Results 1 to 15 of 15
    Veteran Member Three Rings fritzner's Avatar
    Nov 30 2006
    05 Red USP Avant 1.8T 6spd
    Pittsburgh, PA
    anyone try Rustoleum wheel coating instead of Duplicolor??..
    my local Autozone used to carry the Dulpicolor Wheel Coating that is highly recommended on here, but recently switched over to Rustoleum ..
    anyone try this stuff yet??..
    Rustoleum Wheel Coating Product Page
    i know many complained about how metallic the Duplicolor Coating is, i wonder if Rustoleum is any better??..
    >'05 Brilliant Red A4 USP Avant 1.8T 6spd
    ...REVO-II | TT injectors | RS4 sway | RS4 Pedals | podi
    ...Moven SP-10 (sportec reps) | 3.0L brakes | RNS-E | coolbox
    ...USP CLUB MEMBER #118
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    Re: anyone try Rustoleum wheel coating instead of Duplicolor??..
    Rustoleum makes some good stuff... i used the regular (non-wheel specialty) stuff on the weights on my wheel and it's still on there same as day 1
    Senior Member Two Rings abradley's Avatar
    Mar 12 2007
    02 A4 3.0 Quattro
    Virginia Beach
    i used krylon rust tough enamel http://www.krylon.com/images/product...ugh-enamel.png and it worked awesome. sprayed my stock winter wheels and held up great.
    *Selling my A4. Check the classifieds*
    two words: canvas beige
    Nov 30 2006
    Pittsburgh, PA
    thanks for the feedback guys..
    so anyone try the actual Rustoleum wheel paint yet??..
    my wheels are being blasted right now and i either need order some Duplicolor (since my local Autozone switched to Rustoleum) or just go with the Rustoleum.. it would be nice to get it locally so if i run short i can just grab another can, but everyone and their brother has used the Duplicolor with good success..
    also i am still trying to find out if the Rustoleum Silver is any less sparkly..
    thanks ..
    Veteran Member Four Rings Pufftrees's Avatar
    Mar 10 2009
    B9 RS5, B9 SQ5, B5 S4
    New Jersey
    Here is a set of 17" TSW Rims I did for a friend with a Vdub using Rustoleum. I did two coats of the gunmetal, waited a day, and 2 coats of clear coat and 2 years later, and 2 jersey winters, and they still look as good as the day I finished them. for Rustoleum!
    Cheap and fast wont be reliable.
    Reliable and cheap wont be fast.
    Reliable and fast wont be cheap.
    Feb 17 2004
    Liberty Hill, TX
    a paint job is only as good as the prep that preceded it
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Mar 10 2009
    New Jersey
    Quote Originally Posted by Matt Devo View Post
    x2...Too true
    Nov 30 2006
    Pittsburgh, PA
    they are being media blasted down to the bare aluminum right now.. i know some have recommended against it, but these guys do aluminum rims all the time and know what media and air pressure to use so they dont tear up the rims.. so de-greasing and making sure there is no dust, and prep should be very good..
    Matt, did you clear your Movens??.. many using the Duplicolor havent.. i wasnt planning on it, but maybe i will??..
    if the regular rustoleum holds up that well, i am sure the rustoleum for wheels will do at least as well.. i really like the idea of using the specific wheel stuff to help with heat and brake dust corrosion.. but limited color options.. i wanted a dark silver, but not near as dark as the graphite.. also heard the silver has too many flakes in it..
    decisions, decisions..
    Nov 30 2006
    Pittsburgh, PA
    Quote Originally Posted by Pufftrees View Post
    did you use a high-temp rustoleum, or just regular??.. that is a nice color, do you remember if it is just called gunmetal??..
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    not always true.
    i prepped and painted a set of wheels with some regular krylon gloss black paint a few years back and after one winter, they were beat up as shit.
    then stripped em the next spring. prepped them the exact same way as before and painted them with regular Rustoleum gloss black paint and they lasted that summer, winter, spring, and up until i sold it.
    i highly recomend Rustoleum
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    I agree that not all paints are created equal, but even good paint, and a good paint job will wear fast if proper prep was not done.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by fritzner View Post
    I gave up on rattle can jobs and just had them blasted/powdercoated. much happier now
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by sean1.8t View Post
    not always true.
    my point was it doesn't matter what you use if you don't prep properly, not that the paint doesn't make a difference
    Mar 10 2009
    New Jersey
    I cant remember what the paint color was, I think I still have the can in my garage, I will check when I get home from work but Im pretty sure I just picked out the color that looked most gun-metal like.
    I know that it wasnt the high temp one. I think it was actually a "for wheel painting" type of paint. I did this over 2 years ago so the memory is fuzzy. As I said I will let you know once I get home.
    Nov 30 2006
    Pittsburgh, PA
    thanks pufftrees..
    totally agree -- 1st step is proper prep (which i think i have covered), 2nd is decent paint..
