Results 1 to 29 of 29
    Veteran Member Three Rings infinitigor's Avatar
    Jul 17 2008
    02' b6 1.8t
    What's wrong with this picture?
    As the title says... yes its a guessing game, but il need some help once you guys determine what's wrong, I'm pretty curious as to how long it will take to realize
    revo//s4 front//sides//s4 rims//h&r//rs4 sway//b5 s4 brakes//rns-e
    Deactivated Four Rings
    Sep 30 2008
    n/a
    Re: What's wrong with this picture?
    Car is neutral. This happened to someone else i forgot what the problem was tho
    Veteran Member Three Rings A4Triple Blk's Avatar
    Jun 10 2008
    Past - 2004 A4 1.8T Quattro 6 Spd
    LI
    the instrument cluster says the lights are on but your dial or whatever you want to call it where you turn your lights on from says they're off ... is that it ?
    B8 2011 A4 Premium+ 6 speed
    Used to B6 it
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Quote Originally Posted by A4Triple Blk View Post
    the instrument cluster says the lights are on but you dial or whatever you want to call it where you turn your lights on from says they're off ... is that it ?
    That was my guess too. That and the fact that his light dial is NOT peeling..... bastard.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    Active Member Four Rings juggernaut201's Avatar
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    blue dash lights
    *JUGGERNAUT*
    (Revo Stage II + HPFP File, AWE Cat Back, DMH Performance Electric Cutout, Forge Diverter/Spacer, Carbonio Intake, AWE FMIC, Snub Mount, RS4 Motor Mounts, S4 Big Brake Kit, E Code TestPipe, KW Variant 3 Coilovers, H Sport F & R Sways, KMD Fuel Kit, KMD Cam Follower, NGK Colder Plugs, Boost Gauge, South Bend Stage 3 Clutch, ECS Light Weight Pulley,Custom Inlet Pipe, 034 Street Mount, Apikol Rear Diff Mount, JHM SS Kit W/ Linkage Upgrade And Weighted Knob Lo Jack
    276hp/331tq
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Your car is out of gas.
    Jul 17 2008
    02' b6 1.8t
    yup thats it... lol to the Neutral comment, Im hoping that it was sarcasm... but yea, i got a new switch a month ago, and now it Turns itself on and sometimes the light that keep the switch on turns off... i have to wiggle it around for it to go on... noticed this problem when a valet car driver put my car on, and the lights went on, im like wtf auto lights?! lol
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    headlights/interior lights are on when headlights switch is in the OFF position
    edit- nevermind, lol
    -Sami-
    Sep 30 2008
    n/a
    Those I believe are the driving lights on the dash or he is VAGed to rest of the world
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    Yeah its the dash being on but light switch off.
    Jul 17 2008
    02' b6 1.8t
    would you rather it peeling, or mysteriously putting the lights on?!
    anyway... should i get a new switch straight from audi, i bought this one here in the classifieds, defective switch? maybe it wasn't made for my car
    Sep 30 2008
    n/a
    Quote Originally Posted by infinitigor View Post
    No it wasnt it really has happened to someone where it just stays lit on "N"
    Veteran Member Four Rings Jibberific's Avatar
    May 21 2008
    az
    it says "WHEN STATIONARY APPLY FOOT BRAKE WHILE SELECTING GEAR"
    instead of "PRESS CLUTCH TO START ENGINE"
    {99.5 Avant}
    Jun 10 2008
    LI
    nicee
    Used to B6 it
    Jul 17 2008
    02' b6 1.8t
    Quote Originally Posted by NvrFllw View Post
    lmfao that sucks... he should get the checked out
    Jul 17 2008
    02' b6 1.8t
    Quote Originally Posted by Jibberific View Post
    no TIP love =[
    May 21 2008
    az
    maybe a tiny bit, i used to have a stratus with "auto-stick"
    {99.5 Avant}
    Dec 06 2007
    I had the same issue, my headlights used to turn on by themselves it was the switch urs may be defective mine is all the LED's burned out after 1 year.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Three Rings gray6spd's Avatar
    Jan 18 2009
    is nonexistent
    texas
    +1
    PREVIOUS:
    2004 1.8T Dolphin Grey- Quattro - 6MT - Sport Package - K&N - 35% - Stage: still in college and broke -
    2015 S4 3.0T Sepang Blue Pearl - DSG - Quattro - DSG - Black Optic - B&O - Sport Diff - Carbon Fiber - Totalled by a damn F150
    CURRENT:
    2015 S4 3.0T Daytona Grey Pearl - Quattro - DSG - Black Optic - B&O - Sport Diff - Carbon Fiber
    2012 Infiniti G37 Sport 3.7L Obsidian Black - Eibach Springs - K&N -
    Proud of my pink coolant.
    Sep 13 2008
    Western Chicago Burbs
    where is the needle for your gas gauge?
    Oct 29 2005
    10speed
    San Francisco, CA
    true I noticed that, I always put up a red flag when I see that problem occur
    - Clint
    Jul 29 2008
    2003 A4 1.8TQM5
    PA
    Quote Originally Posted by B6JoeA4 View Post
    That's what I was going to say.
    Jan 06 2009
    Your car is converting to Canadian with daytime running lights
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Jul 17 2008
    02' b6 1.8t
    you know... its amazing how low the gas needle can go before the car actually runs out of gas... so what's the consensus... do i need a new headlight switch? or should i just sell the car and get a manual to get "apply brake to select gear" message off the dash lol?
    i was actually learning the past couple of weekends on my cousin's e39 m5... im not 2 bad... didn't even stall too much, but to reverse on that car is so weird... i wanna get stick but its like impossible to just switch cars
    May 24 2007
    Southern California
    when my headlight switch is off, the headlights are on too. I have no idea what it is.
    Kyle
    2.0L Revo GTRS Eliminator
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Except for light switch ( VAGed I guess), don't you need to be in Park to start a car? At least all American cars had that issue. And yet your car is running with that dialog on the screen. Very puzzling.
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    when my light switch is in that position that dashboard light is on and it means my fogs and DRLs are on...
    i might be missing something
    two thousand two audi a-four quattro five speed
    Veteran Member Four Rings nein-reis's Avatar
    Feb 01 2008
    MK6 GTI, MK1 GTI 1.8T, B7 A4 TE Avant
    SLC, Utah
    The real problem I see here, there is no check engine light.
    -Tyler-
    Built 06A/IE Cams/IE 2.0 stroker/GT3076/6MTQ
    Dan Shank Super Tuned
    It was a fun run, but the time has gone.
    Account Terminated Four Rings
    Feb 12 2009
    03 Audi A4 1.8T
    East Coast
    LOL
