Results 1 to 25 of 25
    Mar 02 2007
    Fresno, CA
    TPMS Failure warnings
    On several isolated incidents, I have had a "TPMS Failure" warning message pop up on my instrument cluster. Each time I've stopped to check the tires, with normal tire pressure readings. The warning goes away after turning the engine back on. My initial reaction was to think one (or more) sensors might be faulty, but that wouldn't explain why the failure messages are so infrequent (typically less than once a month). Has anyone else had experience with this they can share? I've heard Audi service techs can scan the sensors without removing the wheels to determine if they are faulty, but I wonder if it would find any problems if the warning is not occuring at the time.
    Veteran Member Four Rings robots_are_neon's Avatar
    Feb 16 2004
    SoCAL
    Re: TPMS Failure warnings
    dude, same thing over here I have a service appt for monday on this - soo annoying
    Same with my oil levels
    Current: B8 A4 S-Line Avant
    Previous: B7 S4
    Before that: B5 A4
    ETH
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by robots_are_neon View Post
    Please let me know what they say. My guess is a faulty TPMS sensor, but who knows.
    Veteran Member Four Rings PESAPC's Avatar
    Aug 19 2007
    C8 RS6 Avant 2025 + Durango Hellcat 2021 & Gone B7 RS4 + B8 A4 Avant
    I think you are right ... crap sensor
    B7 RS4 - JHM R-Clutch/LWFW/CP/Short Shifter + Milltek Exhaust + JHM Piggies&Tune + F/R Brembo BBK + HRE
    B8 AVANT S-Line FMIC + F Brembo BBK + BBS + STaSIS Exhaust + GIAC Tune
    BOTH Ohlins Coilovers + Rear Sway Bars + Michelin PS2 + Tint
    Veteran Member Four Rings mioStile's Avatar
    Sep 25 2006
    TPMS low tire pressure warnings pop up on the b7 s4's all the time -
    Rather than a faulty sensor, sometimes it's that the sensors are TOO GOOD. If you look in the manual, there's a way to re-set the sensor range so that there is a larger range for tire pressures to vary before alerting the sensor. If that doesn't work, make sure you check the tire pressure of the spare - that could be a little leaky and cause a warning.
    Fixed my problem and haven't had an issue since.
    Current Iggnshn: 2007 4.2L 6 speed quattro S4. Neuspeed catback. 20x8.5/20x9.5 BBS RSGT. PSS9. USC license plate. always my work in progress.[/FONT]
    AMA
    Together we can all defeat 2.0T and 2.7T crime
    Ya, I'm that guy...
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by mioStile View Post
    Thanks for your reply. Unfortunately, it's not indicating that pressure is low. Instead, it's specifically saying "TPMS Failure", which is indicated in the manual as being a problem that could caused by various reasons. One of which could be a faulty sensor. I'm just wondering how common this is and whether anyone else has been having the issue as well.
    Aug 19 2007
    I recommend changing the air in your tires ... that will fix the issue.
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by PESAPC View Post
    You're kidding, right?
    May 24 2007
    Southern California
    I'm not familiar with the b8 and how the tire pressure sensor works, but could the warning possibly be set off by the new aftermarket wheels and tires?
    Kyle
    2.0L Revo GTRS Eliminator
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by A4natomical View Post
    No. The HRE's were built to accomodate OEM TPMS sensors, which are installed using the valve stems. There is a sensor installed in each wheel. You inflate the tires to your desired pressure, then set the TPMS through the MMI so it "learns" the PSI and alerts you if one or more tires goes (25%?) below that pressure. The warning I get is different, stating "TPMS failure", meaning some kind of malfunction in the system where it is unable to function properly. In each instance, I checked the pressure of each tire and they are within allowable limits.
    Aug 19 2007
    er ... seriously kidding !! ...
    Aug 19 2007
    I have HREs on my RS4 and A4 with no issues ... you have a shit sensor ... but which one right?!!?!?
    Established Member Two Rings afouralex's Avatar
    Apr 04 2009
    LA
    I had to take my aftermarket wheels on and put the stock ones on for repairs and forgot to store the current tire pressures and a few miles later I got the "TPMS Failure" message, but I just pulled over and stored the tire pressures and it never happened again, just put the aftermarket back on, stored pressure, and no problems so far. Is "TPMS Failure" the message it's supposed to indicate when you get a flat, or would it say low tire pressure? Now i'm not sure that I got the correct message for the correct problem.
    Alex
    Owner, AudiBloooog
    Feb 16 2004
    SoCAL
    I just got my car back and MioStile was correct, they were just being too sensitive.
    As far as the oil goes, there was a faulty latch for the hood so they replaced that and ALL GRAVY!
    Previous: B7 S4
    Before that: B5 A4
    ETH
    Mar 02 2007
    Fresno, CA
    What was the warning you were getting regarding TPMS? Mine specifically said "TPMS Malfunction" not the low tire pressure warning. According to the manual, they are 2 very different issues.
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by afouralex View Post
    Same thing happened to me when I first put my HRE's on. Got the warning on first start up, stored the pressures, message went away. The message has now popped up on 3 separate occasions while driving. Two of the times it remained lit on the dash until I turned off the car, checked the tire pressure (all were fine) and restarted the car. The last time, it cleared itself within 10 seconds after appearing.
    Veteran Member Four Rings aznpxdd's Avatar
    Feb 16 2009
    2012 Alpine White BMW X1 (China)
    LA/Dongguan/Taipei
    I just got some new wheels today and on the way home, "TPMS Malfunction" popped up for me as well. Did you ever solve this problem Blake?
    -Jeff
    2009 Ibis White A4 2.0T
    Gloss Black Grille | CF Filler Plate | 19x8.5" Dark Gunmetal VMR v701's | Black Calipers | ST Coilovers
    OSIR Trunk Spoiler| H&R 5mm Spacers | 5k DS3 HID's | Luminics Fogs | VAG-Com | Silver CF Interior | K&N Intake
    Painted Front Splitter | Gloss Black Roof | Hardwired V1 | OSIR CF Rear Valence | AWE Quad Tip Exhaust
    Aug 19 2007
    did you reset the computer ... until you do, that warning will recur ... of course, you might in fact have a problem - reset the system first and see if it recurs ... check tire pressure and if one is 2-3 lbs lower than the others that will prompt TPMS to error out
    Feb 16 2009
    LA/Dongguan/Taipei
    How do I reset the computer, a VAG-COM?
    -Jeff
    Established Member Two Rings ChronoVII's Avatar
    Mar 26 2009
    2009 A4 Prestige Meteor Gray
    Phoenix, AZ
    wait.....the TPMS also keeps an eye on the pressure of spare in the trunk?
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by aznpxdd View Post
    The issue has never been fully resolved, but I hardly ever get the warning anymore. I got it last weekend for the first time in a long while, but I kept driving and it went away. Based on my research and experience, it seems to happen when one or more of the sensors loses contact with the system. In my case, the communication failure has only been temporary and goes away after either storing the current pressure through the MMI, turning the car off/on, or simply ignoring the message and continuing to drive. The most important thing to know is that the malfunction warning does not indicate low pressure in any of the tires. With brand new wheels (assuming new TPMS sensors were installed in the valve stems), you must reset the system to "learn" the new sensors through the MMI car settings menu. Hopefully this helps.
    Aug 19 2007
    Bingo
    Veteran Member Three Rings John4378's Avatar
    Mar 19 2009
    Houston, TX
    I am sure glad I came across this post this morning. Both lights came on for me this morning. A yellow low tire pressure light illuminated on the speedo, and the green TPMS failure green light on the rectangular digital display. I guess my first step is to goof around with the MMI and see what that does.
    Dearly Departed - 2008 A4 Avant 6MT S-Line w/ APR Stage 2, 034 HFC
    2006 Lotus Elise
    2005 Ducati Monster S2R
    2006 Ducati Monster 695
    2009 A4 6MT S-line w/ APR chip, AWE exhaust, AWE FMIC, Eurocode HFC
    2011 Ford Explorer - Family Swagger Wagon.
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by John4378 View Post
    FWIW, I've never gotten the low pressure warning. I'd start by checking/correcting the pressure on all tires (including the spare), re-storing current pressures through the MMI and going from there.
    Registered Member One Ring Al Fletcher's Avatar
    May 09 2012
    Miami, FL
    TPMS:
    After putting on the 19 255/35 wheels for an A5 on my Audi 2006 A6, i started to get the TPMS warning. In the car setup i can reset the Tire pressure so the computer knows what the pressure should be but that doesn't seem to work. The TPMS comes on after driving for a little while, after i reset it. Any info would help...Thanks
