Results 1 to 18 of 18
    Senior Member Two Rings Capt.Canuck's Avatar
    Feb 26 2009
    '06 S4
    Ottawa, Canada
    Question about wheel spacers, B7 S4
    I'm about to pull the trigger on some wheel spacers from ECS, but just wanted to double check that I'm picking up the right thing.
    I've got the OEM BBS 18" wheels and 235 40 18 rubber.
    Are the ECS - VW / Audi 10mm Spacers & ECS Ball Seat Bolt Kit the correct measurement for this application?
    In particular I want to confirm that the 10mm is fine for both front and back, and that the OEM BBS wheels are Ball Seat, and not Conical Seat.
    TIA.
    Registered Member Two Rings
    Dec 15 2008
    NoVa
    Re: Question about wheel spacers, B7 S4
    You should get bigger ones in the rear or smaller ones in the front if you want front and back to be even. Stock, the rear wheels are more tucked on our cars. I'm sure you can go up to 15 without problems, so 10 should be perfectly fine. Don't know about ball or conical seat.
    Senior Member Two Rings XwalkerX's Avatar
    Dec 04 2007
    2005 s4 avant
    tuffalo, NY
    i was running my stock avus wheels last summer with 10mm in front and 15mm in the rear and it sat perfect imo.
    2004 Audi A4 Ultrasport [daily]
    2001 911 Turbo [fast]
    2005 Triumph Speed Triple [faster]
    1995 BMW M3 [sold]
    2005 Audi S4 avant [sold]
    Established Member Two Rings showoff's Avatar
    May 06 2008
    Ontario, Canada
    I have an Ultra Sport with USP 18's and stock sport suspension
    I run ECS 20mm Front and rear without rubbing. Its looks so badass!
    2014 Estoril Blue S4: DSG, Sports Diff, Tech Package, Panda Leather, Carbon Atlas trim, Roc Euro Intake, AWE Touring w/non-res DP's, CR-15, H&R Sports, 19 x9.5 AG M590 (Brushed Grigio).
    Established Member Two Rings ThePerfectLine's Avatar
    Feb 13 2009
    Los Angeles, CA
    I am interested in knowing the same thing, as I want to do the exact same mod!
    Deactivated Four Rings
    Apr 13 2008
    Bayern
    if you are running stock sport suspension, you could do a 20/20 or 15/20. i have konis and springs, so i went with 10/15. you could do a tad bit wider f&r, but i'm happy as is.
    Veteran Member Three Rings nealRlett's Avatar
    Nov 27 2007
    B7 S4, '71 BMW R75/5
    yeah, I am going 10mm in the rear and 8mm in the front very soon. As per what xzone909 said, at stock, the rear wheels are more tucked on our cars. You don't want those front tires sticking out too far. Just make sure they are hub-centric and all that jazz. Post pics when you complete-
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    I think all OEM wheels (the BBS included) are ball seat. I'd probably do 12 or 15 in the rear and 10 in the front. Your offset is +43 (the Avus's on the B6's are +45) so I probably wouldn't go with the 20s.
    /S4
    AWE l Koni l H&R l Hotchkis l VMR l LEDs by fly
    Mar 01 2008
    Ouch, neal. Who'd you piss off to get the negative rep?
    /S4
    Nov 27 2007
    Quote Originally Posted by FastB7S4 View Post
    lol I just noticed that. Huh, I have no clue. Never really had an argument on here.(investigation begins)
    --how does one remove this? Do I need more "approved" posts? Someone is messing with me, I wish it would tell you who left negative rep.
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    Quote Originally Posted by ALWAYS4UDI View Post
    That makes stock look real nice, thanks
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
    – Thomas Jefferson
    Dec 04 2007
    2005 s4 avant
    tuffalo, NY
    here are a few pics i dug up from last summer that shows my stance. excuse the blue tape that was hrs before we left for h20...
    1995 BMW M3 [sold]
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    I'm sold
    – Thomas Jefferson
    Apr 13 2008
    Bayern
    i love blue tape
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    Do you need longer wheel bolts running 10/15mm spacer with stock 18"
    – Thomas Jefferson
    Mar 01 2008
    yes
    /S4
    Mar 01 2008
    you can buy spacer/bolt combos from ecs that will be the correct size you need. i believe stock bolt size is 27mm. just add what ever size spacer you get to that to get the proper length you need. also, you'll need ball seat for oem wheels.
    /S4
    Oct 11 2007
    Suburbia
    Quote Originally Posted by Capt.Canuck View Post
    TIA.
    If your running factory wheels I would suggest 15mm front and 20mm rear. It looks great, totally flush. Im not sure if your running stock suspension though. I am selling my set, machined hub/wheel centric Motorsport technology spacers. With bolts. PM me if your interested.....
