Results 1 to 13 of 13
    Sep 27 2008
    Norther New Jersey
    S5 Stock Wheel Weight
    Anyone know the how much stock S5 (19") weighs without tires?
    Thank you!
    Veteran Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    Re: S5 Stock Wheel Weight
    Quote Originally Posted by sbkim View Post
    Thank you!
    Does anyone know the weight of the stock A5 S-line wheels as well, or have a link to an official Audi product guide listing these weights?
    TIA
    OEM+ '09 Meteor Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hόper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards • VAG-COM'd
    Bilstein PSS10s • Eurocode IC Pipe • Avant Dual Exhaust • StopTech Pads • Lamin-X'd • Smoked Ambers • Blesk 5000ks • 034 Trans Mount
    Aug 29 2004
    '08 S5 6sp & '04 avant 3.0
    The City
    S5 are purportedly 29 lbs. and the dunlops that come stock are 29 lbs. as well... 58 lbs. per corner.
    Sep 03 2009
    San Antonio, TX
    While holding the tire/rim, jump on your bathroom scale. Note the weight...then put the tire/rim down and get back on the scale and note your personal weight. Subtract #2 from #1 and BAM....Not an exact science but it give you a ballpark figure.
    MY BUILD
    May 26 2009
    Houston, TX
    Quote Originally Posted by sa_seahawker View Post
    Ya I was gonna do that but I don't have a scale at home unfortunately. I do have a 24Hr Fitness membership tho and there are scales there. Hmm...
    Thx for the info Mr Jones. Would it be safe to assume that the A5 S-line wheels are the same weight as the S5s?
    Senior Member Three Rings jneutron's Avatar
    Mar 06 2009
    2009 A5, 2010 FX35
    Evergreen, CO
    Quote Originally Posted by MR_JONES View Post
    I believe Mr Jones is correct or damn close. I have not weighed mine but wil I can do it 2 weeks when the winter set goes on the car.
    2009 A5 [] Deep Sea Blue [] Light Grey Int [] Nav [] Tech [] B&O [] Stock S5 Wheels [] A dipstick [] STaSIS ARB [] STaSIS Exhaust [] Heon Xenonmatch [] Racing Dash LED Plate Lamp [] Rieger Rear Spoiler [] H&R 20mm F 25mm R [] Volant CAI []
    Active Member Two Rings labombadiesel's Avatar
    Jul 01 2009
    Audi A5 3.0 TDI quattro manual
    Zaragoza-Spain
    Well, the A5 S-line 18" wheels weigh considerably less than the S5 19" wheels.
    In fact my S-line 18" wheels with winter tyres (245-40/18 W Vredestein wintrac xtrem), being the tyres completely worn, weighs about 51 lbs per corner.
    With the tyres new it's expected to weigh a bit more, about 54 lbs per corner.
    What is really surprising for me is that my VMR V710 8,5x19 rims with Kumho ecsta SPT 255-35/19 96Y tyres completely new mounted, weighs only 54,66 lbs per corner, so the S5 8,5x19" rims are really heavy weighing 58 lbs per corner with tyres mounted.
    I was as surprised as you could be when I weighed the wheels on my house scale.
    Apr 03 2009
    I sold my OEM S5 wheels with OEM Dunop tires. UPS weighed it as 50 lbs for each wheel set including cardboard and plastic wrapping. So 29 lbs for the wheel sounds right but I doubt the tire is just as heavy. My best guess is 30 lb wheel, 15 lb tire.
    '08 Audi S5 - Ibis White/Tuscan Brown/Wood Inlays
    6 Sp/Tech Pkg/Navigation Plus/Bang & Olufsen
    20" J Line SDMsl2 Wheels/Custom Catback/H&R Springs/Huper Optik Tint/Hoen Fog Light Bulbs
    Car is for sale! Click Here
    Stage 3 Forum Advertiser Four Rings
    Apr 01 2004
    Orange County, CA
    Quote Originally Posted by MDS5 View Post
    19" tires are quite a bit heavier than 15 lbs!! Tirerack has a pretty good reference sheet in terms of tire weights. They probably use this to make their UPS labels
    Link
    If anyone is in the market to buy new tires, I would definitely check out Tirerack's reference sheets.. You may save 3-4 lbs per corner which is comparable with going from cast to forged wheels
    Apr 03 2009
    I stand corrected. I just checked my records and each wheel/tire set was 60 lbs, not 50 lbs. I saw it on their scale so they didn't mark-up the weight or anything like that for shipping purposes. So if the tire is 29 lb according to the tire rack website, then the wheel must be about 29 lbs, as stated by others here. I figure the plastic wrapping and cardboard piece I used for shipping is a couple pounds.
    Registered Member Two Rings
    Sep 24 2009
    MIAMI
    WOW 29lbs
    May 26 2009
    Houston, TX
    I wonder if Audi has a product spec sheet somewhere for all of their wheels. It'd be nice to have public access to sizes, offsets, and weights of all Audi OEM wheels for those who're interested... unless those stats are supposed to be on the DL for whatever reason.
    May 26 2009
    Houston, TX
    I just bought a digital bathroom scale from CVS and weighed myself. Then I grabbed one of the A5 S-line wheels I have and stepped back on the scale to get the difference.
    So unofficially, an A5 S-line wheel weighs 28.2 lbs.
