Results 1 to 8 of 8
    Feb 02 2009
    2002 Stage 2 Turbo'd Ecotec Cavalier
    Lehighton
    Audi A4 1.8t Transmission Fluid
    So, as many of you might have read, i f'kd up when doing an oil change and accidently drained my transmission fluid. According to numerous of sources, i need a special tool to be able to fill the fluid up, so i was looking online and came across a hole setup kit from BLAUfergnügen! Inc and i was wondering how many of you guys ever used this kit and how it worked. How was the special tool aswell?
    Feb 02 2009
    Lehighton
    Re: Audi A4 1.8t Transmission Fluid
    http://www.blauparts.com/proddetail....od=F2A1007%2DA
    that is the kit that im looking at. L&T said they would charge me like 250 ish for everything, but i also have to tow it there. Trying to stay a little lower on the output of cash because im buying a set of rims this week. Let me know what you guys think orhave heard.
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    that should work for you.
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Dec 05 2007
    Hmmmm, you drained the transmission fluid without the special tool bit? It is the other way around. You need the tool to drain the fluid and an allen socket to remove the fill plug (can not recall what size though). What year is your car? And you don't need a special tool to refill your tranny fluid, just a suction pump (can be found at an auto store for no more than $10). I found it easier to place all the fluid needed into an empty gallon water carton and fill from that.
    Sep 07 2009
    Colorado
    where is the fill plug located and how do you fill it and what is needed?
    Oh yea! 2004 A4 1.8T
    Sep 07 2009
    Colorado
    I need help I accidently drained the transmission fluid while doing an oil change, where is the refill plug located and what is needed to refill the transmission, 2004 A4 1.8T
    Aug 31 2009
    '97 A4 2.8QM, '04 allroad 2.7T tiptronic, '99 F350 V10.
    VA
    Its a 17mm hex key (allen), you can get it in a set from harbor freight for $9.99 right now.
    Senior Member Three Rings JK35's Avatar
    Apr 08 2008
    97 B5 TQM
    SW Florida
    16mm security 12 point triple square. Snap-On actually has these sockets on CLEARANCE! I bought one for $10 off their site a couple weeks ago.
    I just gotta know, how the ---- do you dump your transmission oil while attempting to change your oil?
    -and not just the OP, it sounds as though he isn't the only one!
    Rarely would I ever suggest that anyone should take their vehicle to a mechanic rather than turning wrenches themselves, but if you don't know the difference between an engine and a transmission...
    the least you can do is educate yourself.
    (Hmmm.. I have NO FRIGGIN CLUE what this is, but I'm going to disassemble it anyway! ah! fluid is pouring out, I wonder if this is where the blinker fluid goes?)
    -wow
