Results 1 to 17 of 17
    Nov 04 2004
    Buffalo Ny
    Gas Door release
    is there one? i just got the car and couldnt find it...
    Veteran Member Four Rings bong2611's Avatar
    2000 A6 AVANT, 2004 MBZ ML350
    Newark, Ca.
    all the doors have to be unlocked to open the gas tank. If the drives door the only door unlocked the gas door won't open.
    Veteran Member Four Rings Audi_Sniper's Avatar
    01 & 04 Audi A4 1.8t quattro
    Buffalo, New York
    Re: Gas Door release
    LOL* This reminds me when I first got my A4. I looked up and down high and low on how to open the damn thing. After about ten min I got out of the car and just pushed in on the right side of the gas door and it opened .
    Like the above post says make sure your doors are unlocked....
    Bringing the Great Lakes Regions Together
    http://www.greatlakeseuros.com
    BetaAlphaTau Member # 30
    The toys:
    01 Audi A4 quattro APR stage III (Fast and tight like some of your little sisters)
    04 Audi A4 quattro (Der neue tägliche Treiber)
    Nov 04 2004
    Buffalo Ny
    ok so unlock al doors and push it in and it pops out?
    Veteran Member Four Rings white fish's Avatar
    Feb 21 2004
    05 allroad(old) 10 Q5 10 S4 13 S6
    T.O.
    I just have to unlock the drivers for the gas door but all for the trunk
    Buffalo, New York
    You got it.. If you still cant figure it out I'll swing by and show you. I think you live right down the street from me....
    The toys:
    GTA, Canada
    Right, with the drivers door unlocked it releases the lock on the gas door. You can then push the right side it letting it swing out.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    Is this just for B5's? I got my B6 and was like what no gas lock???
    789whp
    GTA, Canada
    Really? ..didn't know that.
    Lock the doors and try to open the gas door. I'd be surprised if they took that away, unless they added a switch on the inside to release it.
    Audizine
    Veteran Member Four Rings buck's Avatar
    Feb 16 2004
    '05 Tacoma & '03 Yamaha R6 & '14 Yamaha FZ-09
    Simcoe County ON, Canada
    true in my case also - I don't need all my doors unlocked
    APR 93 Octane Chip, VDO Boost Gauge, 710N, Koni C/O's, Carbonio CAI, High Flow Coconut air freshener.
    60% of the time, it works EVERY time.
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    What year do you have? When you lock the door does a metal pin come out into the gas cap area?
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Veteran Member Four Rings A4 in SC's Avatar
    Feb 16 2004
    '84 911 Carrera GP White, Burgundy cloth
    Simpsonville, SC
    Man, at least I don't feel left out. I was on my way home from Atlanta (where I bought my Avant) and stopped for gas. I felt pretty dumb calling the guy back to ask where the gas flap release was! Granted, I traded in my '00 GTI 1.8T that had a release button. I knew for sure I just couldn't find it...
    GTA, Canada
    He's got an 01.
    Same as in my case, it has the pin but it only needs to have the drivers door unlocked in order to get the gas cap open.
    My car is not setup to unlock/lock all doors with one press of the button....much nicer this way.
    Audizine
    Feb 21 2004
    T.O.
    I have a 97 and when my doors are locked the gas door is locked but as soon as I unlock my drivers door the gas door unlocks too, you can hear it, push the button again and you can hear the trunk unlocking
    Senior Member Three Rings Kodymfk's Avatar
    Jun 07 2012
    Black B6 A4 416whp e85 5 spd, Black AllRoad Static (tip)
    Lansing Michigan
    Bringing this back to life. I can't get my gas door to unlock for the life of me lol. My ccm got water damage, I thought that was the problem. I replaced it with a used one, reprogrammed it. Still no open gas door. I tore into it to check it out. It looks fine, no water or even dust has appeared to get back there. The siren and door actuator both look new still. Where do you even go about replacing these gas door lock actuator things? I couldn't find one on ecs or here used. I have an B6 A4. Thanks in advance for your help and advice.
    e85, meth, 30psi, 1.8T All the Way Check my build out! http://www.audizine.com/forum/showth...-build-on-methI'm also on the FB Kody K
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    You're in the wrong section unfortunately with this question. I'd check out the B6 section.
    For a B5, if you can't unlock the gas door for some reason, you can go in the trunk on the right side. Remove the carpeting on the side behind the tail light. You should see some vacuum lines leading down to the Central Lock Pump. I believe it's a red hard vacuum line that goes to the gas door release. Use your mouth and the vacuum line like a straw to create a vacuum and it should release the lock.
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
    Active Member Two Rings Expplucky's Avatar
    Apr 21 2013
    San Antonio
    your central locking pump must be broken, your guna need to wedge out the locking pin with a flatghead screwdriver
    99 A4 2.8 30v, K&N intake, HID kit, working on more.
