Results 1 to 9 of 9
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Angry how to tell if valves are bent with head off
    i have a aeb head i pulled off and is there anyway to ell if the valves are bent? someone told you you can fill the ports with brake clean and if they eak past the valves then they are bent? any other methods
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Registered Member Two Rings mwebb's Avatar
    Jan 25 2009
    98 2.8 A4
    central pa
    Re: how to tell if valves are bent with head off
    well first off if your head is pulled off the block alll your valves shld be sitting flush if not somethings bentor u can just pull them out and look at them all
    98 A4 2.8
    1976 Jeep CJ7 with 14" suspension lift
    Registered Member Two Rings manufan's Avatar
    Nov 16 2007
    98 A4 2.8 QM 93 Ducati 900ss
    northern pa
    Take it to a machine shop and have it pressure tested.
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    Quote Originally Posted by mwebb View Post
    All of your valves will not be sitting flush. It will depend on where the engine was in rotation when you removed the head.
    You would be to tell if a valve was severely bent by just taking the head off but you would have to remove the valves to inspect them further and see if they are slightly bent.
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    the cams are removed so all valves are seated right now
    99 A4 1.8TQM:
    00 B5 S4
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    to do a quick test, i use wd 40 variant in a manual spray bottle. spray in port. look to see if it leaks. if it comes out quick, it'll be bent or the valve seat needs to be reground. on suspected valves, i'll pull the valve stem in a drill and spin it to see if it's obviously bent. hope this helps.
    82mm je pistons, scat rods, ported & polished aeb head. gt2871r, atp hi flow manifold (ported). 580cc injectors on custom giac tune. Once you boost, you'll never go back....
    Senior Member Three Rings ed1380's Avatar
    Mar 16 2009
    ATL
    way ive done it-
    have the head upside down and level.
    i used diesel cause it doesnt evaporate as fast, but pout that into the "dish" until its flat with the level of the head and let it sit overnight. if theres any gone in the morning then you might want to take a better look at it
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    the 3 ways i check are:
    looking at the piston for valve damage. if there is piston damage there is most likely bent valve(s)
    removing the cams and checking for leakage on all cylinders. this can also be used to check valve faces/seats for damage/carbon.
    removing the valves (using proper tools) and visually checking (very easy to tell bent from new)
    iirc the exhaust valves and the center intake valve are the ones that usually hit, with the latter getting the brunt of the collision with the piston head
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Senior Member Four Rings Jake39454's Avatar
    Mar 04 2009
    Horsepower injected Audis
    Richmond RI
    Quote Originally Posted by ed1380 View Post
    way ive done it-
    Correct
    Brake clean out the ports then fill the combustion chambers with fluid of choice (I use oil personally) and look in the ports with a flashlight after a few hours. You will see the fluid reflecting light if there is any leakage.
