Results 1 to 12 of 12
    Oct 26 2008
    03 A4 Avant 3.0 6mt
    3.0 oil leak not valve cover gasket...
    Hey guys, I had an oil leak which was dripping on to the exhaust/CC. I replaced the valve cover gasket (passenger side only as driver's side is fine) with the help from members on this forum.
    It didn't stop the leak. Any ideas on where it could be leaking?
    I have read about a half-moon seal/metal gasket for the cam chain tensioner on the 1.8t but not sure it applies to the 3.0 v6.
    Any insight would be appreciated.
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: 3.0 oil leak not valve cover gasket...
    yes the half moon applies to 3.0 heads as well
    - Clint
    Established Member Two Rings bofa deez's Avatar
    Nov 03 2008
    bellevue, wa
    yep like you suspected. its gauranteed to be the cam adjuster seals like you said. half moon and metal gasket. these things go bad all the time... on passenger side these are a pain in the ass the get the seals in and out. drivers side is a lot easier cause its on the front of the engine, not the back. also inorder to access the seals you have to compress the chain tensioner with a special tool that threads into the head.
    Oct 26 2008
    03 A4 Avant 3.0 6mt
    Thanks guys, I will order the parts and the tensioner tool tomorrow.
    Where exactly is this seal anyway? Took a quick look but could not see it.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Avantist View Post
    under the cam tensioner at the back of the head
    - Clint
    Aug 08 2007
    A4, GTI, Corrado
    Jacksonville, FL
    Not to question anyone's knowledge, but I don't know if these tensioners exist on the 3.0 head. I think they do on the older 2.8's and 2.7's. But the 3.0 actually has 4 cam gears that are all driven directly on the timing belt.
    It could be the cam seals that sit behind the cam gears, those are known to leak as well.
    2011 VW Jetta TDI
    2002 Audi TT Quattro
    2002 VW Jetta 1.8t
    1993 VW Corrado SLC
    Oct 26 2008
    03 A4 Avant 3.0 6mt
    Quote Originally Posted by KJIV View Post
    Is this true? Should I not order the half-moon seal/metal gasket/tool ?
    I plan on ordering a Bentley dvd but in the meantime can anybody advise on what to do? Thanks.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    The 3.0 heads utilize the same halfmoon gasket
    -Sami-
    Veteran Member Four Rings 02silverb6's Avatar
    Nov 20 2006
    ATL, GA
    I had a bad oil leak and it definately was the cam adjuster seals..i would replace those first before anything else.
    PM me if you need RNS-E installed in Atlanta area
    R.I.P 2002 Audi A4 3.0
    Sep 13 2015
    commerce
    OK, my 3.0 is leaking pretty badly and smoking when i park it seems to be on the passage side pretty bad and the drivers side a little bit. what parts other than the valve cover gasket should i get ? i want to make sure the problem is 100% fixed when i do the work and don't mind doing extra
    Aug 26 2005
    Quote Originally Posted by MSUaudi View Post
    The valve cover gaskets are the most common parts that age and leak oil like that. Very often, simply re-tightening the valve cover screws will stop any leaking of oil occurring. When the cover gasket ages, is relaxes under the valve cover and the cover screws get loose. Try re-tightening the cover screws before replacing the gaskets.
    Vorsprung durch Technik
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    What he said ^
    Also, quick test: With engine running, remove oil fill cap from driver's side valve cover. Is there a slight vacuum present when you are lifting the cap out? There should be. If there is pressure (instead of vacuum), your PCV system may be plugged or damaged. This pressure forces oil past the valve cover seals.
    Good info available by searching for "Audi B6 A4 3.0 pcv"
    Great info available by searching for "Audi B6 A4 3.0 pcv heater hose"
