Results 1 to 30 of 30
    Veteran Member Three Rings xileh's Avatar
    Nov 06 2008
    Audi A4 B8 and Audi 100 20vt q
    Norway
    Headlight range control defective
    Got this message when I started my car today. And I see the lights don't go up/down as they use to do when I start the car.
    I have removed the headlights, when I removed the bumper. And I started the car while the lights where not mounted. And the message came up. But the message keeps on comming now, after I mounted the lights back on.
    Is something broken, or do I maybe have to go to a audi garage and get the headlights adjusted and fault codes deleted?
    Mar 02 2007
    Fresno, CA
    Re: Headlight range control defective
    I have a feeling nobody else has come across this issue yet. You're really one of the first I've heard of removing the bumper and all that so far.
    Senior Member Two Rings tekieru's Avatar
    Feb 27 2009
    08 Infiniti G35x/09 VW GTI
    San Francisco, California
    stealership!
    FML - never get the car i want... now im stuck with a black 08 G35x = /. i want AUDI or VW!
    Nov 06 2008
    Norway
    Blake P: I also removed the headlights when mounting laminx tint. But I didn't start the car without lights.
    Guess I will find out in the weekend. Going to run a VagCom diagnose on it then.
    Tekieru: stealership? what is that?
    Senior Member Two Rings Banan's Avatar
    Mar 28 2009
    B9 Avant 3.0TDI
    Sweden
    Quote Originally Posted by xileh View Post
    He's playing with words, a dealership (your Audishop) that's expensive steals our money, hence stealership... I think
    Active Member Two Rings _Makki_'s Avatar
    Mar 06 2009
    Fiat Seicento Sporting
    Norway
    xileh: had the same problem with mine A6 once. Xenon leveling setup got f00ked. U need to use VAC COM or VAS to fix it.. Nothing got damaged.
    xileh: Møller = stealership :)
    09' Audi A4 2.0TDI 202ps/405Nm Q Avant S-Line
    02' Audi A6 2.5TDI 220ps Q Avant Recaro X
    05' Fiat Seicento Sporting
    98' Golf IV Rieger GTi Wannabe X
    96' Audi A4 1.8 X
    94' BMW M3 X
    92' BMW 325 M X
    85' Citroen BX SPORT GTi Wannabe X
    Veteran Member Three Rings piotrowr's Avatar
    Jul 18 2008
    Scottsdale
    Had this happen when had front right fender replaced due to fender bender. Body shop removed the front right light assembly and upon reinstall error message was there. Body shop took it to the dealer and dealer reset codes and all came back to normal.
    2010 A4 Avant Prestige - 19" Sport Package, Quartz Gray Metallic
    Mar 02 2007
    Fresno, CA
    Glad I was wrong. Seems like a relatively easy fix!
    Jul 18 2008
    Scottsdale
    Yah but they charged the body shop $120 to reset the lights. Repair shops need to be careful with all these new sensors to take the cost of having to reset these things for insurance quoting purposes. The body shop had to flip the bill on this one since they had closed the claim and give us the car back with the lights defective. We brought it back and said "you fix it" as they suggeste WE take it to the dealer and see if they can reset. I was like, sorry, you didn't put it back together right, you drive it down to the dealer and consume your time not mine. Anyway, it all worked out....plus I had the poor bastards pay for the rental for 2 days while the dealer had it.
    Nov 06 2008
    Norway
    Well. Then I guess I will try to delete the codes. Have a friend that got VagCom and he will do it for me. Hope it is that easy
    Thanks for answers.
    Oct 24 2008
    N/A
    Had this problem 3 months ago also, came up 2 times within 3hrs timeframe. Somehow it went away next day.
    Senior Member Three Rings MOLDOVANOS's Avatar
    Aug 10 2009
    michigan
    I know its an old thread, but if somebody is searching for the same problem here is the fix http://www.a4mods.com/index.php?page...tml&category=6
    Nov 06 2008
    Norway
    Quote Originally Posted by MOLDOVANOS View Post
    thanks.
    Nice avatar picture btw :p
    Established Member Two Rings lokak's Avatar
    Jun 21 2009
    Houston, TX
    just got ecodes and ran into this fault code:
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
    any ideas? I hope it isn't a damaged auto-leveling motor in the headlight :(
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    I had this happen when I lowered my car and the servos within the headlights could not properly adjust because the manual set screws were set too low. I reset the headlight level and cleared the code with a VAG-COM. Hasn't come up since. HTH
    My current rides...
    Audi
    Jetta
    Veteran Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    Quote Originally Posted by Jacon View Post
    I noticed recently that when I gun it at night, I can see my headlights adjust to point down. Even when I left off the gas, they don't always auto-level back up. Then later on at random they level themselves and I feel like the ppl in front of me think I'm brighting them. Is this what you're talking about Jacon? I'm lowered as well.
    Anybody else run into this issue?
    OEM+ '09 Meteor Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hüper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards • VAG-COM'd
    Bilstein PSS10s • Eurocode IC Pipe • Avant Dual Exhaust • StopTech Pads • Lamin-X'd • Smoked Ambers • Blesk 5000ks • 034 Trans Mount
    Senior Member Two Rings misc720's Avatar
    May 04 2009
    socal
    Oops posted in wrong thread.
    Feb 19 2009
    Linden, VA
    Thanks
    Established Member Two Rings Chris250's Avatar
    Nov 22 2013
    Baltimore
    Would anyone know if the car would pass inspection with this light on?
    Jul 05 2016
    Manchester United Kingdom
    Hi All,
    Explanation how I fixed it and how much it will cost GB pounds:
    On my Audi A4 B8 2008 2.7TDI I had warning light pop out on my dash ''range headlight control defective'' so I went to mechanic to get this checked on computer £25 and he found this error ''sensor for vehicle front open circuit/short with power'' so Ive asked how much gone be to fix it? He told me that it will be another £102 for a part and £55 for an hour labour + VAT ended approx. £177!!! Sacre bleu!!! so I went to Audi dealer and ask them for a part number, for first they said that my Audi doesn't have front sensor?! hmmm...I knew that he doesn't have clue what he is talking about because day before I saw this video https://youtu.be/4QMYVhAtcuU and I found this sensor on my car exactly on the same left hand side like this guy on his A4 B6.......alright so when he said this, then I stopped believe him and just ask him to provide me the part number + price and how much it will be to fixed this in Audi garage......he said part will cost £155 and labour £150 an hour!!! WHAT!!! My answer was only one....Thanks for that pal, I will think about it and come back to you soon...yeah of course. After all this bad experience which I had with mechanics I decided to searched the Item on Ebay.co.uk and I found it exactly what I was looking for 1T0907503A ...200Hz second hand for £30 :) so this afternoon Ive put this new/second hand part on, took me an hour to do and guess what, fixed! Dash light has gone (no computer needed) and headlights back to normal and adjusting itself, Happy days...
    Mar 26 2014
    I am getting this error as well now.
    Did you just change the one side?
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    I have had this issue before and if you have a VCDS you can go in and do a test and it will run the range and reset it.
    Mar 26 2014
    Quote Originally Posted by bluetori View Post
    So you diddnt have to replace anything?
    What kind of VCDS do I need?
    Jan 14 2010
    Georgia
    Quote Originally Posted by JVince View Post
    Just your basic 350$ cable and was able to fix it, you cannot clear the code a lot of times the lights just have to be reset, park on a flat surface and allow it to move the motion and it should clear worked on my T3 Toureg as well.
    Feb 08 2020
    Texas
    Can any one tell me where range control module rt. side 2012 A6 headlight is located?
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Mike852 View Post
    smac probably will.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    :-P
    C7 A6? Can't say for sure, but ETKA seems to imply it'll be in the left end of the dash, on the cabin side of the firewall if it's like the A4.
    https://audi.7zap.com/en/usa/audi+a6.../9/941-941025/
    You're looking for something like this:
    https://wolfautoparts.com/headlight-...7a-274271.html
    Mike, you've got the front left and front right headlamps, you've got a level measurement arm on the left side front and rear control arms, then you have the control module that reads the movement of the level arms and tells the headlamp motors how to move. There's not a separate control module for left and right, as it sounds like you're implying.
    For our A4, it's behind/above the glove box.
    Sep 18 2018
    Calgary
    Beside the module, check the level sensor and see if the arm is broken, if they are you will get the same error message on the dash. Of course it's always better to do a scan with VCDS. I've replaced both left and right rear arms.
    For vehicle without ADS, I think there is only one in the front and one in the rear. For ADS suspension, there are two in the front and two in the rear.
    Without ADS
    Front 8K0941285P
    Rear 8K0941309F
    ADS
    Front 8K0941285P
    Rear Left 8K0941309D
    Rear Right 8K0941310C
    The arm on 8K0941309F is exactly the same as 8K0941309D or 8K0941310C, only different is the sensor.
    Junior Member One Ring
    Feb 17 2022
    Pennsylvania
    For anyone still needing the info on obdeleven
    Car
    Control units
    55 headlight
    Basic settings
    For me I was met with 2 options test or adaptive something choose adaptive
    It'll show waiting >hold green check and let go
    Hold again and let go
    Clear code
    Enjoy
    Feb 22 2017
    Quote Originally Posted by Ai_barber_guy View Post
    Thanks for this. I got this error yesterday. My car is a B7 S4 though. Will have to try it this week.
    B9 A4 Allroad
    4L Q7 S-Line
    MK1 TT 225
    B7 S4 Avant (sold)
    Stage 2 MKV GTI (R.I.P)
