Results 1 to 35 of 35
    Established Member Two Rings Robv27's Avatar
    Dec 27 2006
    Richmond VA
    2.7T vacuum lines diagram????
    Hello, Does anyone have a diagram for the 2000 2.7T models? I have a vacuum leak somewhere and can't figure out where... It sounds like it's coming from the TB area, but did not see anything there, I even replaced the TB gasket to the intake manifold, And i believe this vacuum leak is the reason for mt missfire code on cyl #6... anyway, if anyone has a vacuum diagram it will be greatly appreciated, and BTW, does anyone know a good trick to find vacuum leaks, I tryed the starter fluid on all connections but that did'nt work
    Any help will be greatly appreciated
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: 2.7T vacuum lines diagram????
    No idea where a diagram would be. I'm assuming you checked your throttle body boot?
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Veteran Member Three Rings Justin:NorCal's Avatar
    Feb 08 2008
    2000 Audi S4 (new build), 2000 Audi S4 Stage 3 (stolen last year)
    Dublin, CA
    Dec 27 2006
    Richmond VA
    Quote Originally Posted by s42k5b View Post
    yes, i actualy replaced it about 6 months ago... Thanks anyway!!!
    Dec 27 2006
    Richmond VA
    Quote Originally Posted by Justin:NorCal View Post
    Just what i'm looking for!!!! You're the man!!! Appreciated
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    has someone changed all there vac lines to hose techniques or anyone else for that matter?
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Veteran Member Three Rings NOVAS4's Avatar
    Sep 02 2007
    2003 Audi RS6
    Woodbridge, Virginia
    let us know where you find it!!
    Current: 2003 Audi RS6
    Current: 2008 Acura RDX Tech (daily driver)
    Previous: 2013 Hyundai Genesis Coupe 3.8, 2006 Acura TSX, 2008.5 Mazdaspeed3, 2000 S4 Sedan 6sp stage3-, 2004 Subraru WRX
    Jan 21 2007
    01.5 Silver Avant
    dc
    whats the diameter of our vac hoses???
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    take all the covers off, and with the engine running start spraying brake/carb cleaner all over the intake and vac hoses... Once you hit the area where the leak is, the car should stumble. That's the area of the leak.
    Jan 21 2007
    01.5 Silver Avant
    dc
    so noone knows if its
    3.5mm
    4mm
    6mm
    8mm
    what size are our vac hoses, or are all of them different.
    Registered Member Two Rings Knight_Rider's Avatar
    Feb 26 2008
    Go f*ck yourself!
    Quote Originally Posted by Robv27 View Post
    depending on your how old/how many miles your car is, it's prolly a torn TBB.
    inspect that area for sure. have someone get on the throttle while you are up front around the bonnet. you should be able to narrow down where the hiss is coming from. when i tore my TBB's many many ages ago... it looked fine, but upon further inspection it was completely torn apart underneath. i could stick my fingers into it.
    but if you want a diagram, there is a small diagram of the whole vacuum system on the inside of the hood on the pass side closest to the dash. its very small, but has all the vacuum connections. hard to believe but true. it looks like a certification sticker, but look closely... DIAGRAM! =)
    I am Michael Knight, my car is K.I.T.T.- The Knights Industries Ten Thousand, my organization is F.L.A.G. I am powered by Garrett/Honeywell and GenerationJDM.
    Dec 27 2006
    Richmond VA
    =Knight_Rider
    Mine is missing!!!
    Dec 27 2006
    Richmond VA
    Quote Originally Posted by Knight_Rider View Post
    inspect that area for sure. have someone get on the throttle while you are up front around the bonnet. you should be able to narrow down where the hiss is coming from. =)
    I did replaced about 3 month's ago... it was ripped almost in half and i did'n even have this vacuum issue... It's really weird... it really sounds like it's coming from the TB area... Thanks for the input man
    Dec 27 2006
    Richmond VA
    Quote Originally Posted by NOTORIOUS VR View Post
    I did that too, w/ starter fluid and no luck!! it idles low and misses on #6 and you can deffinately hear the vac leak!!
    Dec 27 2006
    Richmond VA
    Quote Originally Posted by casawhites4 View Post
    3.5mm
    4mm
    6mm
    8mm
    I do have all the stock vac hoses except for the 2 DVs, had to replace those before. i think all the sizes you mentioned above are the vac hoses we have...
    Veteran Member Three Rings audikidS4's Avatar
    Sep 03 2008
    2001.5 S4 Avant 6spd - Sil/Blk, 1995 S6 Avant - Blk/Ercu
    Wareham, MA 02571
    I bought 3.5mm (several feet) from BlauParts and used it to replace some rotting hose around the back of the engine where my boost gauge taps in and also used it at my DV valves. Seems like the perfect replacement size for those areas at least.
    The original audikid! Coined as ebay username spring 1999.
    **MTM ECU, Piggies, ASP Tru-Duel, Stratmo ss kit, Stern sm, AWE DTS, Voltgland GT2, Neuspeed 19mm RSB, full Samco kit, drilled and slotted rotors, PODI/S-W boost gauge, Sportec pedals, 30% Huper optik, CCMod, stubby antenna, VMR 708s 18X8.5 32mm**
    Dec 27 2006
    Richmond VA
    Quote Originally Posted by audikidS4 View Post
    BTW, on my boost gauge i'm getting 14 Vac when idleing, if i remember correctly i used to get around 20 vac. It's been a while...
    Established Member Two Rings CTAudiDriver's Avatar
    Mar 17 2009
    ME
    Any luck finding the vac leak???
    I'm having the same exact problem right now, I've done everything and am currently in the process of looking for a vac leak. I'm missing on cylinder 6 (as well as the rest of the cylinders although not nearly as much) and its only under light load driving
    Senior Member Two Rings momento1's Avatar
    Feb 04 2008
    AUDI 2002 S4
    Sydney, Australia
    if you still have original plastic T pieces then check the one under the Y-pipe.. theres a hose which comes from the top of the manifold and Ts off to the N249 valve... i had a crack in that T piece which could not be seen by eye
    just like you described, i could hear it... but couldnt find it for ages
    CURRENT - Audi 2002 S4 Nogaro Blue Pearl - Stage 3+ 335Hp atw (but something isnt right...)
    PREVIOUS - Audi 2001 S3 Silver - 230Hp atw
    Senior Member Three Rings jakecro's Avatar
    Feb 08 2007
    '00 S4 6MT 324K mi stock K03s
    Pittsburgh
    follow link to my site in my sig; vac diagrams in there.....
    site rework in progress so ignore the mess
    -Jake
    [email protected]
    www.audidatabase.com <--feel free to contribute material
    new siggy
    710Ns|CC|VDO Vent Boost Gauge|Piggies|LW Crank Pulley|034 Snub|Hawk HPS|K&N|Continental ExtremeContact DW
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    look on your hood. EVERY B5 S4 has a diagram there.
    l gotta-- l gotta get
    a form from a scientist.
    Senior Member Three Rings PluschakovP's Avatar
    Jul 05 2010
    NW Washington
    so which vacuum line do you connect a boost gauge into? just doing some research...
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    Quote Originally Posted by PluschakovP View Post
    Here's a pic. Though mine doesn't have it, the hose you connect to has some sort of fabric cover on it. This will give an idea of where it is:
    It's the T-fitting. The hose that goes to the right connects to the Fuel Pressure Regulator (FPR) that you see at the bottom of the pic (it has the sticker on it with Audi rings and AK on it).
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Jul 05 2010
    NW Washington
    Quote Originally Posted by Mooseimage View Post
    OKAY, so I got it defined to 2 hoses now. The Left or Right threaded one? I'm guessing the Right One since it goes right into the FPR. Here's a pic of mine, let me know.
    Jul 05 2010
    NW Washington
    I suppose this threaded line, hence it goes into the Fuel Pressure Regulator. Cool, thanks a lot!
    Feb 15 2008
    Sacramento, CA
    Right threaded one. You got it.
    Jul 05 2010
    NW Washington
    Sweet, thank you so much! Installing a boost gauge is so much easier than I thought :)
    I'll go search for some gauges and get one installed as soon as I can.
    Oct 11 2011
    Kawasaki Ninja
    Bountiful, UT
    Some shops have what's called a vacuum leak tester. It basically blows smoke into the vacuum lines, and wherever the leak is smoke will come out! You could check with the local high-school auto shops and see if they have one they'd let you use for a minute.
    I know it's a year late, but I figure there will be someone else with the same issue.
    Apr 28 2013
    2001 Audi A6 2.7t, 1981 yamaha dt175
    Oshkosh, Wisconsin
    Hey I don't suppose anyone would know which vacuum line to t into for a boost gauge?
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Jul 30 2013
    Yuma, AZ
    Does anyone happen to know what size vacuum lines are on a 2000 A6 2.7t Quattro...I know there are at least 3 different type; one larger, one smaller, and one that has a woven casing. Any pointers in finding a suitable replacement for all these would be helpful.
    Aug 05 2011
    Memphis, TN for now!
    The above vacuum diagram doesn't really show the PCV system. There is a line that comes off the bottom center of the intake manifold...spray there. Also, the intake manifold gasket may have a leak.
    Have you done a pressure test?
    Jun 22 2015
    Martinsburg, WV
    Im having troubles finding my boost leak. Ive replaced both dv's, spider hoses, wastegate sensor and my mas, but too no avail. Are the downpipes coming from the dv's to the turbos or wherever they go supposed to be welded or have clamps? Mine are loose and im assuming thats part of the problem but not sure. Any advice?
    Established Member Two Rings xb6boix's Avatar
    Nov 06 2012
    Houston TX
    Quote Originally Posted by BigDWV View Post
    Yea there supposed to be a bolt that's holds it in place..
    having four rings is a lifestyle
    Jun 22 2015
    Martinsburg, WV
    Thanks! Im going to guess theyre not on theyre. Would ECS tuning have them?
    Sent from my SAMSUNG-SM-N900A using Tapatalk
