Results 1 to 40 of 44
    Dec 19 2007
    York, PA
    Interior Trim Wrapped in Suede
    Attempted to do something a little different than the rest. I know there are a few guys on here that have wrapped the trim...some looked good and others not so well. I think mine turned out great. I think some will like it and some will hate it. There are NO sags or bubbles...im actually quite proud of myself b/c of how well it turned out. Let me know what you guys think. The only other color i wouldve done would be black. But my trim was already soul gray and just black for the shifter surround and the front/rear ashtrays. I did all 9 "trim pieces":
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Re: Interior Trim Wrapped in Suede
    Looks Toight!
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    I would have left the shifter area alone, but it looks like you did a real nice job. No obvious bubbles and wrinkles. Did you tape off the pieces and use spray adhesive?
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Senior Member Three Rings FourRingsB6's Avatar
    Oct 07 2008
    2005 A4(HIS), 1999 Jetta(HERS)
    Lancaster, PA
    Close ups of the shifter area. Great job with the fitment aroung the quattro badges and chrome trim.
    Stretched, poked, and slammed.
    May 21 2007
    Florida
    Quote Originally Posted by kwimberly View Post
    agree here. i probably also would have used a darker red.
    2018 Navarro Blue Q5
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    nice!
    02 A4 3.0Q6MT
    -chad
    Veteran Member Four Rings michgo's Avatar
    Oct 21 2007
    Wagon/Variant/Avant A4 B6
    Any tips for someone who is doing this soon? How did you do the quattro cut out?
    Any DIY's or specific materials you used? Thanks!
    I heart wagons.
    'It's actually a pretty big pet peeve of mine when people mess around with my photos', MmmBoost
    shave it mold it sand it paint it
    Oct 22 2005
    Reppin the Mitten.
    nice, I was actually going to do this.
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    looks good any chance you will a diy on this??
    211,000 miles
    ||Borla||forge dv||35%||awe||k&n||autobahn hoses||awe smic||ssac||walbro 255||
    Veteran Member Three Rings LDetter's Avatar
    Mar 10 2008
    York, Pa
    Looks good man! I'll have to check it out wed at chillis a little closer if you'll be there. Looks like the tips i gave you worked out pretty well
    1998.5 1.8TMQ Cactus Green
    Veteran Member Three Rings Tomek6's Avatar
    Dec 29 2006
    2005 A4 USP 6spd
    Looks good. Don't spill anything on the shifter surround.
    2005 Audi A4 USP 6spd |Revo Chip|TT 225 Injectors|Evo MS Intake w/ modified stock ram air|Samco Hoses|Forge TIP|Forge DV|VMR TP|Custom SS 2.5" Magnaflow Exhaust|ECS Snub Mount|KW V2 Coilovers|Hotchkis S4 Sways|BBS CH's|3.0 C/D, Slotted Rotors|USP Front, Rear Spoiler and Interior Trim|Cupra R Lip|B7 Rear Valance|DTH Sideskirts|Grilles|E-Codes|S4 Mirrors and Door Blades|S/w Boost Guage w/ Podi Steering Column Pod|
    Veteran Member Three Rings Kerschera4's Avatar
    Jun 21 2007
    DC
    Quote Originally Posted by michgo View Post
    i did this a while back if you remember my thread and the 2 pieces you need to get out are the 'quattro' and the trim piece along the flip up part of the ash tray.
    when you take the trim off it is just a hole filled with plastic that is holding them into the actual trim piece. it is easy to see what i am talking about when you take the trim off. i just used a dremmel and ground down the backing plastic within the hole and was able to pop both pieces right out.
    as far as adhesive goes, and im sure the OP will attest, use a strong spray adhesive. i used 3M foam adhesive and the fact that it is so strong made it very easy to not have any bubbles or peeling
    Sep 30 2007
    2015 A4 6MT Black Sport Package
    973 - Northern NJ
    looks good... very nice job. +1 on prefering a darker color but it looks very nice.. And the shifter surround probably should of been left alone, probably get dirty quick? BUT then again im looking to find an alcantara shift boot haha, but in a dark blue color to match my moro blue color... anyone know where i can get one PM me! (sorry for the thread jack).
    Good work and for being different..
    Any plans on doing your head liner?
    I wouldnt mind doing my headliner but dont want to tackle a job like that on my own.
    Veteran Member Four Rings jcg05c's Avatar
    Jun 07 2007
    350z
    orlando
    Its just so hard to find a good color to go with the inside of cars. Still ehh on doing this
    19in Privat Netz 10mm front/17.5mm rear
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
    Senior Member Two Rings iwasinthepool's Avatar
    Apr 05 2006
    2002 A4 1.8TQM
    silverthorne, co
    i'm trying to find grey burberry to do mine.
    Dec 19 2007
    York, PA
    Ill get close-ups as requested. The quattro badge was actually removed and then pressed back in after i punctured holes in the suede to get the badge "posts" back through. I used a pair of pliars to force it back in. The extra material in the holes actually has enough press to keep the badge in...no need for glue. As for the color, i see what many of you mean, AND with the shifter area. The good thing is, is that the red actually matches the red audisport logos on my rubber mats. ALL pieces were removed and disassembled to wrap...except the front ashtray. For a DIY guide, it was relatively straight forward. I bought Loctite's spray adhesive AND the suede at a local "joann fabrics". I sprayed the piece itself AND the backside of the suede for proper adherement. (if thats a word, lol...per the directions of the spray can) and slowly applied it like it was a tint to assure no bubbling. It takes TONS of TIME and PATIENCE to get this perfect. There are odd cuts to make in the fabric to get it around the tricky curved areas of certain pieces. Just take your time and keep clean. The adhesive can get quite messy as you may think. Any other questions, please feel free to ask me. I can probably do a whole other set of trim with what i have left over. I bought a full yard.
    Dec 19 2007
    York, PA
    Quote Originally Posted by LDetter View Post
    haha, yea they did. I just was like "fuck it" and went to go pick some suede after work on friday and spent the ENTIRE night till past midnight doing it all. I figured i could use a break on going out friday night and save it for saturday night instead. It was quite relaxing chilling out for an evening, just me and the car and some tunes.
    Mar 10 2008
    York, Pa
    Quote Originally Posted by n7plus1 View Post
    Know what u mean, im on probation and cant go out so i end up working on the car instead. Told ya it wasnt hard, the suedes pretty easy to stretch to get all the wrinkles out of. It took me forever to do mine, at least a week working evenings but i did the door armrest too wich were a bitch, dont plan on doing them again anytime soon.
    Veteran Member Three Rings jstcalmebatman's Avatar
    Aug 21 2008
    yeah i like yours alot i want suede but in a different color.. idono something to tie the interior together. not pop out. this is what i have as of right now. put in a couple weeks ago
    ( sorry to thread jack i just forgot to post mine )
    Dec 19 2007
    York, PA
    not threadjacking...people...post up whatever you want.
    Established Member Two Rings cabreezy's Avatar
    Mar 13 2009
    02 A4 3.0L QU
    Long Island
    i really like that look n7plus1, good choice of colors, I prob would have also gone with a darker shade of red, but that still pops nicely.
    jstcalmebatman's looks pretty cool too, although i don't know how i feel about it (the purple) seeing that your car is red from the side view mirror.
    wonder what color would be good if done on my tan interior... yikes
    Aug 21 2008
    Quote Originally Posted by cabreezy View Post
    Haha well its actually black.. Damn I think the sun is already getting to it.. And even with tint all around
    Dec 19 2007
    York, PA
    oh and for the ashtray in the front...you just lay over the aluminum pieces and then use a razorblade to cut them back out.
    Oct 21 2007
    Was just wondering what grey suede would look like
    I heart wagons.
    Veteran Member Four Rings mnkyA4's Avatar
    Aug 10 2004
    The City
    Quote Originally Posted by jstcalmebatman View Post
    I saw your trim in person at teh Alameda GTG. Nice job. Maybe you can help me take out my trim as I want to paint mine it flat black.
    03' 1.8T A4 Avant Tiptronic ----- SOLD!!!!
    FUTURE: 2013 Ibis White Q5 3.0T
    Dec 19 2007
    York, PA
    doesnt look bad...just a bit dull. Nice chopping skills
    Aug 21 2008
    Quote Originally Posted by mnkyA4 View Post
    haha yeah its not that difficult.. once you know what to do its hella easy. i just used the biy for trim install
    Veteran Member Three Rings CTUltrasport's Avatar
    Jan 25 2007
    2005 Audi TT
    Greenwich, CT
    not a huge fan of the color, but props to you for doing a great job.
    2013 Audi S4
    Dec 19 2007
    York, PA
    thanks everyone...i may go back to the store and go over teh colors again...nothing else comes to mind that would go well against black.
    Veteran Member Three Rings burns420's Avatar
    Oct 20 2007
    Anybody try tan suede trim in a black interior? think it would look good?
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    i did the opposite of that, tan interior w/ black suede
    Sep 01 2008
    San Diego, CA
    Veteran Member Three Rings karp's Avatar
    Feb 04 2008
    2012 STG2+ S4 and Triumph Daytona 675
    New York
    It came out great!... I would have tried red too. But i think it clashes a little bit now (a bit too bright) but nice job! =]
    May 24 2007
    Southern California
    ^^foreveraudi: i'd do the same if I had tan interior, looks good.
    Kyle
    2.0L Revo GTRS Eliminator
    Dec 19 2007
    York, PA
    buddy of mine on here has done the black suede with tan interior. Looks great...maybe he'll see this thread and throw pics up. I have since gotten rid of the suede.
    Oct 20 2007
    I just did the grey suede on black interior. It looks a bit lighter in the pics than in person. Ill be doing the headliner and pillars black this weekend. Also Im gonna do the door inserts black aswell.
    Oct 20 2007
    Anybody have pics of dark tan suede in black interior?
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    i just did the opposite today, black suede on platinum interior, i will get pics of it tomorrow, i love it. the dash piece was a royal PITA, looks good though.
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    can anyone post the DIY on how to take all of the trim off and how to take the door inserts out??
    I think i might do black interior with white suede like the S4's have on the seats and stuff
    Oct 07 2008
    East Texas
    ^It's on a4mods.com
    These all look great! I'm thinking about doing a crazy different color! Like lime green
    02 A4 3.0Q6MT
    -chad
