Results 1 to 33 of 33
    Registered Member Two Rings
    Oct 28 2007
    PA
    P1545 Throttle Valve Controller: malfunction and EPC light
    Does anyone know what would cause this? It started throwing the code intermittently the other day and now as soon as I clear it it comes back and throws me into limp mode.
    Checked for boost leaks and there are none.
    FS- Giac X Ecu $350shipped
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: P1545 Throttle Valve Controller: malfunction and EPC light
    Quote Originally Posted by noclutch View Post
    Have you done any work on the car lately? Removed anything from the area of the TB? You can try to do a throttle body alignment and also maybe pull the ECU for a bit and see if it helps but, that's not a good code to get. Could be the throttle body itself.
    08 S4- Stock SOLD
    Oct 28 2007
    PA
    Yes I modified the FMIC pipes, although I didn't do anything it the area of the t-body or bi-pipes at all. And it took about 10 minutes of driving to throw the code the first time. I'll try to do an alignment. Thanks
    Oct 28 2007
    PA
    Tried To do the throttle body adapt through Vag-com Block 060. Couldn't do it, it just said ERROR in the far right box. The original code eventually went away but then came up with 2 codes about not being able to adapt the TB.
    17972 - Throttle Actuator (J338): Under-voltage during Basic Setting
    P1564 -35-10 - - - Intermittent
    17967 - Throttle Valve Control part (J338): Fault in basic settings
    P1559 - 35-00 - -
    Looking at the voltages while operating the throttle, everything seems fine.
    Jan 29 2007
    08 S4 00 S4
    MD
    P1559 - 35-00 - -
    Did you unplug the ECU? Maybe take the throttle body out and clean the contacts as well as the TB itself. I don't know, it's not lookin good though..
    08 S4- Stock SOLD
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    could be the ecu going bad
    Oct 28 2007
    PA
    I haven't pulled the ECU yet. I just cleaned the tps contacts with some QD. I'm gonna try to run the adapt again.
    Then I guess I'll pull the ECU and see if I can find any component damage.
    In the 2 months or so that I've owned this car I found the rear diff mount broken, trans needs a rebuild, rear makes noise, o2 sensors were facing downward and bottoming out, fmic piping interfering with the bumper, a misfire that won't go away, and now this. I love this car! :)
    Oct 28 2007
    PA
    ECU looks fine. I took a video of what it looks like with the TBB off when I try to run the adapt. I'm assuming that the TB is supposed to swing all the way open. I think I'm just going to start looking for another TB.
    Oct 28 2007
    PA
    Anyone have any more input?
    Oct 28 2007
    PA
    Does anyone know how to test the throttle body? I want to narrow it down to either the signal coming in or the throttle body itself.
    Thanks
    Active Member Four Rings nthusiastt's Avatar
    Oct 27 2008
    B5 S4 Avant
    Thanks
    Leave the charge pipes off and have someone start the car and pump the throttle to see if the plate opens completely. Is it possibly to reset the ecu with the VAG-COM? It sounds like an electronic issue based on what you've been doing. I doubt you'd have to replace the entire assembly.
    They want you afraid of your neighbors, your community, your family, your ability to support yourself, terrorists, climate change, China, Russia, Covid. As long as you are afraid, and won't unite red or blue, they win.
    Jan 29 2007
    08 S4 00 S4
    MD
    Thanks
    Measuring blocks for the throttle body should be in group 060-069. Did you just do the alignment, what else was measurable?
    08 S4- Stock SOLD
    Oct 28 2007
    PA
    It looks like its opening when the car is running. The TB alignment definitely isn't working though as seen in the video up there. No idea on what would cause that.
    Oct 28 2007
    PA
    The ECU reads it as working correctly when I log those blocks. It sees the correct percentage when opened and shut and everything in between.
    Jan 29 2007
    08 S4 00 S4
    MD
    I don't know man, I'm out of ideas. Maybe find someone local that can let you swap in a known good throttle body before you buy one, just to make sure.
    08 S4- Stock SOLD
    Oct 28 2007
    PA
    Thanks for your help man, I appreciate it.
    I figure if I push it into the lake near my house that it should fix it.
    Oct 28 2007
    PA
    Ok so now I'm getting this code that again pops up everytime I try to clear it.
    18012 - Internal Control Module Driver Error
    P1604 - 35-00 --
    I'm assuming now that the ECU is bad.
    Long Island, NY
    Quote Originally Posted by 2001S4NY View Post
    looks like i win
    Oct 28 2007
    PA
    Looks like the ECU was fine, replaced it and I'm still unable to adapt the throttle body.
    Does anyone know if there's anything else between the throttle body and ECU? I'm probably going to replace the TB next but I'm open to suggestions.
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    New TB is what you need most likley.
    -02 F'in Silver. GT2560/s AWE, ER/s RS3 Wheels, KW/s and every other typical S4 upgrade.
    Oct 28 2007
    PA
    Got a working used TB in there. Still will not even try to adapt, it just says "ERROR" on the Vag-com status box when I try. Tried both ECU's and the same thing happens.
    I've cleared the codes several times, is there something else that could be stuck in the ecu's memory that I have to clear? When I clear the codes the only thing that comes up is 'Adaptation not Started."
    Oct 28 2007
    PA
    Just wanted to update. After messing with the car with the new throttle body and the old ECU I got it to adapt finally. I drove the car a couple times and the EPC light popped on again and the same code popped up. I got a PM from another member on here having the exact same problems and the other day I found out that someone who lives a few blocks from me is also having the same problem with the same symptoms. I'm going to try to get in touch with that guy but if anyone has anymore suggestions I'm all ears.
    So far
    -changed throttle bodies
    -changed ecu
    -checked continuity through wires
    -cleaned/tightened harness connection
    May 16 2007
    Irving, TX
    post updates on your diagnosis / fix if you got em!
    I just started having similar issues. The car drives fine, then if I park it and try to restart within a few minutes while the engine is hot, it either wont start and I get 17953 and 17966 error codes OR I get super-limp mode with CEL, EPC lights and car won't rev over ~2k. Hopefully you got it figured out and will share your wisdom!
    Oct 28 2007
    PA
    I'm still stumped at this point. I keep thinking its fixed, drive it a few times then it seems to come back. Now I have problems with the idle creeping up to ~1100rpm when the car gets hot, it doesn't throw a code when this happens.
    Check your wiring going to the throttle body, mine doesn't have the little clip on there so its zip tied tightly.
    Nov 18 2008
    2018 Passat R 1999 A4 2.7t stg 3+ 2019 Tiguan
    Chicago
    Any update?
    this just happened to me too, but here's my story:
    Car would not go over 2k rpm, turned off and on, worked fine for 24 hours and roughly 100 miles of mixed driving, city/hwy, hard pulls, etc.
    Today EPC light on, car died, will crank but won't start. Got an another ECU, car started but runs like crap, misfiring, sounds like a coil has gone bad, will replace the bad coil and see what happens, and the EPC light is still on. Will try to find out whats going on tonight.
    Go BIG or GO HOME!
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    I had an issue with my race ecu and the throttle body on the dyno at Waterfest 07. The dyno operator couldn't get my car to go past 1500rpms on the dyno no matter how far down the pedal went. But after disconnecting the ecu and connecting it again it worked fine. But as soon as I got off the dyno it was doing it again. But as soon as i switched back to my pump gas ecu it was fine. Turned out to be a bad ECU got a new one and have had no issues with it. However are you experiencing throttle cut? and or rpm issues?
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    Nov 18 2008
    Chicago
    Yea, figured out my problem, the fucken ECU was fried, long story short, if ever swapping motors, make sure you have SECURE grounds. So disappointed right now, but have to give BIG THANKS to Jason(JHM) will be helping me get a new ECU in the next few days. On the bright side, the car pulled really hard before can't wait to get her back on the road.
    Go BIG or GO HOME!
    Oct 28 2007
    PA
    I zip tied the harness for the TB as tight as I could and the problem hasn't come back, I'm pretty sure thats all it was.
    I never had a no-start problem like yours, Paul.
    Nov 18 2008
    Chicago
    Yea its my ECU for sure, I opened it up and you can see the part that burned, its just really funny how we had the exact same symptoms.
    Go BIG or GO HOME!
    Active Member Four Rings CrtchRktRcr's Avatar
    Feb 25 2009
    CRF50
    Scottsdale AZ
    finally a thread with a solution! My roomate is having this problem and throwing code p1545.
    AEB B5 A4, QUATTRO MANUAL SPORT-H&R,FORGE,1BAR,5BAR,BOOM
    xbox live: Cr0tchf4i
    ["im in the computer lab and some dude with about 8" just sat down next to me -S4Jet"
    WWW.ASKMY2CENTS.COM
    Mar 29 2007
    Modded GS-T
    West Chester
    i know this thread is old, and i have a VW but i havent found a fix yet and its getting really upsetting. I have a feeling it's the ecu although I havent run an adaptation yet. I bought a unitronics ecu and upon install, i got the epc light and all the codes mentioned above. I dont have any of those silly tools to get the ecu open yet to look for damage but has anyone reached a fix for this yet? well nevermind on the fix, guess i gotta open the ecu and hope for the best :-/
    Mar 29 2007
    Modded GS-T
    West Chester
    nevermind. ecu=fried. great.
    Oct 26 2010
    KALAMAZOO, MI
    sorry i know this is old but i just had the exact same problems you did. do you mind telling me what exactly the harness for the TB is?
