Results 1 to 7 of 7
    Veteran Member Four Rings gearhead1186's Avatar
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    ABS/ESP/AirBag Light after removing seat.
    I went to the track last weekend and took out my rear and front passenger seat. I unplugged the 3 plugs that were under the front passenger seat.
    Airbag light was obviously on when I had the seat out. Now, after putting the seat back in and plugging everything back, the ABS, ESP and AirBag light stay lit.. any ideas?
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    Re: ABS/ESP/AirBag Light after removing seat.
    an update... airbag light comes on right when the car is started... after a couple min of driving the ESP and ABS light join the party..
    i heard i need a VAG to reset the airbag light...
    Veteran Member Four Rings SLC_S4's Avatar
    Jul 15 2007
    2001.5 S4
    Utah
    I just removed my steering wheel and after reinstalling have this same problem....airbag light on immediately and abs/tc lights on after I start driving. I'm going to try to reset with vag-com.....but if that doesn't work, any ideas?
    -Seth
    APR Stage 3 - APR Stealth exhaust - APR downpipes - APR Bipipe - APR snub mount - AWE side mount intercoolers - AWE LWFW - RS4 clutch - ITG panel filter - JHM Shifter - Startup Racing Vogtland GT coilovers - Stern adjustable control arms - Fiber Images vented carbon fiber hood - Fiber Images carbon fiber fenders - Recaro Style Topline seats - A bunch of other stuff I can't remember
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    ex B8.5 SQ5, ex 8V S3, ex 8P A3 VR6, ex B5 STK S4
    Norcal
    it will reset just fine with VAGCOM. anytime an ABS sensor gets unplugged, even for a second, it must be cleared with VAGCOM.
    The Best Things in Life Are Free... Or Heavily Discounted!
    Jul 15 2007
    2001.5 S4
    Utah
    Ok, just cleared the codes with vag-com. The airbag goes away, but as soon as I start driving, the ABS/ESP lights come back. The code I get is 00778 - Steering Angle Sensor (G85) 37-00 - Faulty
    -Seth
    Senior Member Two Rings S4ilorJerry's's Avatar
    Jan 02 2009
    01 B5 S4 Sedan; 1995 Euro-spec VW Golf III
    Stuttgart, Germany
    Quote Originally Posted by SLC_S4 View Post
    you probably need to re-calibrate your Steering Angle Sensor:
    Link vvv
    http://www.ross-tech.com/vag-com/car...ringangle.html
    '01 B5 S4||RSK-04's|ER Intercooler's|Milltek 3" exhaust|Piggie pipe's|ECS pulley's|710n's|JHM MBC|AWE V2 Boost Gauge|VAST stage 2 clutch|Stern snub & diff mount's|034 Engine & Trans mounts|AWE DTS w/poly mount|JHM SS & Knob|JHM linkage|H&R CO's|
    Sep 09 2013
    ontario canada
    sorry for raising the dead, but if you were to disconnect the battery first, and only reconnect it after everything has been reinstalled, will it still need to be reset?
