Results 1 to 23 of 23
    Senior Member Two Rings B6_Rakete's Avatar
    Apr 17 2008
    '04 S4 Avant 6sp, '06 330i 6sp
    Minimum rotor thickness?
    Anybody know what the minimum rotor thickness is for the front brakes on a B6S4? I'm trying to decide if it's time to replace the OEM units or if I'm good for one more set of pads.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Re: Minimum rotor thickness?
    need to replace their only good for one set of pads. The rotors are to soft to resurface. I tried that on my b5 s4 cuz audi listed a spec but everyone said not to cut them i cut them and they lasted about 6 months or about 2K miles befroe they started to pulstate and vibrate.
    Senior Member Four Rings ...Mark...'s Avatar
    Oct 03 2008
    Murdered out 04 S4..
    Atlanta BITCHES!!!
    Worst advice ever..
    My B6 has 24k on it and i just changed the pads and the pads only. The rotors were fine, they were not warped and there was no pulsating and they were well within spec when i had the car inspected upon purchase 2 months prior. There was no need to cut or resurface the rotors in my instance.
    Jan 14 2009
    pasadena md
    well ya if you dont cut them im sure you will be fine. if their is no warping or grooves or any lips. When i just hung pads on mine i had to cut them because of the lips i didnt want any noise. but then again i was using some mintex redbox.
    Feb 16 2008
    Iowa
    New thickness is 30mm, replacement is at 28mm. It took me 65K to reach that point.
    If you need to get them turned, they probably need replacing anyway.
    Apr 17 2008
    Thanks for the min. thickness values, I'll have to measure my rotors this evening.
    BTW, has anyone tried these DBA 4000 Series rotors? The new JHM ones seem to be at a good price point, but the wear surface seems to be extremely thin.
    http://www.tirerack.com/brakes/brake...ar=&perfCode=S
    Mar 01 2004
    2004 Audi S4, 1997 Audi A4 1.8
    Northern NJ
    Usually the min thickness is stampedd on the face of the rotor, measure it with your vernier caliper...
    Feb 16 2008
    Iowa
    Quote Originally Posted by B6_Rakete View Post
    Many aftermarket rotors are 4 times the price for little or no gain in performance over our factory rotors in most applications.
    I'd just buy the OEM for $73 each. We have pretty robust brakes already. Just a pad change and fluid can do a lot.
    Veteran Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    RS4
    Sorry for the necro bump...can someone confirm whether or not the 28MM min rotor thickness is accurate for a B7 RS4. I also checked the face of the rotor for a stamp indicating this information and found nothing.
    RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM 3R & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : F Plate Delete : CC Mod
    Veteran Member Three Rings handyvorb's Avatar
    Jan 31 2009
    '04 S4, '95 Eagle Talon MSnS
    Huntsville, AL
    It was already mentioned, but let me say it again, Audi says DO NOT turn (cut) their rotors!
    If they are below 28.00 mm when you do your brake job, you are to REPLACE them.
    You can usually run 2 set of pads on Audi rotors before they require replacement. The lip that shows on the edge after running through a set of pads will not be a cause of noise when installing new pads, again don't cut them. What will cause noise is if all the caliper and pad contact surfaces are not cleaned.
    Joel Baldridge
    Stage 4 Audi Technician (Master Guild Certified)
    Aug 14 2009
    RS4
    Quote Originally Posted by handyvorb View Post
    Speedy response thanks! I am going to measure them now.
    Jan 31 2009
    Huntsville, AL
    Quote Originally Posted by NY07RS4 View Post
    RS4 (Brembo) min rotor thickness is 32 mm.
    B6/B7 S4 is 28 mm min.
    The response I made was actually to the post above yours, please know they're different specs.
    Joel Baldridge
    Aug 14 2009
    RS4
    NOTED!!!! Thanks again
    Mar 08 2009
    warwick,uk
    I went through two sets in 37,000 miles
    Senior Member Two Rings DTMOOOO's Avatar
    Sep 16 2006
    Westchester NY
    Quote Originally Posted by S4iowa View Post
    Where can i buy OEM rotors for $73 each?
    06 JHM S4 -Sold
    98 TJ Wrangler
    08 Yamaha R6 - Sold
    2003.5 Carbon Black M3 -Sold
    B7 A4 3.2 - Gone
    Aug 10 2007
    south jersey
    Quote Originally Posted by DTMOOOO View Post
    not 73 but close... 78.25 @ GAP.. germanautoparts.com.. always great quality parts and very knowledgeable people
    Feb 01 2008
    04 Audi A4 cab
    Chicago
    28mm
    Feb 01 2008
    04 Audi A4 cab
    Chicago
    Ebay, got a set of 2 front ones for 90 shipped.
    Feb 01 2008
    04 Audi A4 cab
    Chicago
    aiee double post
    Senior Member Three Rings ozo101's Avatar
    Jan 24 2009
    nj
    Quote Originally Posted by mboy View Post
    I suggest you learn how to drive :o)
    Drop den Vorschlaghammer!
    Established Member Two Rings EMAudi's Avatar
    Sep 22 2008
    Misano Pearl RS4
    Quote Originally Posted by ozo101 View Post
    ^^^^HAHAHA
    RS4 *Humble Rumble*
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Why bump a really old thread to laugh at a post that isn't really that funny?
    Veteran Member Three Rings madkimchi's Avatar
    Sep 09 2009
    Bicycle and roller blade.
    Kent, WA
    Quote Originally Posted by EMAudi View Post
    ^^^^HAHAHA
    ^^^^HAHAHAH
