Results 1 to 14 of 14
    Apr 04 2007
    2003 A4 1.8TM, 1987 325, 1987 528
    Columbia/Nashville, TN
    Proper size hose for oil catch can setup?
    I'm in the process of ordering supplies for my catch can setup, and I'm stuck on deciding what size hose to run. I'm going to be connecting everything with braided line and AN fittings. I'm thinking -12 or -10 line?
    Robbie
    2003 A4 1.8TM
    Motor F21 Turbo, FMIC, Green Tops, Meth Injection, Motoza Tune, Carbonio, Forge DV, Ecode Test Pipe, Neuspeed Catback, 034 Motorsport Solid Mounts
    Suspension Statis SS, Antera Type 309 18x8
    Interior/Audio Pioneer D/D Head, JL 450/4, JL 500/1, JL ZR650's, 2 - 8 JL 8W7's
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Proper size hose for oil catch can setup?
    -10 is what you want, -12 is just way too big.
    This is -10.
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Is the factory nipple on valve cover threaded in or pressed in?
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Apr 04 2007
    That's what I was thinking. I want to go as small at possible to aid in routing.
    I have three more questions though for ya.
    1. Where did you find black AN fittings? I'm not having any luck finding a black tee fitting to go into my valve cover with -10 AN's on either side.
    2. What is that other hose going to in the top right of that picture? Is that for the brake booster?
    3. Is the line going under the fitting in the valve cover going to your fuel rail?
    Robbie
    2003 A4 1.8TM
    Apr 04 2007
    Quote Originally Posted by HIERLEVELZ View Post
    Pressed in. I'm buying another valve cover to extract the fitting and then thread the hole.
    Robbie
    2003 A4 1.8TM
    Feb 12 2009
    03 Audi A4 1.8T
    East Coast
    -10
    Jul 07 2004
    socal
    Quote Originally Posted by LavaSurfer View Post
    1. Summit Racing. Link to Black Summit -10 AN hose ends
    2. The other -10 goes to my crank case breather spot on the side of the block under the intake manifold.
    3. Yes, the -6 braided line with the blue/red AN fitting is my fuel feed line.
    Apr 04 2007
    Your awesome! And that actually the next question I was about to ask. Whether I need a 90 to a straight fitting on the block breather.
    So why do you have the block breather going that direction? I was just going to tee them at the valve cover, go over to the catch can, then route it back to the TIP to create a little vac. Then depending on if I go mafless on a BT setup I was just going to get a valve welded to my DP.
    Robbie
    2003 A4 1.8TM
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    just curious as to what this catch can is for?
    - Caractere - BBS - Kamei - 034 - Stasis - Hotchkis - Stern - Forge - Apikol - Revo - Podi - RNSE - Bi-Xenon - Door Blades -
    If your gunna do it.. DO IT right!
    Jul 07 2004
    socal
    Routed it that direction so the line would run behind the head and into my custom catch can that sits in the stock battery spot.
    Jul 07 2004
    socal
    Quote Originally Posted by downhillracer View Post
    To catch the oil in the vapor that is being sucked out or pushed out of the crank case and valve cover as the pressure builds up when the rpms increase. The stock setup allows the oil to get sucked into the intake, thru the turbo and tends to collect in the IC pipes which will then end up causing reduced flow by blocking up the SMIC or FMIC core. The stock setup is done for emmissions so that the oil vapor is burned as it goes thru the cylinder, but this decreases the amount of power the engine produces.
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    Rob, did you finish the catch can setup? If so how about some finished job pics?
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Active Member Two Rings tibanez's Avatar
    Nov 06 2008
    2005 Allroad 2.7T/2003 A4 1.8
    Chicago/Ecuador
    So you are not going to the TIP?
    Jul 07 2004
    socal
    Quote Originally Posted by tibanez View Post
    nope, just straight vent with the 3 filters.
