Results 1 to 26 of 26
    Jul 03 2007
    Fairfield CT
    How to install caliper retaining spring????
    i know this is probably a stupid question but how do you install the caliper retaining spring?
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    Re: How to install caliper retaining spring????
    Did you get the S4 ones ?
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
    – Thomas Jefferson
    Jul 03 2007
    Fairfield CT
    yea
    help i wanna get these on but dont want to break anything
    thanks
    Dec 05 2006
    So. Cal.
    push them into place. it's not that hard, just gotta use a little elbow grease.
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    Screw driver will pop them out and yes, they push on.
    I have two OEM sets available (non-S4 logo'd) if anybody needs them.
    FS: Audi TT 225Q Roadster
    They are tricky little bastards. Be careful you dont want to pinch yourself. What you want to do is place one end behind the caliper as your going to install.
    Grab a flat head and push the other end back to install it behind the caliper. The trick here is to keep your opposite hand in the center of the clip applying pressure to keep it from popping out. Once both ends are behind the caliper, grab a rubber mallet and tap the center so the tab seats in the brake pad properly.
    Senior Member Three Rings mcimiluca's Avatar
    Feb 20 2009
    Quote Originally Posted by joeycuccaro View Post
    x2. that hurt just by watching lol
    Quote Originally Posted by mcimiluca View Post
    Dude i still have the little blood blister... lol
    Mar 12 2007
    Boston
    Let me start by saying I rarely DIY (unfortunately) but having read all the write ups on this, I tried it today and it is E-A-S-Y. Took less than two minutes for each one, and I am not exaggerating. Flathead screwdriver to pop the stock one out, then wedge in the "S4" spring in by hand. So easy. Thank Christ I didn't let the dealer do it and charge me a half hour labor.
    After giving my stock calipers a good thrashing yesterday with some brake cleaner and wire brush, the addition of the new springs makes the brakes look halfway decent behind the new wheels. It was driving me crazy looking at shiny, new CHs with shitty, dirty stock calipers behind them.
    SOLD 4/16/15- '08 Daytona Gray RS4/Black leather/CF trim/35% tint/MTM 10mm spacers/Euro steering wheel/GMG catback w/ Magnaflow DPs
    SOLD 9/4/11- '04 Nogaro Blue S4 w/ LaBree Resonated Fullback/ Vogtland Coils/ ECS Snub Mount/18x8.5" et32 Diamond Black RS-GTs
    Jan 14 2008
    If you search "rattle", there will be a lot of posts. Here is my version from another post:
    I had the pleasure of doing this myself this morning before a local car show... yes, I did it myself.
    Quick and easy:
    1. Use a flat head screw driver in the middle slot and pop the tab out of the hole. Do not pull it all the way out yet.
    2. Put a towel over the entire assembly (I learned this after the one side) and use needle nose pliers to pull the entire clip straight out at you. The towel should deaden the blow when the caliper flings at you.
    3. To reinstall, align the "S4" in the middle area and push the top part of the spring into position.
    4. Then push the bottom part into position.
    5. Finally, use the flat head and squish the little tab into the slot in the middle area.
    6. Relax and enjoy. Sorry if this is a repeat, I rarely do anything by myself and am quite happy I was able to do it.
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Quote Originally Posted by EYE4SPEED View Post
    Quick and easy:
    Damn I wish i thought of that, when i put mine on I took one of the clips off the forehead when it rocketed off.
    Mar 12 2007
    Boston
    Quote Originally Posted by beemercer View Post
    I guess I got lucky. I just popped both off'em off with a screwdriver. There was definitely a "spring" effect but neither shot off with any real danger.
    Veteran Member Three Rings sleeperwagon's Avatar
    Nov 07 2007
    18 RS3, 22 AMG GLC43, 97 AA M3 Sedan, 03 Dinan M3 Convert, 88 E30 M3
    Northern Ohio
    dumber question. The "TAB" on the S4 clip, do I jam that into the square from the brake pad or just make sure it sits on the brake pad clip? (the little metal parts on the back of the brake pad that pops into the caliper)
    Quote Originally Posted by sleeperwagon View Post
    Yes, make sure that "tab" is seating inside the square.
    Nov 07 2007
    Northern Ohio
    nevermind, I am an idiot. its flipping easy, I was too concerned chipping the paint on the calipers. Just push guys/gals, its easy!
    Veteran Member Three Rings IslandHydro's Avatar
    Nov 29 2008
    WA State
    Goggles would probably not be a bad plan, just sayin.
    Senior Member Two Rings LOUDERPLEASE's Avatar
    Mar 20 2012
    Melbourne Australia
    Hey where'd my pic go?!
    Veteran Member Four Rings troyguitar's Avatar
    Feb 03 2013
    2004 Z06
    PA
    I am apparently doing it wrong then because it is a huge pain in the ass for me. I need two screwdrivers, pliers, and a hammer plus several minutes of cursing at the damn things.
    Sent from S4 in my S4
    2004 Z06
    2001 allroad gaytronic - Sold
    2008 TT 3.2 DSG - Sold
    2006 S4 Avant MT6 - Sold
    Mar 20 2012
    Melbourne Australia
    Senior Member Three Rings CDN_S4's Avatar
    May 24 2013
    Rainbows and Unicorns
    NB Canada
    Quote Originally Posted by troyguitar View Post
    lol for me too, it flew past my face twice when it popped off lol. However with a little bit of persuasion from a hammer it found its place.
    Car History: 2007 GLI, 2001 A6 2.7T, 2007 GTI, 2004 S4
    Sep 11 2014
    San Jose, CA
    Painted my calipers today and popping the spring was easy but putting new ones on was difficult (the old ones were worn and faded). When I try to wedge in one side, the other side pops out like a bullet. I decided to put a tie wrap on one end and that helped me push the other one in. The tie should not be be loose, otherwise it won't stop it from popping out. After that, rubber hammer the center to complete the install.
    Established Member Two Rings httuner's Avatar
    Jun 18 2013
    Anchorage Alaska
    Put one side in all the way, use long flat to push the other side towards the caliper carrier then use a hammer to hit it all the way in. Worked for me that way.
    Jun 05 2016
    Vermont, USA
    I must be an idiot because putting that spring clip back on was the hardest lart of tbe whole brake job - and I still don't think it us seated as well as it was when I took it off (that was easy)
    Sent from my LM-G710VM using Audizine mobile app
    Veteran Member Four Rings Jdsb6s4's Avatar
    Aug 27 2016
    GL450, GLA250
    Quote Originally Posted by spooled951 View Post
    If you know how to pull out then you should damn well know how to put it back in 😂
    Veteran Member Three Rings s4ski's Avatar
    Jul 01 2013
    2005 S4 Avant, Skiis
    Anchorage, AK
    I think the S4 clip has a slightly different fit than OEM. You can see it if you align the two up in comparison. The S4 clip kept popping off before I could push the other end in, launching as a projectile. After gashing my hand, I gave up. Put the OEM clip back on, which was a piece of cake in comparison.
    Established Member Two Rings Eye_In_The_Sky's Avatar
    Oct 17 2012
    96' TT Supra
    Finland
    Just push the upper or lower arm in place first and press the center pin in place after that and bend the other arm in after that.. If it doesn't work just mod your old one like I did
    Skickat från min ONEPLUS A3003 via Tapatalk
