Hi all,
First off, yes I read throught the forum and did search the forum but couldn't find the exact replica of my problem.
At light throtle between 2000 rpm and 2800 rpm, after a light accelaration, when engine is cold and outside temps are between 28 F and 40 F and high humidity the car will hesitate. Nothing strong, feels like misfire.
Car bought used, still under CPO, now with 70 000 miles. A4 avant, 2.0T, stock.
Brought it to the dealer several times with no luck.
First I noticed, but no CEL came on (at +/- 60k miles)
Then CEL came on flashing for 15 seconds, but once it was past 3000 rpm, the CEL went off. I got the car in at the dealer and they replace the crankcase valve. Did nothing. (at 68k miles)
The CEL then came on after I moved my warm car in the parking lot after washing the salt from it. Brought the car again, they change the PCV. Did nothing. (at 69k miles)
I told the service manager about the problem every time I got the car in.
Since I live in Montreal, the perfect weather are in fall and spring to get the hesitation, but whenever we have conditions close to the ones cited above, the car will still hesitate, minor hesitation, but hesitations none the less.
I will get the car in the dealer, in roughly 1200 miles for the scheduled maintenance and will have to drive there again in the morning after to test drive it with the tech so they hopefully withness the darn problem they can't replicate (remember cold engine, it has to sit still overnight)
Other than that the car is perfect.
What do you guys think ?
PS I don't have a VAG-com just yet.
Jerome
