Results 1 to 13 of 13
    Established Member Two Rings lucidor's Avatar
    Feb 25 2009
    Seattle/WA
    Engine dies when clutch let out???
    No, im not stalling it. It starts fine but as soon as i start letting the clutch out the engine shuts off?? Any Ideas? I think it might be the clutch safety switch. Does that seem right?
    B6 S4 Avant
    XBL: Shenanians09
    -Ryan
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Re: Engine dies when clutch let out???
    Has it been a while since you've driven the car? Did you drive through a river?
    Feb 25 2009
    Seattle/WA
    nope no rivers.
    I drove about 5 miles then I was driving out of a stoplight and when I shifted into second the engine shut off and now it dies everytime I let the clutch out.
    B6 S4 Avant
    XBL: Shenanians09
    -Ryan
    Nov 09 2007
    Si,NY
    Does it run rough at all? Very,very slightly rough barely noticable. Then one night thing just would stall when the clutch was let out. Any CEL's? I had a similiar problem, it was a coil pack.
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Can you start the car with the clutch pedal up? I would try the switch first and see from there.
    Feb 25 2009
    Seattle/WA
    LCD says press clutch pedal to start so no I can't start with pedal up
    B6 S4 Avant
    XBL: Shenanians09
    -Ryan
    Senior Member Two Rings Joesturbo's Avatar
    Mar 28 2007
    Lewisville, NC
    If you can start the car with the car in 1st gear (clutch pushed in) it is not the clutch - however if the car tries to move at all it has something to do with the clutch or the slave cylinder.
    Seems like your symptoms of it "all of a sudden" sounds like the clutch or slave cylinder.
    If you rev the engine and then slip the clutch does the car move at all or does it just die?
    2010 A5, 2010 A3 SP, A4 Avant 1.8T 2004, Corrado G60 + 93 VR6, GTi 1.8T + VR6, 65mpg T-diesel Caddy, Jetta VR6
    Feb 25 2009
    Seattle/WA
    Quote Originally Posted by Joesturbo View Post
    There is no violent shaking or anything like the engine is trying to stay alive. It just shuts off. If i rev the engine and let the clutch out the engine dies but the car does move. It now have trouble idleing. Im starting to think fuel pump??
    B6 S4 Avant
    XBL: Shenanians09
    -Ryan
    May 08 2010
    Hawaii
    Unhappy I am having the same problem
    My car quits/stalls right when i let out the clutch. The rpm's just drop to zero and it tuns off. Definitely not like a normal stall.
    Seems like it is a sensor telling the engine to turn off.
    If anyone knows what the problem could be or has had this same problem any help would be greatly appreciated.
    Mahalo in advance!
    Oct 21 2005
    y
    Veteran Member Four Rings bw86's Avatar
    Dec 06 2008
    2.0L 058
    LI
    really bad vacuum leak? Try starting it with the maf unplugged?
    May 08 2010
    Hawaii
    It only happens once in a while (but A LOT more often in the past week). My car idles fine and when it does let me let the clutch out without stalling it drives perfect!
    Would a vacuum leak cause this problem sporadically? is there a sensor that could be causing this problem?
    Senior Member Two Rings zephyr125's Avatar
    Oct 06 2008
    98.5 B5 2.8, 74 BMW 2002, 82 BMW R65LS
    Corte Madera, CA
    Quote Originally Posted by bob12312357 View Post
    I had the exact same thing, it did this for about a week and then never did it again. About a month later it started misfiring, which was the coil pack. I never found out if the clutch thing was related to the coil pack or not but since its been replaced its never done it.
