Results 1 to 17 of 17
    Registered Member Two Rings
    Dec 15 2008
    Honda Prelude, NSX, B6 A4 USP
    Aurora, CO
    Where does the K04 come from?
    A couple of questions here, first of all, what car does the K04 come from, and why do I only have a K03?
    I have heard that they are the same size turbine, but the blades are more aggressive on the K04, is that true?
    Also, from what I have found, the stage 1+ ecu and bigger fuel injectors delivers roughly the same amount of power as a K04 setup, just 10 or 15 hp & ft-lbs less.
    2005 Audi A4 Ultra Sport
    1991 Acura NSX
    1997 Honda Prelude
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    Re: Where does the K04 come from?
    K04's are made by Borg Warner same company that makes our stock K03's, you can source them just as you would any other aftermarket turbo. The turbo is exactly the same externally but the blade pitch is infact more aggressive.
    Horsepower is about what you stated above but there is more torque.
    789whp
    Established Member Two Rings Syrus5o's Avatar
    Aug 23 2008
    b5s4 stgIII
    Greenwich Ct / Albany Ny
    Ko4s can be found in the TT, b5 rs4 and the c5 rs6 (which everone was the v8biturbo) There are a few different variations in each of those ko4s some make more power than others.
    Forum Moderator Four Rings docurley's Avatar
    UK London
    Quote Originally Posted by Syrus5o View Post
    But on the the aftermarket K04-15 will fit the A4.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Feb 23 2009
    2018 Tiguan (SOON)
    York, PA
    I think it comes from a stork.
    As far as power, you get more HP, not more Torque. It doesn't really boost more (unless you want it to), it just holds boost longer... a K03S might die off at 4.5-5k (sorta made those numbers up), but a K04 will hold it. I've never gone past maybe 6.5k with my K04, but it holds it at least that long. Thus, all the extra power is at the top end - meaning more HP.
    At least, from what I know about these things and my own first hand experience, I think that's right =P
    Aug 23 2008
    b5s4 stgIII
    I considered a K04-15 for my gti years ago, I thought it was supposed to give about 10-15 more hp and 25-30 more lb/ft than my ko3s. Possibly even more tq than that with good tuning. I ended up going with a 2871r. oh well
    A lot of misinformation here...
    Our A4 (longitudinal) uses a K04-015, it is not found on any OEM Audi or VW applications, the turbos are made by Borg-Warner, which is a company that bought up both KKK turbo and Schweitzer turbo.
    The K04-001 is the OEM turbo used on the Audi TT225 and S3 (transverse motors).
    Be very careful sourcing your K04-015 right now as there are many Chinese knock-offs floating around right now.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    k04-015 was used on the eurospec TDI golfs.
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Guess again, the PD150 golf is transverse and they used a Garrett variable vane turbo p/n 038 145 535 E
    UK London
    Quote Originally Posted by Greg@DTH View Post
    They also use the K04-023
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Well you see, when a daddy turbo loves a mommy turbo very much, sometimes they make a baby turbo...
    -Darrick
    the funniest thing is that is what I was thinking when I saw thew thread intro
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    Germany!
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    UK London
    Quote Originally Posted by davidlizard View Post
    Germany!
    Funny that because it's cheaper to buy them from the US then by them here in the UK
    Dec 15 2008
    Aurora, CO
    Thanks for the info guys. You sure haven't made the K04 sound like the obvious choice for me.
    I was thinking of doing a Unitronic stage 2 setup with 386cc injectors and a dual side mount intercooler setup, and just letting my humble K03 blow all that it can blow.
    1991 Acura NSX
    1997 Honda Prelude
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    [QUOTE=Greg@DTH;3587254]
    QUOTE]
    No, K04-02X for 225hp motors (TT, S3, Cupra R)
    i would guess the K02-001 was used on the 210hp Leon, but i'm having trouble backing this up, in fact i'm finding forum posts that says ALL of the 210/225 models used the -020/021/022/023 turbos (020 and 023 being "unsilenced")
    ∴ i am probably wrong in my assumption
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Mar 29 2005
    Acura MDX
    New England
    Quote Originally Posted by hlgladiator View Post
    nope, not true
    low end torque of my K04-15 set up was 85 ft/lb more than 1+,
    (tho this is comparing K04-15/miltek HFC and exhaust to 1+ and DSMIC only)
    tho at the upper RPM's it was more like 25 ft/lb
    see below
    '12 Golf .:R /
