Results 1 to 40 of 49
    Veteran Member Three Rings xileh's Avatar
    Nov 06 2008
    Audi A4 B8 and Audi 100 20vt q
    Norway
    How wide wheels on A4?
    Hello.
    wonder a bit how wide tires are possible to fit an a A4 B8.
    Can you post what wheels you got on your car?
    Front/Rear
    I hadd
    9,5"x19" with 265-35-19" last summer front and rear. ET 35 (I think)
    Lowered with original sport coils from Audi (not sline)
    Senior Member Two Rings tekieru's Avatar
    Feb 27 2009
    08 Infiniti G35x/09 VW GTI
    San Francisco, California
    Re: How wide wheels on A4?
    hey not to thread jack you but what are the stock wheel size (s-line)?
    FML - never get the car i want... now im stuck with a black 08 G35x = /. i want AUDI or VW!
    Mar 02 2007
    Fresno, CA
    It depends... Do you mean without rubbing or poking past the fender? If I remember right, your fronts poked past the front fenders by about 10mm. I think 9.5" wheels might work with ET45, but not sure about clearance with the suspension on the inside. I'm running a conservative 8.5" width with 245/35/19 tires to avoid rubbing the rear fenders. Your question does not lend itself to a simple answer, so please clarify.
    Nov 06 2008
    Norway
    tekieru: My sline wheels was 245/45 or 40 -18" Don't remember the ET
    Blake P:
    I ment without rubbing fenders On front I also want's to be able to make a turn without destroying my front fenders. Thinking 8,5 with 235/245 and 10" rear with 265-295 some place?
    Veteran Member Three Rings awhk82's Avatar
    Jul 13 2007
    Hong Kong
    Quote Originally Posted by xileh View Post
    Blake P:
    Hi Xileh, I have been runnin 20x9 ET 37 with 255 tires for the rear and they rub the inner fender when suspensions are compressed. I'd say 20x9 ET 40 would be your safest choice for the rear. As for the front ET 37 with above spec fits perfectly (fender rubber has to be removed to avoid rubbing). 255 width tires would be the optimum size for 19 and 20 inch. You might have to reconsider about 235 tires. Hope this helps.
    2012 RS4 Avant - Suzuka Grey
    Capristo Catback, HMS X-pipe
    Before...
    11 TTRS | 10 S5 SB | 08 A4 3.2 | 06 A4 2.0T | 05 A3 SB 2.0T | 04 S4 | 99 A4 2.8
    Mar 02 2007
    Fresno, CA
    Blake P:
    The problem with that idea is that the rear fenders are not wider than the fronts, so running wider wheels and tires in back is a very bad idea, IMO. If you remove the plastic clip from the front fenders and roll the inner lip flat you can easily fit 9" wheels all around. If you want to drop it really low and avoid rubbing, I suggest ET41 all around with 245 tires. 255 might work if they have rounded sidewalls like Toyo T1R, but that rear fender liner sticks out so much that you might have to cut it to be rub free with a very low drop.
    Registered Member Two Rings Jim@STaSIS's Avatar
    Sep 22 2008
    sonoma, ca
    we've got 265's under it w/ no rubbing. trying 275's this week to see if we can squeeze them. fun with offsets!
    Mar 10 2009
    About time we got a wheel fitament thread going. I've been searching all over for an answer to this question...audiforums.ca, audiforums.com, audiforum.com, vwvortex, etc.
    Mods, can you sticky this and change the title to something along the lines of "A4 B8 Wheel Fitament"?
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by Jim@STaSIS View Post
    Wheel specs would definitely be helpful, Jim.
    Veteran Member Three Rings sevenstarz's Avatar
    Dec 28 2005
    Orange Va
    +1 and suspension settings.
    Peace
    2015 SQ5 Brilliant Black | Black Optic | B&O | Carbon Inlays | 21's | KW Street Comfort | 15f/20r Spacers | RSNav S4 10.25 | 034 Stage 1 ECU/TCU
    Sep 22 2008
    sonoma, ca
    i'm sure they would. they're silver, and we wrap them with tires. =D
    sorry but that's special sauce. we pull the springs and dampers off the car, bolt up various wheel sizes + offsets and cycle the suspension through its range of motion to check for interference. then we do a bunch of road testing to validate. all to find the widest tire possible w/out rubbing. it takes a long time, and a lot of work, so you'll understand if we're not exactly forthcoming with the data.
    the good gnus is that you can buy them from us!
    Junior Member One Ring
    Mar 10 2009
    Houston
    What size tire can I use in place of the standard 245/40-18 that came with the Sport Package? I am trying to add "width" to make my tires look full/chunkier... and still use the 8J x 18 wheel
    Sorry if this is not clear?
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by HtownA4 View Post
    275/35/18 and 285/35/18 are the closest to your stock rolling diameter, and equally "bad" depending on how you look at it. The 275's will result in your speedometer reading 0.543% too fast and the 285's will be 0.546% too slow. Both are very close, but way too fat for 8" wheels, IMO. My suggestion would be to get at least 9" wheels if you want to try and stuff a fatter tire in there.
    Mar 02 2007
    Fresno, CA
    I nominate this for worst reply in history.
    Jul 13 2007
    Hong Kong
    +1 here
    Before...
    Nov 06 2008
    Norway
    I have borowed a wheel that is 10x20 now. It only got 245 tire, but I will fit this on my car, just to se the space with lowering rear.
    Will try with different spacers to make different ET's to
    Mar 02 2007
    Fresno, CA
    Glad to hear it! What is the wheel offset?
    Senior Member Three Rings Reinart's Avatar
    Oct 27 2008
    Oslo, Norway
    I have the choice of 20x8,5 with ET35 or ET38 on the wheels i've decided to go with. I know ET38 sticks 3mm more out to the fenders than ET35.
    Most people say go for ET35, because its a more agressive offset. I'm just wondering if the ET35 will rub the fender with a suspension setup lowering 60/50mm?
    Feb 27 2009
    LOL
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    so did you find a sauce recipe for 275s...or a no go.
    Veteran Member Four Rings B_Boy's Avatar
    Nov 24 2008
    2024 VW Atlas SEL Premium R-Line, 2024 Ford F-150 RCSB
    +1
    b_boy
    '23 SQ5 P+
    Sport S, B&O, Nav, Black Optics, Black Nappa, Black Sport Exhaust, Mythos Black, VAG-COM, LED Reverse Lights, IE ECU Tune, CETE
    Tint: 15% F/R, 50% Windshield
    Wheels: Rohana RFX11 Brushed Bronze - 22x10.5 ET32 // Pirelli Scorpion Zero A/S+ 265/35/22
    Sep 22 2008
    sonoma, ca
    where have all the senses of humor gone? since we're a business we try to sell the things we develop, not give them away. i'd love to go open source but we haven't figured out a way to do it and keep gas in all of our ferrari's.
    the 275's we've run have rubbed like crazy. our car is about 2" down from stock for comparative value.
    Mar 02 2007
    Fresno, CA
    Nobody is asking you to give your wheels away, but since this is a thread about wheel specs that will best fit the A4 a little free information isn't going to hurt anyone. There are many reputable wheel companies that list the specs of their wheels for everyone to see and they seem to be doing quite well. I, for one, would never buy a set of wheels if I don't know the specs.
    Nov 24 2008
    let us have it!!!!
    b_boy
    '23 SQ5 P+
    Established Member Two Rings marvinmai's Avatar
    Aug 24 2009
    Audi A4 B8
    Would a 255/35/19's fit on my stock 225/50/17?
    Current:
    2010 Audi A4 2.0T Quartz Grey | 20% Non-Metallic Tint All Around | Vag-COM | E-Codes | Hoen H11 Fogs | 19" Forgestar Wheels (19x9 ET42) on Hankook Ventus V12 K110 EVO (255/35ZR/19) | H&R OE Sport Springs
    Future Mods:
    Black Optic Grille
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by marvinmai View Post
    Wait, are you asking if you can put 19" tires on 17" wheels or am I misunderstanding your question?
    Aug 24 2009
    Audi A4 B8
    No. Right now i have the stock 17's. I wanna replace my WHEELS and TIRES with that arrangement I stated earlier. I'm just not clear on how much width of tire (the 255) the vehicle can handle. Let me know if I'm still not clear.
    Current:
    Future Mods:
    Black Optic Grille
    Mar 02 2007
    Fresno, CA
    255's are fine with the correct wheel width and offset. Which wheels are you looking at?
    Aug 24 2009
    Audi A4 B8
    i'm really digging what a fellow AZ'er has done on his A4. 19" Hyper Silver V708 w/ 255/35 Hankook Ventus V12 evo K110. I have the same Qrtz Gray Metallic A4 as he does. Would I need new springs or anything? Sorry, I'm a auto-noob.
    Current:
    Future Mods:
    Black Optic Grille
    Mar 02 2007
    Fresno, CA
    Yes, he lowered his car on STaSIS springs so if you want the same look you need to lower your car. 19" V708's would fit just fine with 255/35/19 tires.
    Aug 24 2009
    Audi A4 B8
    Have any recommendations on where I can get the STaSIS springs for a good price?
    Current:
    Future Mods:
    Black Optic Grille
    Mar 02 2007
    Fresno, CA
    Not a clue. Depending on how far you live from West Covina, Penske Audi is a STaSIS certified dealer who can sell and install their parts and you would still be covered under warranty. Otherwise, I'd suggest you buy H&R OE Sport springs for a slight drop and similar spring rate to stock that is supposedly designed to work nicely with stock shocks and retain the stock ride quality.
    Sep 03 2009
    Jim, do you think your 275 recipe could be rub free on oem audi drive select sline suspension? If 265s fit all around, neat6o, but it would be nice to have a max fit for original sport springs too.
    I am guessing 9.5x20 275s on et43 would be the closest to working.
    Sep 22 2008
    sonoma, ca
    we've not gotten 275's to clear, but only on our suspension. can't speak to stock s-line.
    Veteran Member Three Rings CLEAR's Avatar
    Aug 28 2009
    2009 Audi A4 3.2Q Aruba Blue
    Pasadena, CA
    275/30/20 on Eibach Springs here, waiting to take the wheels off to show pic of the offset.
    graphic designer - photographer
    Sold : Ducati DESMOSEDICI D16RR
    Veteran Member Three Rings SignitrSideways's Avatar
    Dec 16 2008
    Manhattan Beach, CA
    thanks haha
    as for prices of the springs, i paid 350parts and 100 labor, but I bought a lot of stuff at the same time to kind of offset the low cost of labor... i was at $50/hr instead of a lot higher for the avg job.
    keep in mind when you drop the car you'll need to do a re-alignment which is pretty expensive in it's own right.
    thanks again for the props.
    Current Mods: 30% Rear 50% Front Llumar Ceramic Tint. 19" V708 w/ 255/35 Hankook Ventus V12 evo K110. H&R Coils.
    STaSIS: Chip, Anti-Roll Bar, exhaust, steel brake lines.
    Mar 14 2007
    09 A4 2.0 6MT AWE Exhaust&FMIC
    New York, NY
    I'm not sure if Stasis offers more than one wheel setup for the A4 B8. I met with a local member tonight dieatomic who has them and said they are 20x9 ET48. He's running 255/30/20 tires and 5mm spacers in the rear. Not surprisingly, from the looks of it there's room for 5mm spacers up front as well. Perhaps with the ET48 offset there's room to run wider rubber as well? It's certainly a less aggressive offset than most aftermarket setups.
    These were the SE08 wheels.
    Senior Member Three Rings dieatomic's Avatar
    Sep 23 2009
    2009 A4
    Bergenfield, NJ
    ^^^ yep Im running the se08 with 255 35 20 all around and 5mm spacer in the rear. I uesd two 5mm spacers on each side but since i had no hub left to center the wheel i got vibration at about 45 mph. I ibelieve with the stock suspension (not sport or s-line) you can run a 12 mm hr spacer and def a 265 width tire maybe a 275 but not sure.
    Veteran Member Three Rings eboosted's Avatar
    Jul 17 2009
    lima
    Wide wheels will make the car look faster but perform slower, mmmm... I'm not sure about this mod
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by JasonR View Post
    I'm pretty sure STaSIS designed the wheels with a pansy offset so they could squeeze 265 wide rubber on them. Although, if you ask me I think 255 is overkill for the power the A4 is putting down.
