Results 1 to 27 of 27
Thread: SD Card Slot
    Oct 02 2007
    Australia
    SD Card Slot
    Hey guys, just wondering if u guys know what the biggest SD card is supported in the dash... im currently using a 2GB card, but once over 2GB... the cards become SDHC... any ideas if the car supports it?
    Established Member Two Rings D.NGUYEN's Avatar
    Feb 17 2009
    2009 Audi A4 2.0T 6MT
    Re: SD Card Slot
    Quote Originally Posted by cK1 View Post
    I don't believe it takes SDHC cards.
    Senior Member Three Rings khmerguy978's Avatar
    Sep 14 2008
    B8 A4 Prestige
    Boston, MA
    Re: SD Card Slot
    SDHC doesn't work. tried it.
    Aug 10 2009
    Re: SD Card Slot
    "with single CD drive and SD memory card reader (supports SD-HC cards up to 32GB)" V.310
    Veteran Member Three Rings Cabal_san's Avatar
    Sep 06 2009
    TX
    Re: SD Card Slot
    You can find a 4Gb SD card online - not SDHC. Around $9.99 US as of last month when I got mine off Amazon. It will work just fine. Just put your tunes in folders.
    Gave up on a fix to get early 09 using sdhc. I tried about 4 diff sizes and speeds to no avai of sdhc.
    YMMV.
    Senior Member Two Rings gtrab's Avatar
    Mar 02 2009
    Audi A4 B8, Audi Q5 2013
    El Salvador
    Re: SD Card Slot
    biggest SD card supported is 4GB SD (non "SDHC")
    most 4GB cards are SDHC
    4GB "plain" SD cards are "rare"
    NOW: Audi Q5 2.0T Ibis White
    19" 5-Y spoke wheels 255/50 tires | Exhaust tips | Special lower body paint work | VAG-COM customizations
    EX: Audi A4 B8 CVT deep ocean blue
    19" 5-Y spoke wheels & 255/35 Dunlop SpeedMaxx tires | S4 grille & fogs trims | S-Line side skirts & exhaust tips | "Audi collection" items | Custom paintwork | CTM ECU reprog | VAG-COM
    Sep 06 2009
    TX
    Re: SD Card Slot
    Here's a link to they type you want foran older B8 w/out SDHC support.
    Enjoy
    http://www.amazon.com/Transcend-Flas...002567&sr=8-10
    Aug 10 2009
    Re: SD Card Slot
    Eitherway the newer models support SD Cards up to 32GB
    Senior Member Three Rings dame drizzo's Avatar
    Sep 15 2009
    1995 Audi URS6
    Re: SD Card Slot
    i am so lost.. where is the memory card slot??
    Sep 10 2009
    2001 A4
    East Walpole, Massachusetts
    Re: SD Card Slot
    Quote Originally Posted by dame drizzo View Post
    behind stock nav screen.
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    GTA Canada
    Re: SD Card Slot
    Quote Originally Posted by young wing View Post
    Not in the B8. Only RNS-E (not available in B8) has the slots behind the screen.
    If you don't have Nav, the slot in the actual head unit, near the lower left corner.
    If you have MMI 2G, you don't have SD slot.
    If you have MMI 3G, it's behind the flip down door below the disc slot.
    As for max size, RNS-E is SD only. Older non-nav cars are also SD only. Newer non-nav cars & MMI 3G can read SDHC up to 32 GB.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
    Sep 06 2009
    TX
    Re: SD Card Slot
    For Symphony/Concert radio B8's, its on left side just below dash nipple.
    Prior to late 09 production, hardware reads SD only, not SDHC.
    Hence the need for a 4GB SD Transcend card (or other manufacturer)...
    Veteran Member Four Rings Tone-Dogg's Avatar
    May 06 2007
    2020 Q3 P+
    Hartford, Connecticut
    Re: SD Card Slot
    Quote Originally Posted by Cabal_san View Post
    So in 2010's will and SDHC work? or only SD's Sorry to sound ignorant here, i'm just confused. TIA (BTW, i have an 010 with the SD slot in the lower left on the head unit, I'm currently running a 2GB SD) I would like more space
    2016 Q5 3.0T Quattro P+ Sline Black Optic
    2020 Q3 2.0T Quattro Premium +
    Sep 15 2009
    Re: SD Card Slot
    i've put in a 4gb SDHC and it works on my 2010
    May 06 2007
    2020 Q3 P+
    Re: SD Card Slot
    Quote Originally Posted by poker838 View Post
    Thanks for this info
    Veteran Member Three Rings scottyuk's Avatar
    Sep 20 2006
    Essex, UK
    Re: SD Card Slot
    FWIW I've used 16Gb SDHC and 1Gb MMC...now both removed and replaced with a 160Gb iPod ;)
    Senior Member Three Rings vajking's Avatar
    Mar 21 2009
    Audi A6 4F 2009 2.0 TFSI
    Sweden | Balkan's
    Re: SD Card Slot
    Does the SDHC 4GB work in a A6C6 2009??
    Audi A6 4F
    2.0 TFSI - 232bhp / 380nm
    S-Line
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Anyone else here use a SDHC or SDXC card with success in a 2010 (basic MMI/non navigation)? I'm having a hard time finding a SD only card on Amazon.
    I'm not real happy with the consistency of my bluetooth device with my iPhone. Sometimes it doesnt display song info correctly, takes awhile to connect, and sometimes cant answer calls thru the cars speakers. Seems like an easy option is to simply put my music on a SD card so its always easily available without my phone being involved and then use the regular connection for phone calls.
    Is it as easy as copy/paste the iTunes folders I want to the SD card?
    I'm as cool as a cucumber in a bowl of hot sauce.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    You can use SDXC but you must format them into FAT32 format.
    I run dual 64GB cards with roughly 100GB's of music. I've been tempted to try a single 128gb card so my music is all on one directory, but the MMI already takes a while to read and load the 64's.
    I feel like it it might be annoyingly long trying to read it all off of a single 128 card. One of these days I'll give it a try.
    EDIT: Forgot to mention that I'm a B8.5 with MMI 3G+
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Thanks for the info!
    I currently only have 6 GB of music (Social D, Rancid, Bad Religion, etc) on my iPhone. ha ha!
    Is it as easy as copy/paste the iTunes artist folders I want from my PC to the SD card?
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by BeerBrent View Post
    I remember reading that the MMI system can only ready X amount of files or folders per directory (255 if I recall correctly?). However, I think you could break those files out into multiple sub-directories.
    I have no idea if that's true or not - I suppose I'll find out when I try a 128gb card. I did originally base my structure off of that premise though.
    I structured my cards as such:
    Each album gets it's own folder with the album files inside. I labeled the folders "Artist - Album Name" to keep them in alphabetical order when scrolling in the MMI.
    The benefit of this way is that everything you want to find is alphabetized and accessible from the primary directory. I found that the more sub-directories you have, the slower the MMI becomes to navigate, particularly the back button.
    The downside to this is that all of your albums are in the primary top directory, which slows the loading time and gives you a monster list to scroll through when you're searching for something to listen to. For example, let's say you had all the albums of an artist whose produced 15 albums over his or her career. You'll need to scroll past 15 albums before you get to the next artist.
    I'm going to try restructuring my cards again soon.
    Artist > Albums > Songs
    This seems more logical but when I first did this, I remember there being a specific reason why I didn't do this the first time around. I think it had something to do with how the MMI displays the folders and files. I think I remember that it might treat all sub-directory trees as one entire sub-directory - and if your subfolders are only album titles, you lose visibility to the artist name when searching.
    I can't recall for certain though. Maybe I'll make this my weekend project.
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Established Member Two Rings redlineracer's Avatar
    Nov 21 2015
    Toronto / ON
    Running a 64 gig in my B8.5
    Jun 24 2018
    Slovenia
    I`m running Transcend 16GB micro SDHC with micro SD adapter and works perfectly.
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by adamazing View Post
    I finally pulled the trigger on a 128GB card (thanks Prime Day) and can confirm that it works just fine in the MMI 3G+
    As expected, it does take a bit longer to load the card from a cold start (106GB of total media), but once it does you're off and running like normal.
    I made sure to use a UHS-3 rated card with fast read times.
    For reference: I used a 128GB Samsung Evo Select which is basically a rebranded Evo Pro sold as an Amazon exclusive line.
    When I tested this card in CrystalDisk, it came back averaging 84MB/s read time over five test sequences. Pretty decent value.
    Apr 26 2014
    San Diego, CA
    I may have spoken a little too soon.
    The 128GB works, but not without an annoying quirk. It's so big that upon start-up, the MMI doesn't accept it as a playable medium right away. After a few seconds it begins to load like normal.
    The problem, is that initial hiccup means the MMI re-loads your entire card like it's a brand new SD card every time.
    So if you have, say, 40,000 songs on your card it's going to start from Folder 1, Song 1 every single time. It wont pick up where you left off.
