Results 1 to 12 of 12
    Mar 20 2009
    ATL, GA
    Door puddle light problem.. how serious?
    Hi, I think im in a trouble.
    I was changing my interior lights to LEDs,
    Everything went fine but when I was changing the puddle light on the passenger door, it all happened..
    I pulled it out from the harness and changed the bulb and put it back in just like i did on other doors. But then it won't turn on.. I flipped the bulb 180degress still it won't work. Moreover, the red light on the door (another light that is turned on when the door is open) stopped working as well..
    I guess i accidentaly broke wires or something..?
    I have no clue what i did.. or what went wrong.. and I am worried..
    Should i take it to the dealership or a bodyshop? Is it covered under warranty..?
    will it be expansive to get it fixed?
    Man, im worried.. help me..
    Veteran Member Four Rings Erocko's Avatar
    Feb 16 2008
    Honolulu, HI
    Re: Door puddle light problem.. how serious?
    Check if the red light on the edge of the door is out. I had the same thing happen on my front passenger door. I kept trying bulbs. Took a while, and a lot of different bulbs, to realize that the red bulb was out. I swapped in one of the other old wedge bulbs to replace the burnt one and it worked
    You can only use one led in each door. The red has to stay a normal bulb. System freaks out or something because of the low power draw. Ideas about it on here somewhere.
    Current: 2019 B9 A4 Quattro
    Former: 2016 8V A3 Quattro, 2011 Mk6 GTI DSG 4-door, 2005.5 B7 A4 2.0T FWD CVT
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    put the regular bulbs back in and if it doesnt work then check the fuse. If its does work then your led bulbs might be bad
    Mar 20 2009
    ATL, GA
    even when i put the regular bulb back in, it won't work..
    how do i check the fuse by the way..?
    i am NOOB so..
    Mar 20 2009
    ATL, GA
    and i didnt change the bulb inthe red light..
    only the puddle on the bottom..
    can i possibly break the wires or somethign while pulling the cover from the harness.??
    Veteran Member Three Rings A4RingPimp's Avatar
    May 24 2008
    DG '06 A4/ '08 Land Rover LR2
    On a peninsula
    check your fuses
    U shouldn't be modding if u don't know how to check a fuse
    Have you ever seen the movie...
    The Secret?
    This guy is amazing!
    Six Minutes Can Change Your Life! Find Out How.
    http://store.sixminutestosuccess.com/?aid=590822
    Mar 20 2009
    ATL, GA
    sorry i am a noob..
    now i know how to check the fuses..
    i will do it when i get back home
    but is it possible to blow a fuse while changing lights?
    and if a fuse is blown.. is it easy to replace it?
    Mar 20 2009
    ATL, GA
    hey.. i just checked the fuse and it seems it is alright..
    it seems like driver and passenger door share the same fuse and driver's door is obviously working too..
    what is the problem here...
    Veteran Member Four Rings harryd14's Avatar
    Jun 30 2008
    Atlanta, Ga / Norwich, England
    i am sure it wouldnt be expensive to fix, i would take it to either the dealership or any automotive install place that have an experience with electrical installs (i.e. sound systems or the likes)
    A4 2.0Tq 6spd - Dolphin Grey
    AWE Exhaust - V708 18x8.5 - Dynavin Navi - Carbonio CAI - Blacked Out Grill - Retrofit Bi-Xenons - Passport SRX
    Smoked Reflectors - 7500k Fogs - LED city lights - CF rear lip spoiler - Tint
    Mar 20 2009
    ATL, GA
    thanks..
    i guess i will have to take it to the dealership..
    May 28 2008
    ft laud
    did you fix it. i have the same problem too. but, my front and back passenger side door lights dont work... i check the fuse and its good. also, check the blubs and they are good too. any info would help thanks...
    Veteran Member Four Rings dblock110's Avatar
    Apr 11 2009
    usa
    this happened to me installing my LED's too
    but its not that they didnt work, its just they went out (as normal)
    try closing, locking, unlocking, opening, that did it for me
