Page 1 of 3 123 LastLast
Results 1 to 40 of 91
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    *** 034 - 2.7 to 3.0 STROKER KITS - KITS,TECH & FAQ - NEW PRODUCTS ADDED ***
    Got some requests from S4/RS4 customers that wanted to see a similar thread to our 1.8T stroker kits so here it is:
    PSA : PLEASE USE THIS THREAD TO ASK ANY AND ALL QUESTIONS YOU MAY HAVE ON YOUR MIND.WE PRIDE OURSELVES ON KNOWLEDGE SHARING SO DO NOT HESITATE TO ASK (no matter how dumb YOU think the question is.)
    Combinations range all the way from 2671cc's to 3013cc's!
    2671CC KIT - JE PISTONS
    This is the introductory level kit for those of you who want to do a simple hone on a tired block.Simply guage the rings,drop install on pistons and drop them in.
    Kit includes:
    (6) - 034 Motorsport 154mm/21mm Forged Connecting Rods
    (6) - 81mm bore / 21mm wrist pin JE Pistons with ANY compression ratio
    (1) - 034 Motorsport AAA VR6 Antifriction bearings
    $2299.99 + Shipping
    2805CC KIT - JE PISTONS
    Same amazing price as the 2671cc kit but requires boring of your S4/RS4 block from 81mm to 83mm.
    Kit includes:
    (6) - 83mm bore / 21mm wrist pin JE Pistons with ANY compression ratio
    $2299.99 + Shipping
    3013CC KIT - PARTIAL - JE PISTONS
    This is not for the soft at heart.Kit will require external sourcing of a 92.8mm stroke crankshaft from a 3rd party/etc
    Kit includes:
    $2299.99 + Shipping
    3013CC SHORT BLOCK - COMPLETE
    Complete Short block ready to go for those who do not want to source individual components.
    Short block includes:
    (1) - Brand new OEM S4 block
    (1) - Brand new 92.8mm Audi B6 3.0 Crankshaft
    (6) - 83mm bore / 21mm wrist pin 8.5:1 JE Pistons
    (1) - Crankshaft Girdle + ARP Main Studs
    $7689.99 + Shipping
    Of course you can buy the components individually:
    Piston Set, JE 2.7tt
    034 Motorsport Forged Rod set, Audi V6, 2.7t
    Head Stud Kit, Audi 2.7tt
    Headgasket, Compression Dropping 30v and 2.7tt
    Main Bearing Set, Coated, 2.7tt
    Rod Bearing Set, Coated, Audi V6 and 2.7t
    Main Stud Kit, 2.7tt
    Valve Set, Oversized, 5-valve Audi/VW Motors
    Valve Spring Set, 5-valve, High Rate and Lift w/Ti Ret.
    034 Motorsport Forged Rod set, Audi V6, 2.7t - $1029 + Shipping
    Pauter Rod Set, 2.7t and V6 Audi - $1255 + Shipping
    034 Motorsport Anti-Friction Main & Connecting Rod Bearings - $270 + Shipping
    Main Stud Kit, 2.7tt - $340 + Shipping
    Supertech Valve Set for 2.7TT motor - $799 + Shipping
    Supertech Valve SPRING Set for 2.7TT motor - $707 + Shipping
    Please send me a PMwhen you are ready to order and please select which displacement you desire ;)
    Also remember that 034 Motorsport carries a WIDE RANGE of Aftermarket parts for the 2.7TT motor including the ever famous (and controversial Tial turbo kits) as well as many amazing products.
    Thanks
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Re: *** 034 - 2.7 to 3.0 STROKER KITS - Increasing displacement - KITS,TECH & FAQ ***
    Price of your rods are mixed
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
    Feb 26 2006
    Earth
    Quote Originally Posted by GURUMAN View Post
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    i wish the cost of going fast wasn't so steep
    So sweet to see a kit out though!
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Feb 17 2008
    Ottawa Ont.
    its not going fast thats expensive.
    its doing it in style.
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    thank you once again 034!! Now makes us all a single turbo manifold.
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Veteran Member Three Rings Justin:NorCal's Avatar
    Feb 08 2008
    2000 Audi S4 (new build), 2000 Audi S4 Stage 3 (stolen last year)
    Dublin, CA
    What would a 3.0L with Ko4s running 20psi crank out power wise you suppose?
    Dec 11 2006
    Boston
    Quote Originally Posted by Justin:NorCal View Post
    They're just going to spool a whole lot faster. I doubt you would see any big gains in hp.
    Stage 3+ RS6's
    Mar 13 2007
    Montreal
    If somebody invest 5k to 7k in his block to push tiny k04's he would reflect one of the most ignorant spender in the Audi community.
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Feb 08 2008
    Dublin, CA
    Stage 3 tip :(
    Mar 13 2007
    Montreal
    Stage 3 tip :(
    Swap it
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    I want.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Established Member Two Rings RenegadeEngr's Avatar
    Jun 15 2008
    San Francisco
    Awesome!!
    2001:Silver:S4:DarIntake:ABT Chip
    Mechanical/Fluids Engineer
    Feb 26 2006
    Earth
    Swap it
    Feb 08 2008
    Dublin, CA
    At that point I would dump the S4 and take the money I would spend on GT28s etc and get a used 996TT and dump a GT700 kit into that.
    Apr 20 2004
    Boston
    ding ding ding....but then there is no more audiworld and audizine. Its the only reason why still own mine still lol
    Apr 20 2004
    Boston
    Veteran Member Three Rings joemomma's Avatar
    Feb 10 2006
    ct
    is the 83mm pistons=2.8L??
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by joemomma View Post
    yes, reading>you
    - Clint
    Feb 10 2006
    ct
    yes, reading>you
    Wasnt sure since all the kits minus the first have the same 83mm pistons yet the cc size is different
    Active Member Four Rings nthusiastt's Avatar
    Oct 27 2008
    B5 S4 Avant
    Quote Originally Posted by awdbiturbo View Post
    That and nobody expects an s4 to be THAT quick and it's more comfortable, less expensive to modify. Trust me p-cars are expensive as hell to mod. btw just an fyi the gt700 is nothing compared to the proto kit
    They want you afraid of your neighbors, your community, your family, your ability to support yourself, terrorists, climate change, China, Russia, Covid. As long as you are afraid, and won't unite red or blue, they win.
    Active Member Four Rings EUROTEK//S4's Avatar
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    good stuff!!!
    01' B5 S4 STG.II TIP
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    wowww
    i want this
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    Are the crank girdle and billet main caps that GURU is running recommended with the 3.0 kit? I see it's included in your short block. What's the pricing for these parts too? What's the cost if customers supply the block? Since it's being bored anyway it doesn't matter. What heads are included with your short block?
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    short block = no heads
    long block = heads included
    Senior Member Three Rings YBLEGL's Avatar
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    if its a short block it shouldnt include heads thats why its called a short block
    MAINTENCE AND STAGE 3 INSTALLS DONE, PM ME, MASS/ RI LINE AREA
    2001.5 S4 SILVER 6 SPEED BUILT BLOCK AND SINGLE TURBO KIT WITH PTE 6262.
    Veteran Member Four Rings FLACO X3's Avatar
    Jun 05 2008
    B5S4, B7A4
    Thornton & Elbert County, CO
    sweet, im more and more tempted to buy a B5 S4
    2000 S4
    2008 A4 2.0TQ
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by FLACO X3 View Post
    Expect to spend ~$20k for a solid GT setup though... Its about 1/2 that on the A4
    - Clint
    Oct 08 2008
    MA
    Quote Originally Posted by pit viper View Post
    Yeah, short block usually refers to the area below the head gasket but since this says "complete" short block engine I wasn't sure. The "complete short block" is $5400 more and the list says it comes with the crank girdle, crankshaft, block and main studs as the only other parts. Obviously there are labor costs associated with the assembly and such. I'm trying to weigh the costs of building my spare motor or buying the short block. A boring and acid dipping of the stock block would essentially make it new for 500. Sourcing the crank and head studs would cost about 1000. Not sure how much the crank girdle goes for but I would definately like to know. . What about billet main caps? would they be recomended when running a 3.0 with gt28rs's? How much do they cost? What's the lead time on them?
    Issam, shoot me a PM if you think this is off-topic. I have cash for a 3.0 liter build now but I still need cash for turbos so I'm not in too much of a hurry.
    Feb 26 2006
    Earth
    Quote Originally Posted by wdbdy2000s4 View Post
    I always recommend a crank girdle in a high performance build.Each tuner/performance company has a certain preference/discipline that they stick to me.Mine is to make the bottom end of an engine as solid as possible.
    If you are going to go the route of using your own block then I recommend sourcing a used 3.0 92.8mm stroke crankshaft and just buying the essentials.It will be cheaper for you in the long run.
    Feb 26 2006
    Earth
    HOT OFF THE PRESS!
    Cold Air Intake, X-1, B5 Audi S4/RS4 2.7t
    The X-1 intake is the ultimate cold air induction system for your B5 Audi S4. It uses a large open element filter, as well as a heat shield to ensure that your turbos are drawing in cold, dense, filtered air. Can be used with a stock or aftermarket MAF housing.
    Kit features a high-quality carbon fiber heat shield, AEM Dry-Flow air filter, and includes all installation hardware.
    PRICE = $450US SHIPPED FOR AZ MEMBERS
    Fuel Rail, Audi 2.7t
    Extruded fuel rails for the 2.7t, CNC machined to ensure perfect injector and thread sealing. Features threaded holes on the side of the rails for mounting, user will have to fabricate mounting brackets for their intended installation.
    Includes -6an fittings, larger fittings are available upon request.
    PRICE = $155US SHIPPED FOR AZ MEMBERS
    As usual send me a PM
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    Quote Originally Posted by Issam@034 View Post
    HOT OFF THE PRESS!
    awesome, thanks 034 for the new goodies!.. Is this fuel rail pretty much jsut for larger real high hp s4''s?
    Mar 13 2007
    Montreal
    Quote Originally Posted by Boris View Post
    And I was a part of the R&D on these fuel rails...
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Re: *** 034 - 2.7 to 3.0 STROKER KITS - KITS,TECH & FAQ - NEW PRODUCTS ADDED ***
    Wish i have the money for your stroker kit right now.
    I have the turbos but still on stock engine.
    Nice kits your selling here. Congrats.
    Feb 26 2006
    Earth
    You were part of R&D on alot of other things....where is Cohen?Still flopping down hillsides?
    Dec 11 2006
    Boston
    hhhmmm those fuel rails look mighty nice.
    Stage 3+ RS6's
    Jun 05 2008
    B5S4, B7A4
    meh, ill probably just do TiAL's and keep the 1.8T as a daily
    2000 S4
    2008 A4 2.0TQ
    Feb 26 2006
    Earth
    Good combo
    Established Member Two Rings satans child's Avatar
    Jul 26 2008
    1999 pro modified s4
    uk
    82.5mm bore and 86.4mm stroke .. is a true 2.8l the 83mm is a bit to much meterial to remove imho....
    May 23 2007
    Question Re: *** 034 - 2.7 to 3.0 STROKER KITS - KITS,TECH & FAQ - NEW PRODUCTS ADDED ***
    Does the Main bearing Girdle creat any issues with the starter and trans since they bolt to the upper oil pan?
