Results 1 to 12 of 12
    Registered Member Two Rings
    Mar 28 2009
    05 M5,00 S4, 03 Boxster,99 z24
    detroit
    Mobil 1 synthetic ATF instead of CHF11S?
    Read this somewhere online. Is this a safe substitute? $29 for a quart of CHF11s really sux
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Mobil 1 synthetic ATF instead of CHF11S?
    I run synthetic ATF without issue. You can't just dump it in..This was with a new pump and complete flush.
    08 S4- Stock SOLD
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    I was told by my trans shop to only use the oem audi fluid in the TIP trans. This was after my rebuild. For the standard alot of peopel run differnt stuff, try a search or call a couple of shops/tuners.
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by S4_NE View Post
    He's talking about using Mobil1 ATF as a substitute for Pentosin CHF11S..I think..
    08 S4- Stock SOLD
    Mar 28 2009
    detroit
    yes. A fellow VW fanatic told me this was a safe alternative, he runs it in all his V dubs. Couldn't really find anything on it online.
    Is it safe to use as long as the system is completel flushed with synthetic ATF?
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by nogarobluebeast View Post
    Like I said, I run it, a few others I know do too. I have no leaks and no issues in 2+ years.
    08 S4- Stock SOLD
    Senior Member Three Rings lonestar22's Avatar
    Aug 19 2008
    DFW
    my tranny shop threw Pennzoil Synthetic ATF in my car when they installed the new tranny. its brand new so it shouldnt have any getting used to the fluid to do since its all its ever known. i even looked it up and the pennzoil stuff meets all the audi requirements
    SGM 330i 6MT/RD PLATE LIGHTS/RES DELETE
    STAGE 1 B5 S4, CAN YOU SAY SLAMMED?
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by lonestar22 View Post
    We're talking synthetic ATF in power steering systems here. Nothing to do with automatic transmissions.
    08 S4- Stock SOLD
    Aug 19 2008
    DFW
    Quote Originally Posted by mholme View Post
    thats what i thought until i started seeing people talking about ATF. ive only use 11S in my car though. shits expensive
    Jan 29 2007
    08 S4 00 S4
    MD
    That's why I switched. Audi hasn't made a non leaking power steering system in over 25 years, I don't see them starting anytime soon. I switched to Mobil1 along with a new pump and haven't had to top it off yet.
    08 S4- Stock SOLD
    Mar 28 2009
    detroit
    I think i'll go drain my whole system then. I just added it in, there wasn't really much of the original left anyways. Do i need to remove and clean the entire pump from the chf11s before i switch to synth ATF?
    Jan 29 2007
    08 S4 00 S4
    MD
    You probably shouldn't have just added it. I would do a thorough flush and start fresh.
    08 S4- Stock SOLD
