Originally Posted by
KryptoniK01
This still doesnt explain why they appear equal with stock wheels and not equal when 18's.
When upsizing wheels, S4's going from 17" - 18" barely changes the overall diameter of the wheel/tire combo because the smaller sidewall makes up for the difference in wheel size. That being the case, the gaps from the top of the tire to the wheel arch should remain the same both front and rear.
x2
glad someone already said it. If you buy the correct sized tires, than the overall diameter of the wheel does not change, you'll have the same wheel gap you had before. However, with the smaller sidewall of the tire, it does give the
illusion of the gap becoming bigger when in reality it doesn't. This is just because there is less tire now with the same amount of wheel gap.
