Originally Posted by
ThirdStrike
thought id share in case any of you guys are thinking about doing this:
so here are some shots of how I installed my wahlbro 255 inline. This was probably the easiest inline pump install I've done. the b5 chassis seems like its ready to take a pump from the factory. cant even really tell its aftermarket.
the holes in the frame worked perfect. wonder why those holes are there
the hardest part was finding a line that made a bend of around 120 degrees to go back into the engine bay. the line i used is a oem fuel line from a 1.8t.^
a etka of the wire position from the central electrical panel that's above your left knee as you sit in the driver seat. pump is powered on when the motor turns over, not on turn key [wire position is circled]
ThirdStrike: Noticed today that the "4k hickup" on my 1.8T AEB coincides with injector time reaching 16.32 msec, and watching my fuel pressure gauge, notice at the same time pressure dropping by 10 psi. So, I suspect fuel pump has reached his limits.
A while ago, put a Deatschwerks (love it) in my Allroad, but what a PITA that was. Took me HOURS 'under fuel' to rig a ghetto adapter for the stock sock ('strainer'), since the one that came with the pump fit NO WAY.
So, thinking either dropping in a Walbro 255 (cheap enough), but afraid of 'home depot O rings' (used for securing the Deatschwerks; worked fine) or foam spacer, electrical splicing (or get pigtails), but mostly the darn sock (strainer).
Intrigued by the inline option you describe (and yes, the Bosch 044 is also an inline pump!!!, and inline pumps are used EVERYWHERE in the performance worlds (just maybe not so much in 'stock Audi circles'), particularly (strictly speaking: requiring) if used with intermediate tank (typically 1 gal or so), I was hoping to duplicate your setup.
But to my disappointment, the pic links are GONE.
Can you relink, or send to
[email protected]?
Thanks.
