Wow, this car is a nightmare.
Drove home today, right before getting on the highway I put it in neutral to slow down before the toll booth came up. The Intermittent headlight warning immediately came on, this happened before and when I turned off the car and turned it back on it went away. I didn't think it was a big deal so kept driving with it on.
When I got on the highway I put on cruise control and set it to 74, 2-3 minutes later all the sudden the speed starts dropping like the gas got cut off. I took it off cruise and gave it gas myself and it acted normal. Nothing happened for a while so I put it on cruise control again, same thing 2-3 minutes later speed starts dropping while cruise control is set and on (it runs the normal 74 mph for a few minutes then suddenly starts dropping). Didn't want to mess with it so just stopped using cruise control the rest of the ride home.
Once I get home, I park the car, go inside come back outside and turn on the car. When I give it gas to back it out, it sounded like a harley and like it was only running on 1 or 2 cylinders. This stayed constant the whole time.
I had my Accord for 3 years before this car and the only issue I had the whole time I owned it was the door latch broke on the drivers side and I couldn't use it till it got fixed.
I just got back home and I'm afraid to even touch the car now. I opened the engine cover and looked at the ignition coils to make sure they didn't pop out and they looked fine. The spark plugs might have died, but I don't even want to mess with it anymore. WTF!
OK I made a list of everything that went wrong, I'm almost positive I have a leak somewhere (I really hope). After all of this my idle is still rock solid. So hopefully a trip to the dealer will fix this with something simple and not something huge like needing to replace ECU.
