I just tried to replace my wifes rear brake pads 06 A6 with (this is the kicker) electromagnetic (E-) park brake. I have found out that you have to use a Vag-Com (CAN-Hex) to release the (park) brake caliper. Here is a link to the instructions.
http://wiki.ross-tech.com/index.php/...ial_Procedures
Open Rear Parking Brake
Prerequisites:
Connect a battery charger.
Cycle the Parking Brake ON, then OFF first.
[Select]
[53 - Parking Brake]
[Basic Settings - 04]
Group 007
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The brake calipers will then open,
allowing the pads to be changed
[Done, Go Back]
[Close Controller, Go Back - 06]
It is normal for the LED in the parking brake switch and the warning lamp in the instrument cluster to blink rapidly at this point.
Close Rear Parking Brake
Prerequisites:
[Select]
Group 006
[Go!]
[ON/OFF/Next]
The brake calipers will then close.
[Done, Go Back]
The LED in the parking brake switch and the warning lamp in the instrument cluster will probably continue to blink rapidly. This should stop after cycling the Parking Brake ON, then OFF again.
You CAN NOT release or press the caliper back with force...believe me I tried with every tool I could find. I just ordered a VCDS 350.00 from Ross Tech
Hope this helps!
Steve
