Results 1 to 14 of 14
    Veteran Member Four Rings italia8287's Avatar
    Jul 23 2008
    New York
    tire rotation question
    since the quattro is 50/50 is it necessary to rotate the tires?? im assuming the answer is still yes but just wanted to make sure.
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Veteran Member Four Rings Grishbok's Avatar
    Apr 15 2008
    Reston
    Re: tire rotation question
    yes because its not always 50/50, it constantly transfers power via the center dif.
    2008 A4 Quattro Brilliant Black
    *SOLD*
    StreetTunedTV.com
    You are violating the 3 rules of forum posting.
    1. Title thread appropriately
    2. Use the search first
    3. If you didnt find what you were looking for, its because someone else didnt follow #1.
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    I would actually assume no for the most part. But based on my driving habits I tend to wear out the fronts a lot sooner than the rears (especially the outsides of the front tires). So I would suggest rotation if you tend to pull high G's when making turns.
    2006 Audi A4 2.0T Quattro 6MT S-line
    Veteran Member Three Rings AlexK's Avatar
    Sep 11 2007
    San Mateo, CA
    You should rotate front to back because your fronts will wear faster since they are steering.
    Jul 23 2008
    New York
    Quote Originally Posted by AlexK View Post
    thats what i was thinking. thanks!
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Senior Member Three Rings MichiganAudiDvr's Avatar
    Nov 19 2008
    2007 Audi S4; 2007 Chevrolet Tahoe LTZ
    MI
    Exclamation Re: tire rotation question
    Actually, you might be surprised by this but the Quattro makes each tire work especially hard, all in different ways, and frequent rotation is recommended.
    In fact, when you get a set of new tires Audi recommends rotation after your first 5,000 miles, and...after buying a new Audi with Quattro, Audi covers your first tire rotation at the 5,000 mile service interval free of charge.
    I keep the pace, rotating and balancing every 5,000. It's a good practice. I actually went 10,000 miles without rotating, and developed cupping quickly which diminished ride quality and increased road noise. I ended up just replacing the set as a result. I won't make that mistake again - now I follow the book on rotations and balance.
    Enjoy.
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    cupping at 10,000 miles? May want to check your alignment, you probably hit a pothole somewhere.. rotation and balancing has nothing to do with that... loose tie-rod possibly. You should not have to re-balance your wheels every 5,000 miles.. they stay balanced unless you curb them or damage the tires or wheels somehow.. also, if you are adamant about exact tire balancing, get them road force balanced.. tires that create excessive road force are almost as bad as tires out of balance.
    As for rotations, yes you do have to do them, because even though most of the time, most of your power is in the rear wheels, when you brake and turn, your front wheels are taking a lot of wear.. I find that on this particular car, you don't have to rotate too much... I recommend 5,000 - 10,000 miles.. maybe even more, its good to get a tread gauge.. its a cheap investment to make sure you use your tires to their full extent.
    2008 Phantom Black TQM
    Veteran Member Four Rings ataylor's Avatar
    Dec 15 2008
    snowboarding, computer, and mountain-bike parts
    Golden, CO
    I noticed my fronts wearing, and asked the dealer if I should have them rotated, they actually said "no" because "the back end will slide out on these cars before you'll have trouble in the front"
    D:
    History: MK3 Jetta 2.0 MT; MK3 GTI VR6-SC; B7 A4 6MT STG2; B8 S4 DSG; B8.5 S4 DSG
    Nov 19 2008
    MI
    Quote Originally Posted by Subaru71 View Post
    Actually, we thought it was the alignment - which was done 3 times (didn't fix the issue) - I did the road force balance, twice, but that didn't fix the problem entirely. And, yes, I am particular - and didn't hit any potholes (even though I drive in Michigan, I can usually avoid them, ha ha.)
    I had the car looked over from head to toe at the dealer and at an Audi shop, everything else was good no tie rod issues, etc. I replaced the tires and "gone" like a miracle. (They were Goodyear LS2's - and I also hate Goodyear after this experience.)
    Also, the new tires do stay "mostly balanced" -- but for me the balance and rotation is free at my tire place whenever I want it, so I always have them do it at the same time...and no more problems.
    Nov 19 2008
    MI
    Quote Originally Posted by ataylor View Post
    D:
    HUH? I would love to hear that guy explain his statement to Audi of America.
    "Ya...I just tell my customers to wear out their tires unevenly and prematurely and replace them, 'two at a time.'" Please tell me that this sounds stupid to all of you.
    Sep 11 2007
    San Mateo, CA
    D:
    WTF does that even mean?! Such incompetence.
    DUH! an Audi
    los angeles, CA
    interesting, I typically rotate every 5k, just for my sake of well being. Front to back is how I rotate.
    Funny thing, my mom's rover we never rotated (dad didnt want to) tires lasted over 38k...thats pretty good in my book.
    -randy
    Jan 15 2008
    Chino Hills, CA
    Quote Originally Posted by MichiganAudiDvr View Post
    hmm.. thats really odd that a balance fixed the problem, but hey, whatever works also, it helps to make sure theres no camber issues, as the front on our cars is not adjustable.. so if there is an issue, you would have to replace the upper arms
    Nov 19 2008
    MI
    Tell me about it. I was pulling my hair out trying to figure it out too.
    Sorry to hear about your exhaust/girlfriend issue...it's awfully generous of you to sell your exhaust and keep the girlfriend.
