Results 1 to 31 of 31
    Apr 13 2009
    NS
    Question 1.8t differences
    Hey first off i tryed searcing but didnt find anything
    heres my situation i reacently just bought my first a4 from an auction , now they claimed that it had had the motor replaced with a newer model not that it matters cause i got a good deal but is there a way to tell a differce between the 150 and 180 hp versions mine has the newer valve cover but thats not really anything thanks in advance for any help
    Registered Member Two Rings mwebb's Avatar
    Jan 25 2009
    98 2.8 A4
    central pa
    Re: 1.8t differences
    read the block number? then match it
    98 A4 2.8
    1976 Jeep CJ7 with 14" suspension lift
    Apr 13 2009
    NS
    Quote Originally Posted by mwebb View Post
    ya i figured i could do that just wondering if there was another or easier way to tell that all thx tho !
    Veteran Member Three Rings spyder101's Avatar
    Jan 25 2009
    some where in the U.S.
    look for the engine code on the cylinder head...AEB, AWM, AMU....etc. That will tell what engine it is.
    Veteran Member Four Rings turbo kraut's Avatar
    Oct 30 2006
    09 pontiac vibe
    StL, Missouri
    and what yr is the car?
    the awm motor is 170hp not 180
    2001 Honda CBR929RR - modded - mine
    1992 Ford Bronco - The Beast - mine
    2009 Pontiac Vibe - stock - wifes
    1981 Suzuki GS1100 - sold
    2011 Ninja 650r - sold
    2001 Audi A4 - totaled 3/31/13
    2006 Honda CBR600RR - traded
    1982 Honda GL500 - sold
    2011 Ninja 250r - sold
    Dec 05 2007
    Look on the head of the block for the stamp on what engine it is.
    AEB: 97-99.5
    ATW: 2000
    AWM: 2001-01.5
    Jun 30 2008
    Erie, Pennsylvania
    Probably the easiest way to tell is the cam chain tensioner on the back of the head (You can check without removing any covers). The AWM engine (170hp) has VVT. On the very back of the head, you'll find the cam chain tensioner. If it has a solenoid with an electrical connector, it is an AWM. If it has no electrical connector it is the 150hp ATW or AEB.
    Here is a picture of the tensioner with VVT for the 170hp AWM (notice the black cylinder with the electrical connector):
    Here it is installed on the car (in the yellow box, you can see the electrical connector on the very end of the black solenoid):
    Here is a close-up (in the yellow box, notice the black cylinder):
    Here is a pic of the non-VVT tensioner for the 150hp AEB and ATW:
    And here it is installed on the car (notice the lack of the black cylinder):
    Both of the AWM and ATW engines are drive-by-wire (no throttle cable). If it has a throttle cable, it is the 150hp AEB. The above picture shows the throttle cable circled in red - making that an AEB engine. There is a bunch of other differences. VVT is one that is particular to the higher (stock) hp AWM.
    Active Member Four Rings CrtchRktRcr's Avatar
    Feb 25 2009
    CRF50
    Scottsdale AZ
    so mileage, year and how much did you get it for?
    I have a beautiful 99 a4 1.8t aeb quattro 5 speed.. 3400 son!
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    thats all well and good but the head will have the code stamped into it right on the front drivers side corner. all you have to do is look at the 3 letters. you are making it much more complicated then you need to.
    BTW there is a difference between early and late model AEB engines, the way to tell is the early (058 block) has an intermediate shaft to drive the oil pump and the later (06A block) doesnt.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by ghost6303 View Post
    no, they aren't all AEB motors, the only B5 to come with an 06A Block is the AWM ('01). The AEB stopped in 99.5 and was replaced by the 2000 ATW which was the 058 block and small port head
    - Clint
    Jun 30 2008
    Erie, Pennsylvania
    If I'm not mistaken, looking at the code on the head will require removing the beauty cover on the engine. Looking for the VVT solenoid just requires popping the hood.
    If no solenoid, the presence of a throttle cable will tell you if its AEB or ATW.
    Also, if the engine has been replaced, the head code may not necessarily match up. Could be using a VW head or something.
    I agree, its not much work to pull off the cover, but the OP did ask for something even easier. ;)
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    no the marking will be right where there is a "tab" of extra aluminum on the top of hte head bottom right near the coolant hard line, also known as the engine lift point
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Oct 30 2006
    B8 A4 Avant 6spd
    That doesnt mean anything, it could also be a bastard motor with an 058 block, Ive seen that before on a customers car. An AWM on a 058.
    -18 718 GTS
    Apr 13 2009
    NS
    thanks guys this makes it much easier to tell.from everything read looks like it may just be the AWM motor :D but will check her when i get home tmr.. Like i said not a big thing just curious is all as i wont be modding for a few months due to school debt and i don't know why i put 180 ive done enough research to know that . Anyways learning a lot and hope to have my own build thread up here soon enough
    Apr 13 2009
    NS
    Quote Originally Posted by CrtchRktRcr View Post
    Mines a 1.8t 5speed just like yours quattro also .. 3000 cdn
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by spyder101 View Post
    Actually thats the code for the head not the engine. Best way to tell what block is in the car is to read the code on the block itself. All of the heads fit on all of the blocks so if the shop only replaced the short block with a newer short block it could still have the old head on it.
    He might be able to tell what block it has by looking for the water pump. IIRC they are different on the 058 block vs the 06a block.
    AEB has a throttle cable, the ATW is dbw.
    Feb 25 2009
    CRF50
    Scottsdale AZ
    Quote Originally Posted by B5_t View Post
    hell yes.. screamin deal.. Mine has 150k which sucks.. but runs perfect and is silver with silver leather.. clutch is solid, 6disc changer, everythings solid.. i'm a happy camper. oh and it's sport edition.. here's a tip. if you're gonna drop it.. do NOT get sport springs! get the race.. i got a set not thinking.. didn't do shit. If your's isn't the sport model I will sell you my h&r's for super cheap. pm me if you want them.
    Apr 13 2009
    NS
    thanks man sounds like u got a good one yourself i mean once i add taxes and shit its over the 3500 you got yours for but oh ya was just doin some cleaning of the wheels and noticed also has a full borla exaust too hehe . So that made my day and ya i love the car too no leather for me but has got special edition cltoh seats in it. thanks for the tip am have read that same thing before , going to drop it eventually just have to decide which type and how low i want to if i decide to due to the fun winters up here and it being my DD
    Dec 14 2006
    Halifax, NS, Canada
    you post on custom?
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Apr 13 2009
    NS
    Quote Originally Posted by Squarrl View Post
    you post on custom?
    ya just signed up there not to long ago just kinda browsed the site before this and am just learning everything i can bout the 1.8t's and the new audi but gotta say i love everything bout it so far :) .. i take it your a custom mamber yourself ?
    Dec 14 2006
    Halifax, NS, Canada
    Yah same user name.... car is in the classified there going on the cruse?
    NOW DEAD :(
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    he could still have the k03s on either head block combo.
    boost gauge will tell you which you have.
    Feb 27 2005
    North Wales, PA
    the awm will not drop right into a car that came with an aeb. Water pump, accessories, and plumbling are all slightly different. its doable, but why bother? you won't gain 20 hp with out the awm ecu.
    Jul 07 2004
    socal
    Quote Originally Posted by Poopie View Post
    Sure he will, he just needs a chip.
    Apr 13 2009
    NS
    ah gotcha very nice good luck with the sale...what are you looking to replace it with .. and cruse? ill have to look into that one
    Apr 13 2009
    NS
    Dont worry guys i was wrong anyways still have AEB that they replaced guess i was just hoping fr that little extra
    Jul 07 2004
    socal
    Extra what? The 058 and 06A blocks make the same power. The 2001+ cars just made more power because the stock tuning ran more boost (.8 bar vs .6 bar). Once they were chipped at the same boost they made the same power. So the 150 hp vs 170 hp had nothing to do with the actual block.
    Apr 13 2009
    NS
    Wow well dont i feel like an idiot lol .. guess i shoulda read more into that one i thought they changed something to do with the engine itself
    Veteran Member Four Rings JPJ2007's Avatar
    Apr 15 2009
    Middle TN
    I have a 98.5 A4 1.8T sport package and my engine says ATW right on the head where
    the extra tab is...
    Does this mean mine is swapped????
    Jul 07 2004
    socal
    Quote Originally Posted by JPJ2007 View Post
    the extra tab is...
    That tab is just for the head which could have been swapped. To check the block you need to check the passenger side of the block near cylinder #2 to see which block you have in the car. The person you got the car from could have had the timing belt snap and just threw in any used head they could find and did not there was a diffference.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    They did, smaller ports and weaker rods. The AEB is the best of the stock 1.8t engines.
    Jim
    I Do Werk.
