Results 1 to 15 of 15
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    Symptoms of a bad MAF?
    Hey guys, Ive been wondering the symptoms of a bad MAF. My car has been sputtering at idle. Ive changed the plugs, coilpacks, and tried cleaning the MAF. Ive been getting multiple misfire codes on cylinders #1 and #2. After cleaning the MAF, the car is doing the same thing, where it sputters and idle is really rough....
    I have a K&N and i think thats why my MAF maybe going bad....
    I hate this part of owning an Audi $hit!!
    another stereotypical Audi
    Sep 13 2008
    Western Chicago Burbs
    Re: Symptoms of a bad MAF?
    Jursch2211 scanned my car and found that my maf is pooping out. I als had multiple missfire codes. my car only has 56k. I guess its sort of normal for theses thing to kick the bucked every once in a while.
    I have a 3.0 and a stock paper filter
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    it sounds like the maf...does it try to shut off on your when your at a stop
    211,000 miles
    ||Borla||forge dv||35%||awe||k&n||autobahn hoses||awe smic||ssac||walbro 255||
    Veteran Member Four Rings jursch2211's Avatar
    Feb 05 2008
    Illinois
    Lean codes!!!
    || APR | BW K04-015 | ER FMIC | OEM S4/RS4/R8 Parts | '10 RNS-E | Hotchkis | Adam's Rotors | Podi | OCarbon | Euro Headlights | Euro Color DIS | Euro MKII TT MFSW | Euro Trunk | BBS | Vogtland Coilovers ||
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    Maf or cts/ect (coolant temp. sensor/engine coolant temp.)
    - Caractere - BBS - Kamei - 034 - Stasis - Hotchkis - Stern - Forge - Apikol - Revo - Podi - RNSE - Bi-Xenon - Door Blades -
    If your gunna do it.. DO IT right!
    Jul 27 2004
    Bay Area 925
    ^^ wow I have both those codes. I am buying a new MAF tomorrow, and getting my ECT as well
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    damn earl your car has been running into a shitload of problems recently..
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Jul 27 2004
    Bay Area 925
    its time to sell this money bag
    Aug 20 2007
    97 Jeep Wrangler
    ^ no way! don't do it haha , btw what's a jeff pipe.. some sort of home made test pipe made by jeff haha
    Jul 27 2004
    Bay Area 925
    Its the PSI testpipe that Jeff sold here on AZ a couple years ago.... Its 2.5", its worked out great for my current setup.
    Aug 20 2007
    97 Jeep Wrangler
    ^ right on
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Quote Originally Posted by a4wd View Post
    wanna buy my maf sensor, no housing?
    Veteran Member Four Rings mnkyA4's Avatar
    Aug 10 2004
    The City
    a2wd you ever pick up the sk04 that I ended up not getting?
    03' 1.8T A4 Avant Tiptronic ----- SOLD!!!!
    FUTURE: 2013 Ibis White Q5 3.0T
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    Quote Originally Posted by downhillracer View Post
    I don't know how the name "Jeff Pipe" was ever coined...haha.
    Feb 18 2004
    Los Angeles, CA
    'tis the season to be blowings MAFS (cold air, dense air, and "turbo weather).
    There are two ways to diagnose symptoms of a bad MAF.
    Method #1: "Buy another one, you rich motherf*cka!" -Rick James/David Chappelle
    or
    Method #2: The "educated" and possibly cheaper method, using deductive reasoning.
    Ok...this is what to do: Do you have a VAG-COM?
    Go into your measuring blocks, and go to Group 003. There, you will see your grams/sec readings from your MAF. At idle (with engine warm at operating temperature), it should be around 2.0-5.0 g/s (grams per second).
    During this same time, also measure group 033, this tells you how much % of fuel is being added or taken away out of your A/F mixture (it should typically be only a few percent +/-).
    Also, measure group 032 (same time as well). This is your Long-Term Fuel Trims...or adapted fuel trim based on 033 above. This is an aggregate of block 03xx above, of the "learned" values of driving the car through time (in percentage)... get that number.
    I want to see if your MAF is actually working or doing it's job, or is it something else. Even a BAD MAF could still give you the 2.0-5.0 g/s readings, so that is why it's good to know if your car is leaning out or being too rich. I can tell you to get into your lambda (O2 sensors) settings as well, but that will be next. Typically a bad MAF is more likely to give you rough idle than a bad O2 (wideband) would.
    Finally, after you get these readings, go into your fault code section, and "Clear Codes" (whether you have codes or not), this will reset all adaption. Now turn off the car, unplug the MAF, and fire it back up and read groups 032 and 033 again. Now watch the percentage or short term and long term idle trims, and look at how much it adds/subtracts now. Of course, should your idle stabilize, your trims would either be leaning out (you were too rich before), or richening up (you were getting lean missfires before)...this will conclude that your MAF is 100% "dead".
    Good luck.
