I'm going to do my best to explain my issue so here we go...
Upon cold starting the car (morning start) and taking off 10-15 seconds afterwards, even under light acceleration (always the case while the engine is cold), there is a "jumpiness" to the acceleration through first and second gear. Once I make it through a couple gears the acceleration becomes normal. This occurs anytime the engine is started cold and I drive off. It only lasts for a couple seconds until I make it through a couple gears and then wont happen again until the next cold start.
Is this common for a turbocharged engine until all of the oil circulates through the turbo? I haven't noticed it on any automatic transmission outfitted loaner cars I've driven or the B6 A4 I used to have.
It doesn't seem to happen if I wait a minute or two after starting the car--hence my thought it just needs a little longer to warm up and the ECU has adapted.
Does anyone else notice this? There are no noises associated with the experience, it is just a feeling. I would never accelerate hard on a cold engine so I'm not sure what that would do. It only lasts a couple of seconds though--not nearly time enough for any component to warm up much.
Thoughts?
