Results 1 to 21 of 21
    Established Member Two Rings xRyan2.0T's Avatar
    Feb 10 2009
    B7 2.0T FWD, BMW 325i E86,
    Unhappy Just got quoted $1200 for timing belt replacement!!!!!
    Im at 80k miles now and figured that i should get my timing belt done along with my tune-up, but i just got quoted $1200 w/labor just for the timing belt replacement and service. Seemed outrageous to me. What do you guys say?? Has anyone replaced their timing belt?? if so, how much??
    Established Member Two Rings Brownie85's Avatar
    Mar 19 2009
    Parsippany NJ
    Re: Just got quoted $1200 for timing belt replacement!!!!!
    I paid $411 for labor (5.5hrs) on my 99 a4. and i bought the kit from ECS Tuning for like $200ish
    Veteran Member Four Rings redhott06's Avatar
    Mar 15 2007
    2006 A4 2.0t
    Bedford, NY
    LOL..thats pretty normal for parts and labor.
    06 Brilliant Red A4 2.0T stage2+
    sparco, bbs, revo, stasis
    [email protected]
    Veteran Member Four Rings jriddle11's Avatar
    Mar 26 2007
    B7 3.2Q and C7 A6
    Byers Audi - OH
    That price seams right to me.
    Audi Brand Specialist / Social Media Manager / Spokesperson Byers Imports (Audi, VW, Porsche, Subaru)
    Current: B7 OEM+ and C7 OEM
    Previous: B5, B6, B6 USP All OEM+
    Veteran Member Four Rings bblume's Avatar
    Dec 20 2007
    06 avant. 92 Gti. 07 X3. 14 Sq5
    Colorado
    I helped my friend do his last weekend (using the ECS kit)
    of course his was a a transverse mount motor (FWD A3)!!!
    Took a good chunk of the day and we had a lift.
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    92 Gti-TDi 1Z (sold)
    06 AVANT S-line QMT6 (Just sold it!!)
    07 BMW X3 (given to the in-laws
    Feb 17 2005
    Sarasota, FL
    Thats fairly normal, dealer will be 14-1500
    Mar 19 2009
    Parsippany NJ
    Damn I had no clue the dealers price was so high on that, Did you guys who did it get this kit? http://www.ecstuning.com/stage/edpd/...oductID=251213
    Account Terminated Two Rings
    May 25 2007
    Stage 3 EPL 2001.5 B5S4
    Madison, WI
    Quote Originally Posted by Brownie85 View Post
    I got a timing belt kit for $250 from here and you can rent the tools for $35. WAYYY cheaper for parts and shipping than ECS and way better since you get instructions. It is not so bad and JHM has a DVD he sells for $30 I would split costs with you for because I actually would like a copy ;-).
    http://www.blauparts.com/categories.asp?cat=2300
    http://www.jhmotorsports.com/shop/ca...2d3860ea912480
    I also recommend getting an accessory belt tensioner from autohausaz.com for $60 because it is good to take all that out while you are in there and they do go bad. Feel free to PM me with any questions or getting that DVD.
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Quote Originally Posted by A4ringedONE8T View Post
    I thought that WAS dealer price ($1200)??
    If you have any mechanical ability, it's fairly an easy job. If you can find a good independent mechanic who'll let you source the parts, labor should only be 4-6 hours and will save you a lot of money.
    Veteran Member Three Rings jayphil82's Avatar
    Apr 05 2008
    Quebec, Canada
    I'm glad a got it changed for 150$ while getting the cylinder head replaced under warranty! My dealer said it was a 800$-1000$ otherwise.
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    A word of advice...unless you're doing it yourself, don't buy the parts and then take it somewhere. Most places won't warranty the work if they don't supply the parts (which is justified imo).
    And the price sounds a bit high, but then again I have a 1.8T so idk ($750 parts/labor for me)
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
    Feb 10 2009
    ok, i just thought it was way high, but from the census of the forum i guess i have to fork out the $$$$$. OUCH!
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    call some local indy shops, ask around in your regional forum on here. you can get it done for much cheaper. $1200 is about a right price from a stealership.
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    Deactivated Three Rings
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by xRyan2.0T View Post
    My independent mechanic once said a price that was similar. If you saw the work that has to go into the job it would make sense. As far as I could remember, you have to remove the whole front of the car just to get access, and then you do the replacement. There was a B7 in his yard at the time all taken apart like that and when I asked what was wrong with it, that is what he told me.
    According to the maintenance schedule for my car, "At 110K miles (175km) replace timing belt (2.0TFSI engine only). Check condition of timing belt tensioning system, dampening pulleys, and idler pulleys and replace if necessary (2.0TFSI engine only)." So with 37k on the car I have some time to save up.
    Established Member Two Rings cgmiller63's Avatar
    Jul 01 2008
    2006 Audi A4
    Southern California
    You may not need to change the timing belt just yet. Audi revised the maintenance schedule for the timing belt from 85K to 110K on the 2.0TFSI.
    If you still want to change the timing belt, I have a contact in the Long Beach area who may be able to do it for you for a more reasonable price. PM if interested.
    - Celia
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    I am at 76k now and am waiting until about 100k because I am certified, if it breaks I will let Audi deal with it.
    Veteran Member Four Rings Tusin's Avatar
    Mar 16 2009
    Anchorage, AK
    Um, unless it is scheduled at 85k for you, and Audi denies your warranty claim, because you did not have it done when you should have....
    Sep 13 2008
    Western Chicago Burbs
    Be happy you don't have a 3.0. With 3.0 it costs about 2500-3500 including a gallon of anal lube from the dealer. One guy on here (Living Legend) paid over 5k.
    Mar 24 2007
    Quote Originally Posted by Tusin View Post
    Except that Audi calls for it to be done at 110k miles not 85k.
    Veteran Member Four Rings nramsey's Avatar
    Dec 09 2004
    Quote Originally Posted by chrislane31 View Post
    Which, frankly, is rediculous. Back when I had my B5 I remember weekly stories here on the zine where people with broken timing belts would post up. Most seemed to be going in the 75-90k range. Conventional wisdom is that you were on borrowed time after 70k. It seemed to not really be the timing belt that was the problem, but the tensioner that would fail, causing the timing belt to fail.
    Maybe they improved on the B7, but I somehow doubt it. I'd change it, regardless of whether I was under warranty. Do you want to deal with having a dealer fix the stuff damaged by a broken timing belt? I don't.
    - Nathan
    http://www.flickr.com/photos/nramsey
    2008 A4 2.0T Quattro Avant - Dolphin Gray
    Eibach Pro-Kit - Koni FSD - Rotiform MIAs
    Mar 24 2007
    Sure I will let the dealer replace everything including the head if it goes bad early. Then it will be an almost new engine at 100k. I let them fix most of the other stuff that went wrong under warranty.
