Results 1 to 3 of 3
    Veteran Member Three Rings fatezero's Avatar
    Feb 12 2004
    Orange County, CA
    Climatronic Codes - Accessing On-Board Diagnostic codes
    Well, I was digging around today in the B6/B7 S4 Forum and ran across a thread about putting the S4 Logo on their display:
    http://www.audizine.com/forum/showthread.php?t=276151
    For some reason, I was reading into the thread and ran by a post that Keith@APR put up about being able to read various things like RPM, Coolant Temp, Oilt Temp, etc... off the Climate Control.
    I have never heard of this in my 6 years of owning a B5, and I do not recall ever reading anything about this in the past...so sorry if this is a repost.
    Anyways, I did some digging and came across the following info:
    http://www.passatworld.com/forums/sh...ad.php?t=92981
    http://tech.bentleypublishers.com/se...limatronic.pdf
    http://www.youtube.com/watch?v=gU6aiySTHpU
    http://www.audiworld.com/tech/int5.shtml
    None of the links pertain to the B5 S4 exactly, however I tried it on my car and it worked.
    Here is the process:
    Press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
    After playing with it a little bit today, here are the codes that I came up with that are of any use:
    17 – Speed in KPH
    20 – Volts – Alternator?
    27 – RPM
    46 – Outside Temp Filtered in C
    49 – Coolant Temp in C
    51 – Engine Temp in C? Maybe oil temp?
    Again, sorry if its a repost but I searched the forums in the S4 section and did not see anything so I thought I would share.
    2021 C8 RS6
    2001 S4 Avant 3L Tial 770
    2004 Allroad 6spd EPL Stg 3 SOLD
    2001.5 S4 Avant AWE/GIAC Stg 3 SOLD
    2011 S4 6spd Suzuka Grey Pearl with GIAC Stg 1 SOLD
    2006 S4 Avant SOLD
    2001.5 A4 Avant K04/Jeff Moss Hammer File SOLD
    2001 Porsche 996 Turbo - SOLD
    2001.5 S4 AMS Stg 3 - SOLD
    Feb 12 2004
    Orange County, CA
    Re: Climatronic Codes - Accessing On-Board Diagnostic codes
    BTW, here is a list of all the codes. Most of these should be correct for the US B5:
    http://www.vwclubcroatia.com/forums/...hp?t19539.html
    2021 C8 RS6
    2006 S4 Avant SOLD
    Forum Moderator Four Rings
    Apr 16 2005
    Pearl City, Hawaii
    Yea it's been posted before many eons ago.
    Good information to know.
    B5S4/A3S3RS3/Hawaii Forum Moderator - PM Comments/Concerns
    18 Daytona Gray Pearl S3
    00 Laser Red S4 (Sold )
    VAST Performance | BLOUCH | AWE | EvolutionRacewerks | Volk Racing | Vogtland | STaSIS/Alcon | JHM Motorsports | RS4 OEM
