Results 1 to 27 of 27
    Registered Member Two Rings
    Mar 11 2009
    Marin County
    C5 S-Line vs Non S-line HP question
    You might say this thread has been written many times, but i couldn't figure the answer out by reviewing them all.
    Obviously the 2004 a6 s-line has 265 hp vs the 250 of the regular 2.7t c5 a6. Some said it was the ECU and some said it was some slight turbo variation (which also made it so that u cant simply bolt on K04's to an s-line).
    I would think it would just be a computer tweak to give it the extra 15 hp. My question is if after chipping, the s-line and non s-line would be at the same HP or not...
    i figured since the modest 15 hp increase of the s-line was from a computer flash, the chip would wipe out the old flash and would make the s-line and non s-line the same. However, if it is indeed a turbo difference then of course the hp's would still be different after both were chipped.
    So... to make it easy. Does the s-line still have 15 more HP after both cars are chipped?
    This question stems from determining if i really want the s-line or not, because i have found a great deal on a 03' 2.7. Besides the 15 hp, the s-line only has the spoiler, and the badges.... Because all 03's have the sport suspension, which is the same as the 04' s-line?
    Forgive me as my facts could be very off....I am trying to learn all of this in a relatively short period of time.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Re: C5 S-Line vs Non S-line HP question
    hmmm, I believe Daft has dropped knowledge on this before. I will go search it out for you NEWB
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Answers here under BD
    Answers here under Daft
    I think that should answer it......Ecu. And the Tip S-line has different turbos
    Village Idiot!!!
    (\__/)
    (")_(")
    Mar 11 2009
    Marin County
    Yeah i read those before...but there were conflicting comments... This is what Daft said and what i concluded to be true
    "All 2003-2004 A6 and allroad cars with a tiptronic transmission (S-line was only available in tip) have 703T and 704T part number turbos. For some reason they changed the shape of the turbos at that point and due to this the K04s will not bolt up the same.
    The only changes on the S-line cars are:
    15HP (via a small software change)
    RS6 trunklid spoiler
    RS4 style wheels
    S-line badges on rear door trim moldings"
    Still nobody answered the question if the non s-line and s-line would have matching hp after a chip since the s-line just has 15 hp more due to a ecu modification
    if Daft is correct...then the 2003 has the same turbos as the 2004 s-line and the 2003 still has 250...so the turbos have nothing to do with the hp.
    Senior Member Three Rings Asicks's Avatar
    Apr 01 2009
    01 allroad 2.7T 6MT/00 A6 2.7T
    Minneapolis
    I have absolutely no facts to back up the following statement......but i would be willing to bet that once both cars are chipped they will make the same power. I read through the links posted above and it sounds like the 'shape' of the turbos on the sline was changed...whatever that means. I just don't think from a business standpoint that they would put 'specially' built turbos in the sline and only gain 15hp.....that would be a little increawse for a large cost.
    Cliffnotes* without hard evidence to back up the claim i have to go with the assumption that a chipped s-line a6 and a chipped non s-line a6 would make the same amount of power.
    -Scott-
    Mods - Far from stock
    C5UNION
    Reppin' the Midwest
    http://www.audizine.com/gallery/data...fitti_wall.jpg
    Mar 11 2009
    Marin County
    Thanks for the reply...That's what i would think as well. Just curious
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    I would think you could still bolt up K04's, just swap manifolds while you're at it.
    I wonder what they would have changed on the turbos?
    Bolt patterns are fairly specific, they don't change much.
    Veteran Member Four Rings blkrhyno's Avatar
    Mar 24 2008
    2004 audi a6 2.7T 2005 Nissan
    Brooklyn, New York
    What are you guys trying to say, that I won't be able to upgrade to K04s when I'm ready?
    OEM + work in progress
    Veteran Member Four Rings 2001A6's Avatar
    Sep 17 2008
    Stuff
    St. Charles, MO.
    99% sure chipped HP is the same. I thought I read that before, someone with an S-line just had a thread about getting chipped not that long ago. Il try to look for it. There was something different I recall, but I think the ending output is the same.
    ~Matt.
    - PES Supercharged 01 A6 2.8Q
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Aug 21 2008
    09 S60 R-Design, 88 Fiero GT
    Quad Cities
    Quote Originally Posted by blkrhyno View Post
    x2 If that's the case -
    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T 6MT Modded. Allroad 2.7T 6MT.
    LI,NY
    Well another variable is that the S-Line only came in tip, which is known to shit the bed in stage 3 cars. The tip barely holds with regular chip. Any real power kills that trans.. S-Line should have come in 6MT, but because it didn't, its poop.
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me, full weight, street tires, 29+lb wheels.
    Ran an 11.8 @ 119 at MIR - Sept 2008. FIRST A6 IN THE 11's!
    Also 04 Touareg 4.2 89k with 22x10s
    Mar 24 2008
    Brooklyn, New York
    Quote Originally Posted by ENDEE666 View Post
    So you are saying that I can only go up to stage 2 and that's it?
    Apr 18 2007
    ny
    That's why before I go stage 3 I'm gonna upgrade the VB and TC.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    May 04 2007
    LI,NY
    You can do anything you want. But the tip is weak and will likely not hold up. The tp is a lot slower as a rule of thumb, even on comparably tuned cars. But the 6MT has more tuning potential and can take a lot more power.
    The A6 2.7T trans were the same as the B5 S4 trans, so search on that forum and you will find a lot more info you are looking for.
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    I thought the thing with the S-line TIP was that the turbo housings were shaped a little different? I thought is why they have different part #'s?
    Village Idiot!!!
    (\__/)
    (")_(")
    Veteran Member Three Rings BostonDriver's Avatar
    Sep 22 2004
    Massachusetts
    Quote Originally Posted by 2001A6 View Post
    I would concur with this, sicne the extra 15hp for the S-line is all about ECU programming. If you alter the program with the same aftermarket chip, I cannot see how it would be any different in the end. Just because the base-line starts our 15hp more, the aftermarket programming ekliminates that advantage, but then adds back the supplemental hp from the custom programming.
    And yes, the tip tranny is the weak link. A 6-speed 2.7T is the ultimate choice for creating the "super" A6. A guy on the AW forums in CA took his super-modded 2.7T manual and combined it with the body of a 4.2 (with some RS6 parts) and made the "ultimate" A6 track beast!
    Aug 21 2008
    Quad Cities
    Quote Originally Posted by BostonDriver View Post
    You wouldn't happen to have that link handy would ya - I'd love to check it out. Sounds like it would be one hell of a project for sure.
    Sep 22 2004
    Massachusetts
    The car itself is a 2003 A6 2.7T 6-speed sport with OCT stage IV setup, Labree exhuast, H&R coilovers, homebrew Stage III ECU, and 332 Brembos.
    Here is a pic of the car after the body conversion, absolutely the sweetest C5 out there!!! :)))
    Sep 17 2008
    Stuff
    St. Charles, MO.
    Oh my...
    the things I would do for that car...
    And I couldnt find that post. IIRC, it was an APR tune, and there were sime coding issues at first because its a dif ECU. But I believe it was all worked out and the power was the same as a regular 2.7.
    On a side note, similar but not... the early Rabbits with 150 hp, get the same finished product as the Rabbits with 170hp, according to the APR shop here in town... Know this cause a friend was just there for that deed.
    ~Matt.
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Mar 24 2008
    Brooklyn, New York
    Thanks for the info.
    Established Member Two Rings The Stig's Avatar
    Jun 19 2008
    Top Gear
    Here are quotes from some of my emails I saved. I own a 2004 A6 S-line, and had the same question.
    (These are quotes from people who work at APR.)
    “From what I understand, we apply the same calibration to the S Line as the standard 2.7T. The S line makes it's power from a mild version of a "chip" from the factory.”
    “The software is effectively a little different for the S-line vehicles, as they come with a little more power from the factory and we calibrate for the different equipment on the s-line. We determine programming not only by vehicle but by ECU part number as every ECU is a little different and the software must be custom tailored to work with that particular unit.”
    “We do not simply ADD our tuning on top of the existing factory tuning. We RECALIBRATE the ECU to work within the confines of the existing vehicle hardware and fuel octane. Therefore, it doesn't matter if your car is an S-Line that came with 15 extra hp over the typical 2.7T. It's not like as though we pile our stuff on top of this extra 15 hp.”
    Hope this helps.
    Speed has never killed anyone, suddenly becoming stationary... that's what gets you.
    May 04 2007
    LI,NY
    Quote Originally Posted by 04~A6~SLINE View Post
    That parts true, but not specific to just the S Line differences and its ECU. The 2.7T came with a few different versions of the ECU either way. There was M box, A box, K box, etc. No matter if it was an A6 (S or regular), S4, Allroad or whatever. And which "Box" you have is important to what they flash the ECU with. But that is not an S Line specific comment.
    But either way, an S line or non S line, they would make the same power once they are "chipped". The differences, and the determining factor of who wins a race or loses, would be the fact the S Line is a tip. The gear ratios are different, and its much slower. Mod beyond a certain point and the tip can no longer hang.
    And yes, the extra 15hp in the S Line is from the ECU tweak from the factory. The other differences were cosmetic, and basically all the things previously included in the "Sport Package" option from the factory. Thicker sway bars, slightly lower & stiffer springs, and sport seats.
    I think that should pretty much answer what the original poster asked...
    Veteran Member Three Rings djez016's Avatar
    Sep 01 2008
    04 toureg /94 sliverado /98 e320
    Delaware
    so can I make my stock 2.7 into an sline
    .....GAVE YOUR GIRL 4 RINGS NOW SHE AUDI.....
    http://www.cardomain.com/ride/3083923
    Aug 08 2008
    1970 Porsche 914 2.0
    Washington
    you can switch to KO4s BUT there is alot more custom piping and fitting that has to happen first.
    Jun 06 2007
    Philadelphia,PA
    Quote Originally Posted by djez016 View Post
    My co-worker has an S-line. I think you need a sports supension,rear spoiler,shark fin antennae, s-lne rims, and exposed exhaust tips. His car looks much nicer than my A6, buy my APR chip evens the playing field.
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    The sport seats were an option on the S-line, and a lot of them I've looked at don't come equipped with them. Have a look at the interior photos in this ad from my local Audi dealer... http://www.barriermotors.com/Vehicle...G=14&maxMPG=38
    Definitely NOT sport seats...
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    May 24 2009
    2004 Audi a6 s-line 2.7T
    Hutchinson, MN
    I have a 2004 a6 2.7t s-line and no I don't have sport seats. Just the generic 12way power leather. Though the rims/badging/shark fin/spoiler are nice and the tips out the back. Could anyone verify the differen suspension? that would be great to know.
    93 octane stage 1 apr tune....Vagcom stuff.....2.5inch 304stainless catback custom no restriction.....2x Forge a-line 007 DVs....Samco TBB Black
    http://ddsecurity.us
