Results 1 to 39 of 39
    Veteran Member Three Rings Shady Milkman's Avatar
    Jul 20 2004
    04 A4 QTM
    Morris Plains, NJ
    Those of you with 18inch wheels, what size are you tires?
    Im trying to decided between 245/40R18 and 235/40R18
    What is everyone else running?
    -Jonathan
    04 1.8tqm
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    Re: Those of you with 18inch wheels, what size are you tires?
    depends on the width but you should really go 225 or 235
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Between the two, I'd personally go for the 235's. 245's look like balloon tires IMO.
    -Darrick
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    235/40/18
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Dec 06 2007
    245/40 ZR18s and they are thick but ride great.
    -Kirk
    BetaAlphaTau Member #58
    Jun 21 2005
    Milton, Ontario
    go with 265/35/18
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Jul 20 2004
    04 A4 QTM
    Morris Plains, NJ
    Quote Originally Posted by vintagespin View Post
    18x8.5 with a 35 et
    -Jonathan
    04 1.8tqm
    Established Member Two Rings mullardel34's Avatar
    Nov 26 2008
    `03 A4 3.0L Quattro (manual)
    Midwest US
    Quote Originally Posted by Shady Milkman View Post
    Remember, in order to maintain the calibration of your speedometer, the determining factor on tire sizes is ensuring that you keep the same overall tire diameter when selecting an alternative wheel/tire sizing. While it seems like it should be straightforward mathematics to multiply the tire's tread-width by the tire's sidewall percentage of tread-width in order to determine the effective tire side-wall height, you can encounter some surprises. With my Sumitomo HTR+ tires, size 235/40ZR18, that should produce a tire side-wall height of 94mm (235mm x 0.40 = 94mm). However, there's some variability in how the tire manufacturers measure the tread-width, which can result in some unexpected differences in the overall diameter of tires that have the same size specifications.
    A really great tool for helping you in determining tire sizes for your car is the on-line wheel/tire shopping tool at the Tire Rack (http://www.tirerack.com/wheels/). Just select the make and model of your car on the pull-down menus, then select a wheel with the desired diameter and width. Pick an appropriately sized wheel and select the "Add to Cart and Shop for Tires" button. You can now select any tire model and the tool will tell you the recommended size for the wheel diameter/width that you previously selected; the Tire Rack's extensive database of actual tire measurements ensures that you're provided with the proper tire size.
    Mullard EL34
    * 2003 A4 3.0L Quattro (6-speed manual)
    * sport package
    * 18"x8" Moda MD5
    * Sumitomo HTR+ (235/40ZR18))
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    I concur, 225 or 235. I have 235/40 and sometimes I debate going with 225's.
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    I've got 235/40's all the way around on 18x8's
    02 A4 3.0Q6MT
    -chad
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    225/40/18 gets my vote =)
    On a 8.5" wheel , you still get a slight stretch, and the performance as well!!!
    another stereotypical Audi
    Dec 06 2007
    i'm running mine on 18x8.5 ET35 too
    -Kirk
    Jul 20 2004
    04 A4 QTM
    Morris Plains, NJ
    Quote Originally Posted by AudiA4Turbo22 View Post
    i see youre on neuspeed race/bilsteins, any rubbing?
    -Jonathan
    04 1.8tqm
    Senior Member Three Rings Boston_USP_327's Avatar
    Nov 24 2008
    2004 A4 USP 1.8T 6MTQ
    Grafton, MA
    Quote Originally Posted by akaEsCo01 View Post
    +1... i have 235/40, but i think my next set will be 225/40
    USP CLUB MEMBER #327
    Semper Fi.
    Jul 20 2004
    04 A4 QTM
    Morris Plains, NJ
    those of you voted for 225 do you normally like the stretched euro look?
    -Jonathan
    04 1.8tqm
    Sep 07 2007
    San Francisco, CA
    I'm running 225/40/18 on 18x8 et35, lowered on SS coils. No issues.
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    235/40/18
    Some fast things and some slow things
    ~Josh~
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    235/40/18 18x8 et35
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    235 40 zr18
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    I made the mistake of running 245/40/18 on my Avant w/Avus S4 18 x 8 et 38. I get some rubbing with my suspension setup. Def 235/40/18 or possibly even 225/40/18 next set of tires.
    Here's a useful tool for calculating tire fitment issues. Click
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    between 235/40 and 245/40
    I vote 225/40.
    Veteran Member Three Rings dewey527's Avatar
    Mar 10 2008
    '02 a4 1.8tq, '05 tahoe
    Puyallup
    235/40/18x8.5 with stern wheels that i think sit perfectly in the wheel well.
    mods - not enough for me and way too many in my wife's opinion
    K04, Revo "Stg2", PODI Boost Gauge, TT225, fmic, Forge DV, Tantrumwerks 300cell HFC, Neuspeed Exhaust, Stasis Touring Suspension, Spec Stg2 & LWFW, 034 RSB, Neuspeed SS, Neuspeed Snub, Neuspeed TIP, B6S4 front brakes, Tyrolsport Kit, 6K HID, Yellow Fogs, 20%, CC
    Mar 23 2007
    03 Audi A4, 2004 s4 cabriolet
    Rochester, NY
    Ive got 225 in the front, and 235 in the rear, running 18x 8. I had to take out my spacers in the rear because I was rubbing with the 235's. I wasn't when I had 225's all the way around, which seems weird to me but whatever....
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    235/40/18 but my KDW's run a little wide...
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by tlcaudi View Post
    What size spacers were you using that caused rubbing? I am currently running 18x8 et35 with a 235/40 and would like to push the rears out a little. I was planning on running 10mm.
    TIA
    Mar 27 2005
    The Cold North
    i run the 245-40-18 on a 18x8 w/ 35mm offset.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    235/40/18 is perfect. no rubbing. you can put 245 on the back.
    i kept your wheel spec in mind.
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Dec 06 2007
    yes i mean there is like no room in the back haha and the front has a 1/4 finger worth of space.
    -Kirk
    Aug 12 2004
    2002 Audi A4
    Glendale, CA
    235/40/18 on 18x8 all around
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    not to thread jack but ive been thinkin the same thing. Me living in NYC with these Pluto sized potholes, i need a full sidewall to protect my rims and i was thinking of running 245 on 18x8 plus im not into the whole stretch thing.
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Mar 23 2007
    Rochester, NY
    TIA
    I was running 12mm I believe in the back, I switched early last year, so can't remember but it was definitely over 10mm. I believe if I went with 10mm it would be perfect, but I've had a hard enough time keeping this thing on the road over making it look the exact way I want it too!!! I'm also riding pretty low, though....
    Senior Member Three Rings mtshank's Avatar
    Mar 26 2008
    B6A4 | 01 V70 | 73 Jeep Commando
    Salmon Creek, WA
    225/40/18 Kuhmo ASX on Avus 18's
    | UNITRONICS | FORGE | H&R | BILSTEIN | TECHTONICS | BORLA | BOSCH | LAMINIX | MATRIX INTEGRATED | A.S.S. |
    The Northwest's Premier Audi Group
    BLACK DOORBLADE ALLIANCE MEMBER #4
    Veteran Member Three Rings djsnowman777's Avatar
    Apr 22 2008
    Queens NYC
    can u run 245 45 18 with offset of 48 ? s4 avus wheels somebody local is selling avus s4 wheels and tires for 800 so i want to get on it but will i have rubbing issues with stock suspension a4 ? i contacted the guy if the set up is for real
    Jul 27 2004
    Bay Area 925
    Quote Originally Posted by djsnowman777 View Post
    No issues at all
    Only issue would be when you lower the car. But with that high of a offset, i would seriousy think about getting 15mm spacer...esp when the wheels are only 8" wide
    Sep 15 2008
    CO
    somebody just post up pics already
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    225/40-18
    u'll have better rim protection w/ the 235's... but the 225's are fine
    <--------yes, i used my audi to drag my deer out of the woods. it was heavy, i was cold, car had heat, much less work, and frankly, it was far. the deer was big, i am not, just seemed like the right thing to do. if it werent for the apr2+ i may not have been able to pull that monstrosity out of the woods w/out a helicoptor. i cant afford a helicoptor, i have a hard enough time affording my audi. all this being said, yes. that is an apr2+ awd audi pulling a deer out of the woods.
    Mar 27 2005
    The Cold North
    tire is too large. a 245-40-18 is more approiate.
    2020 Chevy AEV ZR2
    Senior Member Three Rings vc1492a's Avatar
    May 04 2008
    Knoxville, TN
    235/40/R18
    2010 A4 2.0T S-Line Cab (CVT)
    2004 Stage 2 Mini Cooper S
    Sold: OEM+ 2005 Audi A4 USP 1.8T
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    Quote Originally Posted by EBG 18T View Post
    can you run 245-45-18 on a stock b6 a4?
    i think it will fit perfect in the rear but in the front im thinking it will hit the tie rod..
