Results 1 to 19 of 19
    Aug 27 2008
    Houston Area
    Wheel lug torque spec?
    Took the 18" sport wheels off this weekend to wax them before the brake dust eats the paint like they did on my B5, and I'm left with very flat black (i.e. brake dust) colored wheels on the inside...
    I checked the torque before removing anything and they seemed to be somewhere between 65-70 ft-lbs. Seems low -- my B5 was 88 or 90. They are back on at 70 now, but I'd like to know what they should be.
    Anyone know what it should be? If all else fails I'll call the dealer :-)
    Thanks,
    Jim
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: Wheel lug torque spec?
    For my 19s on my b7, it is 90-100. That does seem low
    Mar 02 2007
    Fresno, CA
    I've been torquing mine to 90 ft lbs.
    Veteran Member Four Rings PESAPC's Avatar
    Aug 19 2007
    C8 RS6 Avant 2025 + Durango Hellcat 2021 & Gone B7 RS4 + B8 A4 Avant
    92
    B7 RS4 - JHM R-Clutch/LWFW/CP/Short Shifter + Milltek Exhaust + JHM Piggies&Tune + F/R Brembo BBK + HRE
    B8 AVANT S-Line FMIC + F Brembo BBK + BBS + STaSIS Exhaust + GIAC Tune
    BOTH Ohlins Coilovers + Rear Sway Bars + Michelin PS2 + Tint
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    Sorry need to bring up this thread. I am starting to wonder if my vibrations are due to under torquing. I called two dealerships, one said 100lb while the other said 80lb-85lb. Tire shop said 80lb for Audi.
    So which is correct?
    2010 A4 quattro, Tiptronic, Ibis White
    Aug 15 2009
    New jersey
    To be safe,I got info from a Senior Audi Tech 2 years a go.90lbs.
    Last edited by Ernesto; 04-19-2011 at 04:36 PM. Reason: wrote incorrect unit of measure
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by dracolnyte View Post
    Have you tried looking in your owners manual?
    Feb 04 2010
    Ottawa, Canada
    owners manual clearly says 120Nm or 90lb/ft.
    2014 Ibis RS5 w/ Ti. Package AWE Track Edition, ECS 15/10, 034 Transmission Mount, 034 Solid Sway Bar, 034 End Links
    2021 Nardo Grey RS7 w/Black Optics/RS Design
    2023 Daytona Grey RS6 w/BlackOptics/RS Design w/CTS Res Delete, CETE Lowering Mod, 034 Sways
    2025 Daytona Grey RS6 Performance w/AWE SwitchPath, CETE Lowering Mod, 034 Sways, etc
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by Runge View Post
    Party pooper! I wanted to make sure draconlyte knew how to use the index...
    Feb 04 2010
    Ottawa, Canada
    I'm being nice. I have a 4 day weekend coming up, and APR Stage 2/HFC/HFIC/STaTIS exhaust going on soon.
    Jul 12 2010
    Q5 3.0T
    AH! i just read the manual after I got home. yes it does say 90 and I just checked my wheels are torqued to atleast 90... because I couldnt break one loose. So now that eliminates loose bolts from the vibration issue.
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    GTA Canada
    If wheel wasn't mounted flush, even with proper lug torque you'll still have vibrations due to the tire literally wobbling as it rotates.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
    Jul 12 2010
    Q5 3.0T
    Quote Originally Posted by DeMOROlized View Post
    it was installed by the dealer, after being road force balanced
    Mar 02 2007
    Fresno, CA
    Did they give any indication of whether the wheels were out of balance or the center bores seemed too big for the hubs? While not a permanent solution, you can wrap several layers of electrical tape around the hub to make the wheels fit snug on them and figure out if that's the problem. The tape will act as a hub ring in the meantime.
    Jul 12 2010
    Q5 3.0T
    the only thing the dealer said was whoever mounted the tires did it wrong which caused the wheels to be out of balance. no word on bent, cracked or centre bores not fitting properly
    oh they did crack the clips on my wheel caps though, if that helps
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    m12 bolts are 90, the m14s can hold up to more, but maybe the rim gets damaged if more than 90 goes on them. M14 bolts are more like 120ish. I'd use minimum 90.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Jun 14 2005
    Anaheim, CA
    It certainly seems that 90 ft-lbs seems to be the ideal torque spec - perhaps even 2-3 ft-lbs higher.
    Remember, it is always good practice to check/re-torque new wheels after 30-50 miles of driving to be certain the paint around the lug seat area has not affected the torque on the lugs!
    Brandon @ VMR Wheels
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    Never heard other than 90 ft-lb.
    Cheers
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. FCA Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    Veteran Member Three Rings quality_sound's Avatar
    Jan 29 2005
    Ramstein AB, Germany
    Your dealer lied their asses off. You can't mount a tire incorrectly so that it's out of balance. you can improperly balance it or mount the wheel incorrectly (if it's aftermarket) but the tire itself is either mounted or it's not.
    Quote Originally Posted by VMRWheels View Post
    And don't forget NOT to put anything like anti-sieze on the lugs since it'll affect the torque needed to secure the wheel.
