Results 1 to 33 of 33
    Veteran Member Three Rings Dakine17's Avatar
    Mar 29 2009
    '13 Iceberg FJ Cruiser, '05 Scion TC
    San Diego/CA
    DIY: Fix Center Console Fading Buttons
    Hey guys i started searching for ways to fix the fading buttons on my + and - and other stuff around the center console. (pics courtesy of kwimberly). so i went from this...
    then bought this... (MATCHES PERFECTLY WHEN DRIED!)
    Duplicolor scratch and fix 2in 1
    Universal Flat Black
    NG SF 104
    and ended up with this...
    for some reason u can really notice the difference on the -
    not the best, but you get the picture
    the whole portion of the button, somewhat noticeable, was all scuffed
    Sort of noticeable where you grab
    Not the average diy but the parts i used were...
    - damaged fading buttons
    - duplicolor flat black touch up paint
    - and a toothpick (for those tiny detailed spots)
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    Re: DIY: Fix Center Console Fading Buttons
    What color code is the pen exactly or is it primer? Thanks.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
    Account Terminated Two Rings
    Feb 22 2009
    WI
    what is the paint number on that bottle you used? i see TY sumin.
    Senior Member Three Rings Grenade's Avatar
    Aug 10 2005
    04 USP
    Las Vegas
    1C6 Toyota
    Graphite Grey
    USP CLUB MEMBER #686
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    c'mon macro pics haha
    Mar 29 2009
    San Diego/CA
    NG SF 104
    Senior Member Three Rings Boston_USP_327's Avatar
    Nov 24 2008
    2004 A4 USP 1.8T 6MTQ
    Grafton, MA
    im flattered you used my dash as the "after" photo... but i think an actual before and after of your console would be hugely helpful
    USP CLUB MEMBER #327
    Semper Fi.
    Mar 29 2009
    San Diego/CA
    ^ will do. sorry i just had to share as a quick reference. i can only do a after photo cause i never took before photos as hideous as it looks but i will try to point out the markings. I also used the paint on my grab handles and window buttons.
    Feb 22 2009
    WI
    did you just use the touch up applicator or is there a brush too?
    Mar 29 2009
    San Diego/CA
    2 in 1. its a brush and a roller ball pen. but i also used a toothpick for the very small spots and making the + and - more noticeable.
    Feb 22 2009
    WI
    ah gotcha..
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    not too bad of a quick fix for people not wanting to search for cheap used parts...
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Deactivated Three Rings
    Jun 10 2007
    Toronto, Ontario, Canada
    My buttons are exhibiting a similar fate as well and I've been meaning to do this simple touch-up for the longest time. Thanks to this thread, I'm now motivated to finally go ahead and get it done this weekend!
    Veteran Member Four Rings KareemA4's Avatar
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    Where did you get it from?
    Denim Blue FWD
    Power = REVO K04, VMR Test Pipe, Forge 004 BOV, TT225 Injectors and Custom Novitech-Tuning FMIC, Magnaflow Turbo-Back Exhaust, Podi, Zimmerman Rotors, Hawks HPS pads
    WHP??
    Looks = Top and bottom Blackout grills, Yellow fogs, ASA Rims
    Suspension = 02 sport suspension and riding low
    Mar 29 2009
    San Diego/CA
    any autoparts store. i bought mine from advance auto but im sure autozone, pep boys, etc would have em.
    Senior Member Three Rings akarol's Avatar
    May 09 2008
    2003 Audi A4 3.0 Cabriolet
    Orlando, FL
    Quote Originally Posted by jon102034050 View Post
    The problem isn't searching, is paying for them. If I was to replace every button/part that is fading, I'd spend a lot of dough.
    Thanks for the tip. Will try this paint today on the way home. BTW, how long does it take to dry?
    Mar 29 2009
    San Diego/CA
    its a flat paint so depending on the temp inside the car... should be about a 10 min dry.
    Oct 02 2006
    MN
    Quote Originally Posted by akarol View Post
    If you search well enough, you wont have to pay anything... For example - I replaced my climate control with a 2007 a4 and bought it for about $70... I then went around and sold my somewhat peely one for $70 shipped. I have done this for multiple different items on my ride
    Jun 29 2007
    Raleigh, NC
    not true at ALL.
    that climate control thingy is EXPENSIVE for what it is..
    edit -- you found one for 70 bucks??? you lucky bastard.... every one i've found in good shape has been 110+ ...I'm no slouch with searching for a good deal either, half my car (ok, almost all of it) was built on good deals
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Apr 11 2008
    Not bad!! I used a fine tip black sharpie (permanent) and was EXTREEEMELY patient.. looks about the same, and I'm sure the marker costs a lot less. Might want to consider other options :)
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Damn that is a dirty car!
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Mar 29 2009
    San Diego/CA
    ^ ya havent had time to give a good clean down inside the car. wash and waxed the exterior already. i just bought the car about 2 weeks ago.
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Quote Originally Posted by B6Lovin View Post
    not true at ALL.
    I just bought a cherry B7 one for fairly cheap. I will be reselling mine and it has no peeling. The reason for the upgrade is the newer controllers have a vag channel that allow you to do a temperature offset and mine doesn't.
    Mar 28 2007
    how much did it cost?
    May 24 2007
    Southern California
    none of my buttons are peeling and im almost at 60k, but I will admit that our interiors are not as durable as they should be. The only complaint I have is, I wish we didn't have the soft touch buttons, rather the plastic ones like BMW.
    Kyle
    2.0L Revo GTRS Eliminator
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Quote Originally Posted by Boston_USP_327 View Post
    And I'm flattered you used my pic as the "before" photo!
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Senior Member Two Rings Peterjk4's Avatar
    Apr 18 2009
    B7 RS4
    NoVA
    i just took that awful paint off my grab handles and have bare black plastic and it looks fantastic... cheap on audis hand to use water based paint.. I washed it all off with some mild soap and water. Nothing to it. I'll post pictures soon.
    Current- No V.A.G.
    Gone, but not forgotten:
    03' Volvo V70 FWD
    02' C5 S6 Avant QA
    98' C5 A6 2.8 Avant QA
    01' B5 1.8T Avant QA
    96' B5 2.8 QM
    02' B6 3.0 QMS
    Jul 02 2008
    2004 Moro Blue A4 1.8T
    Annapolis, MD
    anyone know the part number for that damn thing? Mine is going and I might as well just get a new one because its pretty screwed.
    Veteran Member Four Rings nananana4k's Avatar
    Sep 10 2005
    A4 B6 3.0, Q5 B8 3.2
    Nice. Better than the super dark perm marker I've been using.
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    I-pod holder: where did you get it?
    -Matt
    FCDT Member #1
    Mar 29 2009
    San Diego/CA
    PM kwimberly. its his picture.
    May 11 2009
    1.8T Q - 04 beige
    Fredericton, NB, Canada
    You have a few options for holder - proclip - bracketon - panavise. I searched a lot for my Iphone and I finally got a complete set from bracketon (mount, swivel and holder) for 75 $. You'll need the power and audio adapter as well. Loys of options on ebay, depending on how smart you want the interface to be. I see in the picture it's a dice unit, you can also go with blitzsafe. Either way all are very easy to install , all you need are the radio keys.
    Beige B6 2004 1.8T Q, clean no mods - keep it simple (for now)
    Jul 30 2008
    Downtown Denver, CO
    Quote Originally Posted by xnetcrash View Post
    Why thank you, Ipod accessory advisor for AZ
    -Matt
    FCDT Member #1
