Francisco, CA
    Quote Originally Posted by Laszlo@034 View Post
    Nice, looking forward to it . So if were to get the rear O2 spacer, then I shouldn't need to get the CEL delete flash?
    Sep 17 2005
    Fremont, California
    Exactly.
    Time for me to get to work on setting up the group buy. Feel free to post or PM me with any questions!
    Sep 18 2006
    GB FTW!!!!
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Thanks for posting Would have been cool to throw a test pipe in the mix as well.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Sep 18 2006
    do you have pics of it installed?
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Nice info!
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by actlsub9 View Post
    Yeah, unfortunately we were a bit rushed with the comparison, but the test-pipe seems to be a time-tested, proven upgrade.
    Sure thing, I just snapped some:
    And the stock cat, just for kicks:
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    How about testing it with a stock car or a car with just ECU tuning?
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    does your cat have a c.a.r.b eo # or does it not need one because it is a direct replacement part? What cell count is the stock cat compared to the 250 of this one? I am also looking forward to the group buy!
    - Caractere - BBS - Kamei - 034 - Stasis - Hotchkis - Stern - Forge - Apikol - Revo - Podi - RNSE - Bi-Xenon - Door Blades -
    If your gunna do it.. DO IT right!
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    It sounds like a great product and I am interested in one, as a test pipe doesn't cut it for me living in California . How long do you estimate it will last on a good running engine compared to a factory cat? That is the one thing I heard about most of the high flow cats, is that you'd be lucky to get 20,000 miles out of them. Has anyone run one of these for longer than a few months/few thousand miles yet?
    Also, are you planning/do you have one for the 2 liter FSI yet?
    If I came down to see you, how long would it take to install one on my 2002 Quattro, and what would the install cost be?
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    would this be pointless on a stock b6?
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
    Apr 05 2009
    SF BayArea
    I noticed just now that in the test, you ran it on a car with a big turbo, not just a chipped car, which would of course showcase the limitations of the factory cat even more so, as it wasn't designed to flow that kind of volume. So I can see the benefits with a big turbo over the stock cat for sure, but will the results be as noticeable for cars running 100 less HP on a chipped K03?
    Aug 20 2007
    97 Jeep Wrangler
    Quote Originally Posted by A4OrlandoB6 View Post
    not really, anytime you can free up the exhaust, especially right behind the turbo, is a good thing, not to mention you are prepping for future mods.
    Apr 05 2009
    SF BayArea
    My main concern is if they are going to be a part that needs replacing on a regular basis. Its not like changing a coil pack!
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by initiala4 View Post
    We'd love to do that, perhaps we can find a local customer with a stock turbo for that. However, the opportunity arose on this car, and this data definitely indicates the amount of restriction that the stock cat creates.
    Quote Originally Posted by downhillracer View Post
    No CARB EO#, and that's a touchy thing here in CA. The nice thing is, it's hard to see that it's a HFC, and it will pass visual inspection at most smog check stations. Not sure on the cell count of the stock one; I'll look into that tomorrow, or perhaps someone else can chime in.
    Quote Originally Posted by onlyaudis View Post
    These metal cats last quite some time. The ceramic ones almost always end up melting. We have had quite a few customers running them for over a year without any issues, even on BT setups.
    We have one that is currently being tested on my B7!
    It should take about 1 hour, IIRC. Our standard labor rate is $115/hour. We also have a nice discount for local AZ members looking to install our parts. If you're still on the stock turbo, we'd love to do a free before and after dyno.
    Not at all! You'll still pick up a decent amount of low-end torque; perfect for that extra push when you're leaving stoplights, or cruising at low RPMs.
    Yes, the stock cat is still a restriction on K03s/K04s. The results would be a bit different, with a greater pickup in low-end torque, but a smaller effect on top-end HP.
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    Does it sound/smell like a test pipe? With a gb waiting in the wings, $300 seems almost worth it to upgrade. Wonder what improvements it'll show on a chipped car...hmmm...maybe time to dyno again....
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by QTC View Post
    These get rid of the stench and the annoying black hydrocarbon buildup associated with running cat-less.
    Hopefully someone local on a stock turbo can stop by for a free before and after dyno.
    Sep 17 2005
    Fremont, California
    Veteran Member Three Rings B5 SLPR's Avatar
    Dec 04 2007
    B7 S4 Avant
    So Cal/La Jolla
    I'm running a stock turbo and live in sd, willing to come up and have u throw one on my car for testing if you want, i currently have a test pipe but would be willing to see a compairason. I'm also running APR 1+ tuning for those who would want to see it with tuning on a stock turbo
    "I like to party"
    VMR, Great Wheels, Great Company http://www.velocitymotoring.com/
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    will this work on an auto??
    211,000 miles
    ||Borla||forge dv||35%||awe||k&n||autobahn hoses||awe smic||ssac||walbro 255||
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by B5 SLPR View Post
    PM replied.
    Quote Originally Posted by Turbo1A4 View Post
    Yes, it will!
    Aug 03 2008
    Philadelphia, PA
    hmm...very interested. dont think the ETA guys here would mind doing this for me! haha i'll throw this near the top of my list.. if i could just get my car back from paint!
    -Kyle
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Dave installed my test pipe - did a great job and even drove to the stealership for a gasket.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Sep 17 2005
    Fremont, California
    We now have stock turbo data!
    Many thanks to AudiRob for taking time out of his day to stop by for the install; I hope he's enjoying the drive home.
    These results surprised all of us; we were expecting 8-9 WHP / 10-15 WTQ gains. The car ended up making a ton more power everywhere!
    These are the kind of gains we'd expect to see on a test-pipe, so I con't wait to do back-to-backs on a 034Motorsport Test Pipe vs. 034Motorsport HFC.
    Test Vehicle Info:
    - B6 Audi A4 1.8T
    - Unitronic Stage 1
    - Custom Exhaust
    - Stock Downpipe
    - Stock Airbox
    Stock Turbo Test Results:
    - 150-200 RPM Faster Spool
    - Gain in Peak WHP: 13.7 WHP
    - Gain in Peak Wheel Torque: 19.7 WTQ
    - Peak Gain in WHP: 15.9 WHP
    - Peak Gain in Wheel Torque: 26.7 WTQ
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Wow!! I never would have guessed that it could make that much difference on a relatively stock setup.
    Nice product!!
    Sep 07 2007
    San Francisco, CA
    Aaargh, damn you Laszlo, now I have no excuses not to get this . GB is effective until June 15th correct?
    Sep 17 2005
    Fremont, California
    No excuses!
    And yes, the GB is in full effect until the 15th of June.
    We will try to start making them ahead of time, so you folks don't have to wait that long to receive yours.
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Do you need to buy the gasket kit or does it come with all hardware necessary for install?
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Exanimas View Post
    The gaskets and hardware are available as an additional option.
    Some people reuse their old gaskets and fasteners, but I highly recommend replacing them with new parts to ensure a hassle-free installation.
    Apr 05 2009
    SF BayArea
    That much more bottom end torque must feel almost like a performance software flash. Does the noise level of the exhaust go up considerably, or is it just more turbo sounds?
    What is the multiplication factor to convert 4 wheel HP and Torque to crank numbers?
    Sep 17 2005
    Fremont, California
    The car feels considerably faster. The noise did increase a bit, but it is in no way "loud" or "obnoxious." The test car actually sounded quite nice, which is rare for a 1.8T.
    Converting to crank HP numbers is a bit sketchy.
    Our 80TQ motor made 703WHP on 100 Octane on our dyo, and 848 CHP on an engine dyno with the same tune...
    Sooo, roughly a 17% drivetrain loss with that data.
    Assuming that calculation is correct, divide the WHP numbers from our dyno by 0.83 to estimate crank HP figures.
    Apr 05 2009
    SF BayArea
    Thanks for the info. I think I may have to get in on the group buy. My only concerns are how long the cat will last,(40,000 miles is OK, 10,000 is not) and how good a job it does at cleaning things up as far as being able to pass California smog without having to sweat it every two years. Last thing I'd need is a failed tail pipe test and a trip to a referee station. Would have been interesting to do an exhaust gas analysis before and after to see just how much more Co and HC there were compared to the OEM cat.
    Apr 05 2009
    SF BayArea
    If you use the .83 numbers, then this guys Stage 1 Unitronic with the stock cat produced only 175 HP and 210 foot pounds torque at the crank. Nowhere near the promised numbers of a stage 1 flash. Is that typical from your experience? With the high flow cat, the numbers on 91 gas are more in line with the promised gains from most of the stage 1 chip upgrades, which then comes in at 192 HP and 233 torque. Boy these cars were underpowered stock.
