Results 1 to 11 of 11
    Veteran Member Four Rings the_pirate's Avatar
    Apr 08 2008
    Houston
    Reclaimed water spots on a black car :(
    I tried washing them off, clay baring them off, and waxing them off. They won't go away. They are all over my hood what should I do??
    I also have fine swirls on my trunk and roof, you can only see it at certain angles and when the sunlight hits directly which is pretty much all the time here in Florida. Once again the clay bar and waxing didn't help...
    Hood before:
    Hood after claying and waxing:
    Sorry for the cell pictures my digital is broken and if you guys can't see the spots I'll take better pictures in the sun tomorrow.
    History:
    2001 A4 1.8t manual swapped
    2007 GMC Sierra ext cab
    2002 Chevy Tahoe Z71
    2009 Audi A4 Avant - current daily
    Veteran Member Three Rings barkerd427's Avatar
    Oct 04 2006
    2007 Audi A4 & a honda
    Princeton, NC
    Re: Reclaimed water spots on a black car :(
    I am having the same problem. I have been able to reduce them quite a bit with meguiars paint cleaner and paint polish, but they are still there. The swirls were pretty much all eliminated with the cleaner and polish though. If anyone has a way to get these spots off we would both like to know. I also have spots on my sunroof and windows that won't come off.
    2007 A4 2.0T S-Line Quattro / Deep Sea Blue / Black Leather Interior / Nav / Heated front seats / Xenon head lamps / APR Snub Mount / RS4 Pedal Set / RS4 brushed aluminum grille / RS4 rear sway bar / RS4 parking brake handle / Xenon match interior lighting / SOON Custom fog light grilles with S6 LEDs and RS4 mesh and brushed aluminum trim, just need to find the trim
    Sep 19 2006
    Orange County
    you need acid to dissolves the minerals. make sure to neutralize the acid with a good auto shampoo and polish/wax as normal
    Veteran Member Four Rings Obvis07's Avatar
    Sep 26 2007
    2007 Audi A4
    Irvine, California
    whoa whoa whoa!!! acid? can u give us a name of a product and soi dont get some crazy harmful acid lol thanks
    Enjoy Life...
    Audi A4 2.0T FWD
    Current Mods:S4 DTM Edition Front Bumper, Black Grill, Black Filler Panel, Custom V2 LED (fly300kts), Iforged RS Equips, Falken FK452, H&R Spacers 5mm & 8mm, Stasis SS, Tint (35%, 5%), LED Interior, Ecode Testpipe, Magnaflow Exhaust
    No more MODs
    Veteran Member Three Rings casuso's Avatar
    Sep 19 2006
    Mexico
    I wouldnt use any acid on my paint. Polish your paint, but use a real polish (Meguiars step 2 is not a "real" polish). I use meguiars #83 in my paint with the porter cable and a polishing foam, gets rid of water drops. If one pass does not achieve what you are looking for, then try a second and maybe a third.
    Meguiars states that Scratch X used by hand can help with water spots, may be you can give it a try.
    And remeber something, wax toyr car to avoid water spots. I do it once a month and has given me great results.
    A4 B9 Tango Red Sline FWD
    Apr 08 2008
    Houston
    Thanks man. I actually have some meg. scratch X in the garage. I used some kind of meg. paste? It worked great on the rest of the car but the swirls and water spots remained....
    History:
    Sep 19 2006
    Orange County
    You do not want to polish water spots as the mineral deposits become trapped in the buffing pad and the grit is rubbed into your paint. They need to be removed with acid then follow with your polish and wax.
    Senior Member Three Rings snowbird's Avatar
    Nov 20 2007
    '04 S4, '11 Q5, '90 Corrado, '96 911 C4S
    Toronto ON
    vinegar is an acid. try it on a spot to see if it works. Otherwise, if you've washed and clayed, I'd move to a proper polish.
    Veteran Member Three Rings billyblooshoes's Avatar
    Feb 15 2006
    1997 A4 1.8TQ, 2008 BMP GTI
    Doylestown, PA
    it depends what the spots are exactly. they could be water spot "etching" in the clearcoat which is caused by the minerals and acid content of rain. they actually etch little spots in your clearcoat where the drops where. this can be corrected by simple machine polishing.
    Precision Detailing
    Automotive Appearance Specialists
    Bucks County's Finest Detailing Services.
    {Laser Red B5 A4 1.8TQ}
    ++FOR SALE++
    2008 VDub GTI 6MT
    boostaholics anonymous member #1.
    Veteran Member Four Rings fusionx's Avatar
    May 16 2008
    07 A3 2.0T
    Socal / Boston
    I heard vinegar works wonders, my friend did it and it worked for him
    07 A3 2.0T S-line - REVO stage 2 - GIAC DSG Flash - AWE downpipe - Custom staggered quad-tip exhaust - H & R springs - H & R sway bar - Neuspeed CAI - fog housing LEDs - VMR boost gauge - JL 12'' Sub w/ Precision Power Amp
    Instagram: @superseany
    CanyonRacerMotorsports
    Project Matte Black: COMPLETE
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    two thousand two audi a-four quattro five speed
