Results 1 to 8 of 8
    Jan 24 2008
    Pennsylvania
    Audi RNS-E GPS Antenna - Which is Best?
    Is there any difference in the OEM GPS antenna and the aftermarket brands? What should I look for if I want the best signal?
    Thanks for the advice-
    Bryan
    -04 A4 USP Avant 6MT
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    Re: Audi RNS-E GPS Antenna - Which is Best?
    The OEM antenna works the best simply because it's located outside the car and can receive more satellites than aftermarket ones that are usually mounted inside the car.
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Jan 24 2008
    Pennsylvania
    Quote Originally Posted by Dolphin18T View Post
    Thanks. Where is the external GPS antenna located? If I had the Audi Symphony II w/ XM, is it perhaps the same antenna? The one that looks like a shark fin near the USP Avant rear spoiler?
    Appreciate the help, nice ride...
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    The sharkfin has several antennas in it. It has the satellite antenna (for XM or Sirius) and the GPS. To use the GPS antenna, you need a long cable with a Farka connector on both ends. The connection to the antenna is located up top in the back passenger corner of the roof. I believe you only need to take off the rear side panel and not the headliner to get to the connector. You would then need to run the cable all the way to the front of the cabin and connect to the RNS-E. I think there's some details posted here if you search.
    USP CLUB MEMBER #34
    Jan 24 2008
    Pennsylvania
    Quote Originally Posted by CyberPMG View Post
    Thanks, that helped alot.
    Quote Originally Posted by Turbavanttro View Post
    Check this out, its pretty easy. DIY
    Cable is only $30.
    Veteran Member Four Rings TurbousMaximus's Avatar
    Aug 25 2004
    Whitehall, PA
    I have a gps antenna mounted inside behind my speedometer. I get 6-8 satellites all day. Which is the most you can get, so you dont need to do the sharkfin unless you want to. I have a spare antenna if you want. 15 shipped and its yours. Its magnetic and you stick in under the dash, very easy and convenient.
    2013 S7 Phantom Black on Black diamond - loaded
    2009 Audi R8, Black on Black w/ Blown V8 and black ADV.1 7.1's. (Carbon, Alcantara, Etc.) - Sold
    2011 S5 Sprint Blue w/ Silver Alcantara, B&O, Carbon Atlas, Nav, and Rear Differential - Traded.
    2006 A4 S-Line Brilliant Red 6spd - Sold
    2000 1.8tqms Ko4'd Brilliant Black - Sold
    Registered Member One Ring 03A4Tim's Avatar
    Jun 02 2007
    Arizona
    I also used (temporarily) the antenna behind the instrument cluster (I ran the wires behind the cluster and stuck the antenna to the metal frame just above the fuse box)
    I got 6-8 sat's in the open areas.. But once I headed up through the mountains, or downtown in parking garages or between high rises my sats dropped down to 1-3... The Sharkfin is definitely the best use if you are going to be in any areas that is not wide open to the sky above without obstruction...
