Page 1 of 4 123 ... LastLast
Results 1 to 40 of 139
    Registered Member Two Rings
    Dec 17 2007
    A4
    calgary Ab
    S366 mounted on Topmount Tubular Mani
    Spy shot. should be running soon
    00 A4 2.1L 20v s366r tapp tuned
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: S366 mounted on Topmount Tubular Mani
    Who runs a BWs366?!?!?
    Stage 3+ RS6's
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    How much power are you expecting?
    Audi A6 2.7T : 6MT : 88K Miles : GIAC Chip : 2.5" Catback : Hotchkis F+R Sways : AWE DTS
    Dec 17 2007
    A4
    calgary Ab
    Quote Originally Posted by Stone825 View Post
    No power goals yet, I run this turbo. I use to run a Gt35r and wanted more
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    i wanna put grape jelly on it and lick it off......
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Dec 11 2006
    Boston
    Quote Originally Posted by 2L8ULUZ View Post
    Well you will certainly get it!
    Is it a singlescroll or twin? What are you running for ECU, standalone?
    Sounds like a nice setup.
    Stage 3+ RS6's
    Dec 17 2007
    A4
    calgary Ab
    Its a single. I was running the tapp tune. I own the tapp car as well. I have 034 on the new car.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Nice Dom, I replied on vortex too
    The non MK4 company is nice here, don't ya think?
    Dec 17 2007
    A4
    calgary Ab
    Quote Originally Posted by 317ssayzarc View Post
    Ya forsure. we dont need slicks to run fast times. hows your car coming along
    Oct 27 2007
    In the lab
    If I could get the standalone finally finished and reliable, that's it, it's done...
    Oct 06 2004
    Minnesota
    So what are your goals? What supporting mods? More info please!
    Slapping a huge turbo on doesn't mean much until you tell us your plan.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    HOLY FUC*!!!
    Veteran Member Three Rings michael66899's Avatar
    Oct 26 2006
    A lot of B5 S4's
    WA
    Badass my friend, I love the new BW turbos. This things gonna be a beast, care to share a more extensive parts list including motor and head work? Good luck and can't wait to see it running!
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    sexi
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    thats going to be nice cant wait to see it done.
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    nice!!!!!
    post more details on the motor
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Senior Member Three Rings b5a4gt28's Avatar
    Oct 15 2007
    97 B5 BAT A4 2.0 HTA30R, 01 STG 3 S4, 04 B6 A4
    Telford Pa
    Whats size injectors? Also Im guessing thats a custom manifold? Btw all that wiring looks fun
    A4-Full-race mani, HTA 30R, Built 2.0L, AEB head, 034 IIc, 3658's, ID1000's, JM fabrications, etc...
    S4-034 tuned, 034x intake, BW K04's, OEM RS4 Goodies, EV14's, APR bi-pipe, Apikol mounts, AWE everything else.
    Dec 17 2007
    A4
    calgary Ab
    Quote Originally Posted by b5a4gt28 View Post
    I use the run this same motor in my 97 a4 now I have a 2000 Audi that the build is going into. Some specs 2L aba Oringed 83.5 bore with Crower rods and Cp Pistons. Arp mains and rod bolts, Raceware Head studs. Stock Aeb head. waiting on some parts for it. S366R turbo. 034 EFI 1000cc injecotors and dual walbro 255 pumps. Spec stage 3+ unsprung disk 6spd S4 tranny. and list goes on
    Oct 29 2005
    10speed
    San Francisco, CA
    stock AEB head? why? I would at a minimum do the whole valvetrain but you really really need a port and some cams with that bad boy.
    Looks rediculous good luck
    - Clint
    Dec 17 2007
    A4
    calgary Ab
    Quote Originally Posted by A4Rob View Post
    Plans to be the fastest A4 100% stock trim again. like none drag tires or any weight reduction
    stock head for now, new head is in the works. still not sure what I wanna do to it, the old head had cams and it worked nice.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Nice project! Must be the skinniest o-rings ever. Didn't think there was enough room to fit them with an 83.5 bore.
    Jim
    I Do Werk.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by onemoremile View Post
    Pretty sure there is plenty of room for 83.5mm bore in a ABA and there is plenty in a 1.8 block seeing that I have been running 83.5mm for 6 years.
    Feb 15 2007
    marimont
    I can already see where this thread is going....so sad :(
    On an uppity note I hope to be running a borg warner by the end of summer so I'll be watching your thread. The high psi efficiency has me hard. Soon I'll have to go have my penis drained at the hospital.
    Forgot to mention. Love the large radial lip inlet. Gives it a better flow just as the cnc velocity stacks that are being used in the upper end intake manifolds! That is something I am going to look into creating, but with slight differences then that.
    Jul 07 2004
    socal
    Quote Originally Posted by solowb5 View Post
    I am also going BW 91-79 T4 TS, hope to have it done next month. Pretty much pushed the limits of the 35r to 600+whp, now it is time to set my sights on 700+whp and 9's.
    Oct 02 2007
    Lone Tree, Colorado
    You bored it but didnt stroke it?...
    Jul 07 2004
    socal
    Quote Originally Posted by jrock View Post
    He has a ABA block which is already 2 liter. He posted that up above.
    Oct 02 2007
    Lone Tree, Colorado
    O sry, didnt even notice that...Just did a quick skim
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    irrelevant.
    as for the OP, setup looks sick.. looking forward to the results. but why not go solid lifter so you can rev safely to 9-10k and take advantage of that turbo?
    Old: 97 30r'd A4 ---> headaches
    New: Evo IX MR ---> 354awhp/349tq and couldn't be happier
    BERNSTEINphotography
    Jul 07 2004
    socal
    Quote Originally Posted by bernB5 View Post
    irrelevant.
    He might need to at some point if he really wants to take advantage of that turbo he is using. It is basically equal in size to a GT4088, he will be lucky to hit 20psi by 5k-5500 rpm.
    Not exactly all irrelevant. I posted it because some people feel the 35r might not be enough power even though they might not have pushed the 35r all that hard. Bigger might mean more peak hp but it doesn't mean you will end up with a better power band.
    Active Member Three Rings 4inchMAF's Avatar
    Sep 04 2008
    Columbus O-high-O
    is this stock AEB head just temporary? seems like springs ,ex valves, Ti retainers, some BIG cams, and a hell of a port job would be the bare minimum to get any semblance of a power band out of this.....
    Nov 15 2007
    Audi A4
    Redding, California
    updates? up an running?
    Feb 15 2007
    marimont
    There was no irrelevency with his post. I stated I'll be watching the out come of that turbo and Mike just simply stated he was going to be running one too. Meaning to watch him also for my knowledge. On to people that understand thing. Just as the guy stated earlier that he has a head being built, but is using the stock head for now to get it running first. I will only agree to use solid lifters and huge came just bc he is making this a DRAG ONLY car.
    Nov 13 2007
    ehh, i'll agree to disagree. no big deal. he justified it in his last post.
    as for solid lifters only being appropriate because it's a drag car, i'd say it's just because of the turbo. that turbo will be a waste with a hydro-lifter head and an 8000rpm redline.
    Jul 07 2004
    socal
    There are a few 1.8t owners running hydro lifters to 9k. I would but my power peaks before 7k rpm now and I am still running mild cams. Its just not a great idea to run solids on a street driven car since that tends to mean putting plenty of miles on them and more servicing of the solid setup.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    sort of on topic, but Mike, you'd probably know this, what do the Evo/Honda guys run for lifters that allow them 10+k redlines? hydro, solid, or something else? and at what RPM they tend up upgrade their stock lifters?
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Mar 09 2004
    nw michigan.
    You have o-rings?
    Jim
    I Do Werk.
    Jul 07 2004
    socal
    You have o-rings?
    Oh I missed the fact that he mentioned having the block/head o-ringed. No mine isnt and I havent ran into a problem needing it even at 37psi.
    How much more meat is on the ABA block compared to the 058 block?
    AEB head
    83.5mm 058 block
    Mar 09 2004
    nw michigan.
    83.5mm bore is fine but it doesn't leave any room for rubber. That is what I was getting at. Head gaskets with copper rings might work but I don't know if any are available. If you've made it this far without them then they don't seem necessary.
    Jim
    I Do Werk.
    Dec 17 2007
    A4
    calgary Ab
    Quote Originally Posted by B518T View Post
    Its all ready to be started when I get back home in 2 weeks, cant wait
    Veteran Member Three Rings speeding-g60's Avatar
    May 19 2009
    PNW
    I, too, run the 366, but mine is 366XL, divided inlet T4 1.00 A/R with twin scroll manifold.... 1600's and will run it on E85. twin 044's. SM4. twin vband Tial 38's. drag only. solid lifter AEB. and on and on....
    i would post a shot or two but its not my thread.....
    now i know of another one to watch :)
    BYE BYE VWKotex....
